NSR Overheating, thermostat changed..
Cwizard
PostPosted: 13:46 - 06 Nov 2007    Post subject: NSR Overheating, thermostat changed.. Reply with quote
hey all,
Other week the NSR decided to hit the nice red line on the temp dial, great. Now changed the thermostat. Still overheating.
Thinking waterpump, anyone changed one before, how much work ami looking at? Crying or Very sad
Honda NSR 125 R1 (51)
Back and better than ever!!
ncrn
PostPosted: 14:29 - 06 Nov 2007    Post subject: Reply with quote
You have checked there is in fact coolant in the system right? My bike lost mine due to a loose clip while I was riding and so I got a red temp line.
I can't see a price for the water pump but if you email the people at https://www.davidsilverspares.co.uk they should be able to tell you.
But yeh I'd check first that there is coolant in the bike and you haven't got a leaking pipe somewhere.
Oh and don't ride it if it's doing this, you may sieze the engine.
ncrn
PostPosted: 14:56 - 06 Nov 2007    Post subject: Reply with quote
Another thought did you bleed the system after filling it with coolant? I'm assuming you were the last person to fill it with coolant here.
Cwizard
PostPosted: 16:20 - 06 Nov 2007    Post subject: Reply with quote
yeh theres tons of coolant, only checked the other day, got a little test the local bike shop said, lift tank start cold with rad cap off to make sure water movement. it suddenly happened. didnt notice till got to my house. overheating with coolant dropping out of the overflow. checked all the hoses, none loose.
alains
PostPosted: 18:02 - 06 Nov 2007    Post subject: Reply with quote
change head gasket !
the worst day fishing is better than the best day working
ncrn
PostPosted: 19:50 - 06 Nov 2007    Post subject: Reply with quote
If you wanna inspect the water pump at all then you'll need to drain the coolant, also to change the head gasket you need to drain the coolant.
Have you got a copy of the manual? I recommend you take a look at it, do as alains recommends he knows the NSR inside out Razz. I guess it wouldn't hurt to look at the pump while the coolant is out.
Cwizard
what on earth for Shocked , the engine has only got 1000 miles on it, remember was a new engine alains
https://www.bikechatforums.com/viewtopic.php?t=126161&highlight=
bugsy46
Village Idiot
PostPosted: 20:05 - 06 Nov 2007    Post subject: Reply with quote
Rolling Eyes
Why not check the temperature switch first? Before tearing down the engine
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
Cwizard
PostPosted: 21:04 - 06 Nov 2007    Post subject: Reply with quote
didnt think of that, thou the needle moves. when i realised i drove home, found the needle would go down at lower revs but be moving reasonable speed, assume the freezing crappy english weather was enough to cool that little bit
iooi
PostPosted: 21:32 - 06 Nov 2007    Post subject: Reply with quote
Stupid question time......
Does that fan come on when it starts to overheat ??
Is the rad full of dead flies and other such crap, which will stop it working....
Karma
Cwizard
PostPosted: 21:40 - 06 Nov 2007    Post subject: Reply with quote
fan? what fan?
i dont have one, bit of background, since the engine refit the bike has been running sweet as, its only a couple of weeks ago it suddenly overheated, by sudden i mean i had been riding about in the evening, put bike away, took it out next day. Halfway to friends house, red line and steam. now this was enough for me to call ahead and say im gonna be a while. let it fully cool down as i pushed the 2 min to his house, left to cool all day. rode back in the afternoon, 5 mins down the road the needle is tickling the red line. no steam, left to cool, spoke to father in law who suggested changing the stat. done and not much difference. thats where i am at the moment.
iooi
PostPosted: 21:42 - 06 Nov 2007    Post subject: Reply with quote
Should be a fan behind rad to draw cool air through when you are stopped.
bugsy46
Village Idiot
PostPosted: 21:44 - 06 Nov 2007    Post subject: Reply with quote
Just because the needle moves doesnt mean to say the switch cant be faulty, BUT it could also OR be a fault with the clocks
Cwizard
PostPosted: 21:45 - 06 Nov 2007    Post subject: Reply with quote
never had one, NSR's dont have them do they? Confused
bugsy46
Village Idiot
PostPosted: 21:46 - 06 Nov 2007    Post subject: Reply with quote
Shouldnt be anything to do with the fan, how often this time of year does your fan come on when riding? ie when does the temp reach fan territory? especially on a low powered machine
ncrn
PostPosted: 21:50 - 06 Nov 2007    Post subject: Reply with quote
No the NSR does not have a fan, just to clear that up. The radiator is cooled only by air flow, thats why it suffers a bit in the summer when stuck in traffic.
Steam would indicate to me there is a leak, have you looked on the top of the head for a sort of copper coloured deposits? I had this when my nsr leaked its coolant over the head.
Cwizard
PostPosted: 21:51 - 06 Nov 2007    Post subject: Reply with quote
ok proper novice question, how can i test the switch, short of replacing it. though i dont want to get into the point of replacing everything till i find it Shocked
Cwizard
PostPosted: 21:52 - 06 Nov 2007    Post subject: Reply with quote
would it be suffering a leak problem with a newly built top end fitted and checked by honda?
bugsy46
Village Idiot
PostPosted: 21:55 - 06 Nov 2007    Post subject: Reply with quote
Find the switch, there should be a wire going into it, put this wire to earth, or , remove the switch, put in water, heat the water, then using a multimater measure the resistance whilst referring to specs
bugsy46
Village Idiot
PostPosted: 21:56 - 06 Nov 2007    Post subject: Reply with quote
If it was pissing out coolant youd know it, there will be dried in white splash marks, and a nice sweet smell!!!
Cwizard
PostPosted: 22:13 - 06 Nov 2007    Post subject: Reply with quote
well none of that. so thinking switch check then. i'll be glad when this poxy bike doesnt have any problems. pretty much replaced the entire bike. Mad
prawny1
PostPosted: 12:21 - 07 Nov 2007    Post subject: Reply with quote
Do you live in a hard water area? If so it might be a furred up rad (limescale) try running some viniger or half a calgone tablet throu your system.
Might be worth popping the water pump cover of and checking that it is engaged with the gear properly and that it is secure on the shaft.
hellkat wrote:
Some people are only alive cos its against the law to kill them.
Tango675
PostPosted: 14:53 - 07 Nov 2007    Post subject: Reply with quote
You should never use just tapwater in your rad. For best results use distilled water with the correct antifreze mixture.
Most likely cause is either the rad, a blockage or the pump.
Do you have any cold-spots on your rad, or at the hozes either end? Does pressure and tempiture build up evenly on the rubber pipes that enter and leave the rad?
May be worth getting the whole system flushed, checked out and pressure tested.
Somebody give that windup merchant a torque wrench..
ncrn
PostPosted: 16:50 - 07 Nov 2007    Post subject: Reply with quote
I agree with Goat-Boy really, you should take the cooling system apart and have a good look at it, obviously after testing the switch as mentioned above.
Thom_NSR
PostPosted: 17:08 - 07 Nov 2007    Post subject: Reply with quote
Could lack of two-stroke (broken pump?) cause this sort of rapid heating of the engine?
The last post was made 16 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 17 - Page Size: 138.93 Kb
