Author |
texas peat |
 texas peat Borekit Bruiser
Back to top |
Kickstart |
Back to top |
texas peat |
Back to top |
Kickstart |
 Posted: 15:35 - 22 Aug 2008 Post subject: |
Jets are the bits in the carb that determine how much fuel can flow at different throttle openings. Too large a main jet and it will run rich on large throttle openings, which will lose performance. Too small a main jet and it will run lean on large throttle openings which will again lose performance but also run the risk of seizing the engine.
Aprilia exhausts have got rather worse over the years. Basically due to bits stuck in them to get through emissions tests. On mine the power comes in about 8000 and ends just under 11000, but mine is an early one and has the 34mm carb as standard as well.
One thing worth checking is that the power valve is in the right way up. Quite often people get this wrong and that loses a fair amount of top end power.
Back to top |
texas peat |
Back to top |
Kickstart |
Back to top |
texas peat |
 Posted: 15:56 - 22 Aug 2008 Post subject: |
think my chain does need lubing actually,it seems quite dry..any you recommend? and what are the rings i need to change?? i might have a go at that if its simple enough. want to learn as i go along..put a new spark plug in the other day(br10), i was well chuffed with myself!!  ____________________ \||/
Back to top |
Kickstart |
 Posted: 15:59 - 22 Aug 2008 Post subject: |
Pretty muh any chain lube. Or just oil (messier but does a good or possibly better job).
Rings go around the piston and seal the piston. Top end engine strip to fit new ones.
Spark plugs are not that long lived on 2 strokes (nowhere near so much of a problem these days), but carrying a spare means you can easily put it in at the side of the road should one fail.
Back to top |
texas peat |
 Posted: 16:01 - 22 Aug 2008 Post subject: |
thanks for info keith. i wont pester you any more..(for today anyway,lol.)  ____________________ \||/
Back to top |
The last post was made 16 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
