aprilia sr 50 help wont start oil light comes on????
rs_1978
PostPosted: 17:36 - 22 Jan 2007    Post subject: aprilia sr 50 help wont start oil light comes on???? Reply with quote
hi i have just bourt a aprilia sr and i carnt get it to go i charged the batt as was dead it did try turn over 1st time but now when i press the elec start it clicks and the oil light come on anybody know how to sort this or what the problem is it starts fine of kick start???? plz help thanks
finpos
PostPosted: 17:40 - 22 Jan 2007    Post subject: Reply with quote
I'd heartily recommend putting a new battery and some oil in it. Also, full stops.
finpos.
rs_1978
PostPosted: 17:44 - 22 Jan 2007    Post subject: sr Reply with quote
yes sorry for my spelling didnt think would matter lol, it is a new battery in it and it has full tank off oil..
finpos
PostPosted: 17:51 - 22 Jan 2007    Post subject: Reply with quote
Is this new battery also the very same dead battery that you charged up and won't turn the starter? If so, it's not new, it's dead and you need a new, new one.
Can't really help you with the oil light, I'm afraid. Are you sure it's just not going OFF for the duration of time you are holding down the starter button?
finpos.
rs_1978
PostPosted: 18:02 - 22 Jan 2007    Post subject: sr Reply with quote
hi yes its a new batt that was got for it, the 1 that came on it was dead i charged it, but also got a new 1 forgot to say sorry. well whats happening is i press the elec start and the relay clicks and the oil light come on and stays on untill i let go of the elec start i have cleaned all earths and checked all wires but still no luck:(
rs_1978
PostPosted: 18:10 - 22 Jan 2007    Post subject: sr Reply with quote
finpos
PostPosted: 18:10 - 22 Jan 2007    Post subject: Reply with quote
Find the thing that's making the clicking noise. Follow the thick cable from the +ve battery terminal - it should be the first thing you come to. It's called the starter relay.
The starter relay will probably have four electical terminals on it. 2 Big ones and 2 small ones.
If you have a multimeter, check you have 12V on both of the big terminals when the starter button is pressed. If not, the starter relay may be buggered.
If you do not have a multimeter, but do have a negligent attitude towards safety, short the two big terminals together with a huge screwdriver or something similar. This should cause some sparks and also the starter motor to spin. If so, the starter relay may be buggered.
finpos.
rs_1978
PostPosted: 18:27 - 22 Jan 2007    Post subject: sr Reply with quote
ok thanks alot ive just been lookin on aprilia site aswell. looks like its a coman fault with them, i will take starter off and try direct to battery, it is the relay clicking so must be a dead starter motor or like you say dead relay thanks alot for your help
russ
rs_1978
PostPosted: 19:19 - 22 Jan 2007    Post subject: sr Reply with quote
hi thanks for help. i tryed sorting it an no spark so i took starter of and stripped it to find the bushers had worn an stuck with dirt so i clened it all out an wd40 it an works like a dream now thanks alot:DVery Happy
The last post was made 17 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 17 - Page Size: 63.09 Kb
