Kickstart |
Kickstart The Oracle
Tango675 |
Tango675 Crazy Courier
Posted: 20:23 - 25 Mar 2008 Post subject: |
BMW prove that these days you can tune and develop an engine to do everything with some electronic wiz-bang (see their boxter twin). It will inherently be better at some things than others, for example, it won't make a particualy good race engine but it will make a nice touring engine and maybe even do a bit of off-roading.
The IL4 is the best selling engine fitted to the most motorcycles (~600cc+) because its what most people want at a price they can afford. And if you happen to knock out car engines too...
However not everyone wants a IL4, so you can take your pick of any other engine configuration in various states of tune.
Would a harley be a harley with an IL4? A lot of the bikes character comes from the engine.
V-twins cost more to manufacture (2 heads) and produce more vibrations than a IL4 but are easy to tune for torque and reasonable power. They also fit easily into a motorcycle frame. Lots of people like them because of the noise (including myself )
A V4 takes on the caractoristics of both a V-twin and IL4, but costs more to manufacture again (two pairs of heads). Honda believe that this is the optimum engine for a motorcycle, but have still to prove this to everyone else (as they are the only people who make them). ____________________ Somebody give that windup merchant a torque wrench.. |
Kickstart |
Tango675 |
Posted: 22:27 - 25 Mar 2008 Post subject: |
Kickstart wrote: | Goat-Boy wrote: | V-twins cost more to manufacture (2 heads) and produce more vibrations than a IL4 |
Proper V twin has less vibration than an IL4.
How?
Unless you have a two stroke, you are always going to have uneven combustion between the two cylinder. The advantage a twin has, is if they are mounted at 90 or 180 degrees to each other. This is because the forces are more balanced, however this will still produce more vibration than an IL4 with the same CC as you have two larger lumps of metal trying to move apart from each other. The only way to counter this is with weights or a big flywheel.
An IL4 has more even combustion over the 4 cylinder and therefore produces less vibrations naturally. Again you can "fix" this with weights or a big flywheel, but these will be lighter than the V twin.
Just think how much vibration you get with a single, then how much you get with a V2, IL4, IL6, V6, V8, V12 etc. It goes down each time, because of the bigger overlap on combustion.
Glad to hear Honda have been joined by a few others on the V4 front. It is a good engine choice for a motorbike (compact and narrow), just expensive to make, so it only really appears in the more exotic bikes. ____________________ Somebody give that windup merchant a torque wrench.. |
Kickstart |
The last post was made 16 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
