do you have indicators on your bike?
ghettostan
PostPosted: 20:33 - 17 Feb 2008    Post subject: do you have indicators on your bike? Reply with quote
i was reading on the internet about motorbikers Legal Requirements
and never knew that you do not have to have indicators ?
is this true?
Confused
im not thinking of taking mine off after spending £20 for a set. lol
stooster
PostPosted: 21:13 - 17 Feb 2008    Post subject: Reply with quote
ive got a 76 lambretta no indicators.....never had them...dont need them...mot still pass...
as said...if the bike had them fitted originally then i think they need them for mot....
seems a bit stupid really...compared to my cbr the lambretta is unstable, poor suspension, poor handling...etc....they should be forced to have them really...
past - er5 - sv650s - drz400s - cbr 600 - gsxr 750 - lambretta gp mugello
present - vespa adidas px - fz6n
Silver
PostPosted: 21:16 - 17 Feb 2008    Post subject: Reply with quote
I had an XLR250 with no indicators. It was a bit unnerving when going round roundabouts.
Jack_Cheese
All you need is a brake light and horn AFAIK, you don't need any other lights or mirrors.
I wouldn't dream of riding without them tbh.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 22:29 - 17 Feb 2008    Post subject: Reply with quote
Lighting rules are a minefield.
Basically if it had indicators and is post 1st August 1986 then it must have indicators (the lighting regulations say 1st April 1986).
Bikes from prior to that do not need them, and can have them removed.
There are exemptions for certain classes of bike. Such as off road bikes (think normally defined by a minimum ground clearance) and strangely mopeds.
Lighting rules are here:-
https://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_6.htm#nschiobligatorylampreflectorrearmarkingdevice
Type_Mo
PostPosted: 23:29 - 17 Feb 2008    Post subject: Reply with quote
basically...
If you have an indicator switch then you need them and they need to be working correctly. No switch then no need for indys.
simple as that!
kestrel
PostPosted: 23:30 - 17 Feb 2008    Post subject: Reply with quote
Kickstart is correct, bikes first used after the 1st of August 1986 must have indicators fitted unless the bike is designed specifically for offroad use or if used only during daylight hours. For daylight only MOT the front and rear lights must either be removed or painted or masked over. Indicator requirements are set out in the Construction And Use Regulations.
PostPosted: 23:34 - 17 Feb 2008    Post subject: Reply with quote
That is another minefield. The regs specify various lighting requirements with exemptions if there is no rear marker lamp. But then specifies that the rear marker lamp must be fitted with no exemptions while also saying that nothing in the regulations can be read as saying lights must be fitted.
Personally suspect that there are further very old regulations specifying lighting requirements which are technically still in force. Hence the comment in the MOT manual that bikes from before ~1930 do not need headlights (which can be read as those after that date do need headlights).
PostPosted: 23:49 - 17 Feb 2008    Post subject: Reply with quote
Various of my bikes have and don't have indicators.
Have ridden without quite a lot and you get used to using hand signals quickly enough.
The last post was made 16 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 16 - Page Size: 68.65 Kb
