jonny99 |
jonny99 L Plate Warrior
Posted: 23:19 - 23 Sep 2007 Post subject: Help please for a dirt bike for a 12 year old |
Hi there
Hope this is the right place for this
I am looking to buy a dirt bike for my 12 year old lad for a bit of scrambling in our paddock at the back of our house (sounds more impressive than it is). Its basically a field with a bit of woods with some jumps etc.
Do you have any recommendations as to a cheap (less than £200) starter for him - only looking for 50cc or so.
Is a mini dirt bike any good or are they a bit small?
Jonny |
Posted: 23:23 - 23 Sep 2007 Post subject: |
Trouble is he'll be growing like crazy. You'd probably be best getting a full sized one if you can.
I'd have said get a Japanese one but at £200 you could be pushing it, you'd be looking at a pretty old/knackered one.
Quite a few people just use an old CG125 road bike with knobbly tyres on it for a 'field bike'. Surprisingly robust. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
G |
G The Voice of Reason
Posted: 23:39 - 23 Sep 2007 Post subject: |
If you had a bit more money, I'd suggest a 80cc 2 stroke crosser.
The big wheel versions can take adults comfortably, while small wheel would probably be fine for a 12 year old if the big wheel isn't.
I believe you can often upgrade them.
The newer ones can be quite fast, but worse case, you could probably make a throttle restricter if it was an issue.
However, you'd have to be lucky to find one in reasonable nick for that price.
If you can get 'em to fit on it, a DT50, TS50 or similar would do the trick for messing about on, but not so great for stuff on track etc.
For competitive, you could also consider a pit bikes, as plenty of stuff caters for them now. You can get them for £200 second hand, though it'll probably be a cheap chinese one that won't stay in one piece that long with out attention.
I suspect the 50cc mini dirt bikes will be a bit too small for a 12 year old - take five years off and that's about right I think.
jonny99 |
G |
yankeedoodle |
yankeedoodle Nearly there...
Posted: 21:05 - 24 Sep 2007 Post subject: |
if its jus for messing around in the garden on then a pitbike would be a good idea. 50cc. or maybe a 110? there's the xports which are good bikes, or if you want a cheaper option then some of the less well known makes which have Lifan engines in are ok jus for basic use ____________________ Bandit 600 |
leeves |
leeves Two Stroke Sniffer
Willenium |
Willenium Nova Slayer
The last post was made 16 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
