My big yellow lemon (NSR125R)
st3v3
PostPosted: 09:11 - 18 Aug 2007    Post subject: Reply with quote
By the sounds of it the front just need bedding in, only riding her will sort that out. Put in add in the for sale section with a little :wanted: in the title for a stater motor and see if anyone PM's you. Or check ebay but they're about £80 buy it now on there.
c-m
PostPosted: 12:57 - 18 Aug 2007    Post subject: Reply with quote
had her running last night. Like all 2t at around 4-6k rpm it splutters, I was then expecting the powerband to kick in after 7k but nothing. Acceleration was just flat.
The powervalve is fitted and I can hear it when i turn the bike on.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
st3v3
PostPosted: 16:31 - 18 Aug 2007    Post subject: Reply with quote
You mean flat spot at 4-6K? Mine's at 5-7K, just as the power band starts. Fookin thing.
c-m
PostPosted: 16:50 - 18 Aug 2007    Post subject: Reply with quote
nah. tried it today, was moving along fine, then I pushed it to 6k rpm and there were two loud bangs.
The engine was still running so i tired again but this time the engine just cut out.
I managed to start it once more but again the engine just cutt out at mid rpms.
Any ideas on what this might be?
st3v3
PostPosted: 17:34 - 18 Aug 2007    Post subject: Reply with quote
if it's warmed up, and the choke isn't on that's bad.
c-m
PostPosted: 20:09 - 19 Aug 2007    Post subject: Reply with quote
I've sorted all the electrics, bulbs, etc.. now so they are all fine.
Gave the whole bike a good clean and degreasing.
Puchased a starter motor, which i should get on Wednesday, so hopefully that will all work fine.
I still need a left hand wing mirror though and don't really wanna pay £30
I started the bike up again today and she ticks over nicely.
I was in 1st just going slowly along then popped her into 2nd, gave it a bit a throttle and the engine died. Any ideas on this?
st3v3
PostPosted: 20:18 - 19 Aug 2007    Post subject: Reply with quote
No, out of ideas now, just give it a good ragg around in first and when(if) you hit 8K, pop into second. Good luck.
Pops_D6
PostPosted: 10:16 - 20 Aug 2007    Post subject: Reply with quote
Badly adjusted float valve? my NSR use to die if you opened it up too quick, turned out the float was sitting slightly too low so it wasn't sucking enough petrol through. Bent the tab back a bit and never had the problem since.
Either that or going along slowly oiled the plug up, they do go better when you're revving them harder....
Bikeless until we move and I decide what to get next!
c-m
PostPosted: 12:33 - 20 Aug 2007    Post subject: Reply with quote
the plugs looks pretty clean after idling for a few mins, no build up or colour change to note really.
Guess, i'm taking the carb apart tonight then
c-m
PostPosted: 13:11 - 28 Aug 2007    Post subject: Reply with quote
put some fresh petrol in her and went for a spin around the block or so.
Came back and it appears to be leaking coolant. from somwhere directly above the cyclinder.
I'm couldn't find any problems with the pipes, so i'm guessing the previous owner (who said he put new coolant in) just over filled it.
I also need a gasket for the water pump.
replaced the speedo cable with on from an NS (cables appear the same) but the speedo still doesn't work Sad
got some more picts to go up when I find my memory card adapter
c-m
PostPosted: 13:29 - 04 Sep 2007    Post subject: Reply with quote
Ordered some new hosing form Dave sliver and some clips. Hopefully that will be the end of the coolant problems.
really would like to sort out the mot this weekend.
Here are some more images
https://www.eastcoastlacrosse.co.uk/carl/nsr/Image573.jpg
https://www.eastcoastlacrosse.co.uk/carl/nsr/Image574.jpg
https://www.eastcoastlacrosse.co.uk/carl/nsr/Image581.jpg
c-m
PostPosted: 14:27 - 19 Sep 2007    Post subject: MOT Failure Reply with quote
Bike failed on the following
Rear shock and bush
oil seal
tyre valves
oh dear Confused
st3v3
PostPosted: 16:25 - 19 Sep 2007    Post subject: Reply with quote
Weekends work with the bit's. Thumbs Up
c-m
PostPosted: 09:38 - 20 Sep 2007    Post subject: Reply with quote
do you reckon its worth fixing or just selling off and cuting my loses?
I'd need a new front tyre and valve
Rear tyre valve
new oil seals
rear suspension bush
rear shock
I just need something to get around on really while i wait to take my test.
The last post was made 16 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 90.67 Kb
