De restricting a dtr 125 1998
Polsta
PostPosted: 16:44 - 10 Apr 2008    Post subject: De restricting a dtr 125 1998 Reply with quote
Hi folks
thought id post a thread about de restricting my dtr 1998 model, im not 100% on the best way to go about it ?
whats the wiring trick people talk of ?
also seen this page ..
https://www.dtr125.net/tuningf.htm
is that all i need to do ? take the metal bit out, and sort the power valve ?
or is it best to buy a full dep exhaust ? but £240 is a lot of wonga, would taking the metal bit out, and putting a £60 dep sinlencer bit be the same/as good ?
appriciate any help, thanks
AAAthreat
PostPosted: 17:51 - 14 Apr 2008    Post subject: Reply with quote
First off man there are loads of threads about derestricting DT's on this forum and on the net.
About buying a full DEP system that should give you a good increase in BHP (double in some cases) but ive also heard that a standard DT exhaust that has had the restrictor removed gives you more, i persenlly have a DEP silencer and am planning on buying a derestricted standard front pipe then when i can afford it buy a DEP front pipe.
Good luck getting more horses out of your DT mate i need more myself considering my 01 only does 60 Smile.
The last post was made 16 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 17 - Page Size: 32.77 Kb
