loply |
loply World Chat Champion
Posted: 20:55 - 03 Sep 2007 Post subject: Tip on raising the idle speed |
Hi folks,
I don't know the exact ins and outs but one thing that I have noticed benefits me a lot on my SZR660 and my SV650 is setting the idle speed a lot higher than stock. I'd like to share this theory with the forum.
I run these bikes at 2,250rpm and 2,600rpm respectively.
I find this makes a massive difference to rideability - On the SV, changing down into first or second for a junction or tight roundabout used to require absolutely sublime throttle control and even then it was a jerky, off-putting afair most of the time. If an unexpected event induced a downshift you had better be on your toes or else it's pogo time.
With the idle speed raised you can bang down into first or second approaching a junction and pretty much let the clutch drop - The higher idle speed means the new gear engages practically without being noticed and feels surreal at first, but is very pleasant.
Changing gears in both directions feels smoother and there is far less play in the transmission.
This avoids sudden distractions and unsettled suspension.
In my oppinion definately worth trying - Just to see if you like it.
On most bikes there is a philips screw on the left hand side of the engine somewhere which changes the idle.
Be aware of the obvious downside being rapid heating when stationary, but I've never found it to be a problem. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Ted |
Ted World Chat Champion
Posted: 20:57 - 03 Sep 2007 Post subject: |
Plus it'll use a tad more petrol... ____________________ '07 Honda CBF500 / '93 Vauxhall Astra (www.fb.com/2wdOffRoader) / '04 Vauxhall Movano
Projects: '81 Honda CX500 x2 / '85 Land Rover One-Ten / ...plus many horticultural things.
||| Bike Test: DAS: PASSED 13/02/2009 ||| Car Test: PASSED 22/05/2005 ||| |
Blau Zedong |
Blau Zedong Banned
colin1 |
colin1 Captain Safety
loply |
Posted: 21:07 - 03 Sep 2007 Post subject: |
The engine runs at that speed on choke when cold anyway so it doesn't make a difference to startup running.
Fuel economy is unlikely to be affected as the amount of time you spend at idle speed is very small and with the difference will be almost immeasurable. Obviously once you open the throttle it makes no difference what the idle speed was.
The noise factor can be annoying but I run standard exhausts so it isn't too bad. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
MattEMulsion |
MattEMulsion World Chat Champion
Ted |
Posted: 21:13 - 03 Sep 2007 Post subject: |
I think I've set mine to lower than the manufacturer's default, mainly because it sounds better on tickover! ____________________ '07 Honda CBF500 / '93 Vauxhall Astra (www.fb.com/2wdOffRoader) / '04 Vauxhall Movano
loply |
Posted: 21:14 - 03 Sep 2007 Post subject: |
Hey, don't knock it till you've tried it... Seriously, it makes certain things a lot smoother.
...Besides, GP bikes run like 3,000rpm tick-overs... As do 98 R1's. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
wristjob |
wristjob World Chat Champion
G |
G The Voice of Reason
Posted: 22:13 - 03 Sep 2007 Post subject: Re: Tip on raising the idle speed |
I ran my race sv650 with a 3500rpm idle speed or so (yes, that's over 1/3rd revs!)
However, I've never really seen the need on the road.
On track you are changing down under very hard braking, so it takes a bit of concentration to get a blip perfect, so this helps stop the rear wheel skipping.
On the road I just make sure I blip the throttle appropriately and never really had a problem - it is something you do have to think about a bit if you're not used to doing it, however.
Also, the slower idle speeds lets you get it sliding more easily for bits of little backing-it-in style fun if you so desire . |
Kickstart |
Kickstart The Oracle
loply |
Posted: 22:28 - 03 Sep 2007 Post subject: |
G, I would trust your oppinion on the subject so can I ask what modifications or findings you made when racing the SV in Minitwin?
I ask as I'm going to be prepping one for it over the winter (probably not the one this thread is about).
My basic plan was just the obvious stuff - new shock, new fork springs, drop the forks and raise the idle speed and pegs... It's the not so obvious tips and tidbits I'm on the lookout for. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
DEN MONKEY |
DEN MONKEY World Chat Champion
G |
Posted: 09:41 - 04 Sep 2007 Post subject: |
loply wrote: |
My basic plan was just the obvious stuff - new shock, new fork springs, drop the forks and raise the idle speed and pegs... It's the not so obvious tips and tidbits I'm on the lookout for. |
That seems to be the basic stuff you need for a road/track SV (rather than dedicated track bike).
Of course you want to make sure the suspension is set up decently for you.
There are some good and some not so good crash bungs for the SV. Unfortunately I don't know who made the very good ones on the race SV luke now has - they're still doing ok after 8 crashes by me and quite a few more by luke as well as some by the previous owner.
Much, much better than the R&G ones I had on the other SV.
Most of the other modifications done were general race ones - ie taking bits off and securing other bits in different places etc.
Race-style clip-ons might be worth a look as they offer a little more adjustability and should be a fair bit less to replace the tubes if you do drop it. If I remember, the SV clipons are above the yokes as standard, a lot of people would put them below to get a bit more weight over the front.
A quick action throttle is definitely worth while. I'd recommended the venhill one, for good price and a good performance.
This only uses a single throttle cable, but this also slightly helps prevent engine braking, as when the throttle is closed, the carb returns at it's own rate, rather than you actually pulling it closed. |
loply |
Posted: 19:53 - 04 Sep 2007 Post subject: |
Thanks for that g, useful note on the throttle grip, bungs and clipons.
If you find out what kind of bungs were on that bike let me know!
Cheers. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
veeeffarr |
veeeffarr Super Spammer
colin1 |
veeeffarr |
G |
veeeffarr |
G |
sickpup |
sickpup Old Timer
MarJay |
MarJay But it's British!
G |
sickpup |
sickpup Old Timer
The last post was made 16 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
