at risk of upsetting: Bringing ER-5 up to GPZ Engine spec?
Smooth
PostPosted: 14:22 - 03 Dec 2008    Post subject: at risk of upsetting: Bringing ER-5 up to GPZ Engine spec? Reply with quote
The GPZ is the obvious parts donor for releasing the stallions from the softly-tuned ER5.
I've seen Stinkwheel's and others posts on Kwak 500s and wonder if anybody on here has bothered to swap the entire GPZ500 engine or just the cams, CDI and carbs onto an ER-5? Valve timing being the most obvious difference between them.
From a different approach, has anybody achieved any tangible improvements from an ER-5 with exhaust mods and re-jetting?
ps. Yes, I know that more power isn't everything and that going out and buying a better bike would be cheaper.
As per previous thread, I believe that improvements to handling (and riding skill) would be more beneficial.
TDM850
PostPosted: 14:32 - 03 Dec 2008    Post subject: Reply with quote
I think its pretty much just cams, exhaust design and airbox size/shape.
The cams will be a pain in the butt, and the GPZ exhaust is a two into two if I recall correctly.
But it is perfectly doable as far as I know. The other alternative of course is to look for a second hand GPZ engine...
Smooth
PostPosted: 14:41 - 03 Dec 2008    Post subject: Reply with quote
It would be easier to swap the whole engine out and fabricate an exhaust to suit, but the engines cost a few quid.
Fitting a set of cams and a new chain&tensioner would be fairly involved, but satisfying (and I could set the valve gaps properly at the same time!)
TDM850
PostPosted: 15:11 - 03 Dec 2008    Post subject: Reply with quote
If you're happy to do that then go for it! Thumbs Up Smile
I've not ridden a GPZ and an ER5 back to back, so I can't say if you will notice the difference, but its an interesting project, and it won't make the bike worse (Unlike potentially swapping forks!! Wink ).
PostPosted: 15:47 - 03 Dec 2008    Post subject: Reply with quote
Valve timing, carb jetting and ignition advance curve are the biggest physical differences.
You would need to check the ER5 ignition system is compatable with the GPZ CDI. Some have one pickup, some have two (there is a GPZ CDI of each type, you'd just need the right one).
In real life, the main issue is the shape and size of the airboxes.
Smooth
PostPosted: 15:51 - 03 Dec 2008    Post subject: Reply with quote
Yes, the ER5 has a single pickup coil.
Have you attempted anything similar with your KLE, Stinkwheel?
TDM850
PostPosted: 16:41 - 03 Dec 2008    Post subject: Reply with quote
My KLE has a GPZ500 engine in it. Complete with carbs and CDI.
Won't run on standard GPZ jetting, runs ok on KLE jetting but doesn't have the GPZs top-end silliness.
Exhaust diameter identical, inlet stubs identical.
Conclusion: Airbox configuration is very important. The GPZ relys on pressure waves to stuff air (and therefore fuel) into the engine. This is achieved by clever airbox design (which is also what made the 900R the first 150mph bike, the 500s is essentially half a 900R). The KLE airbox is around half the size of the GPZ one.
Smooth
PostPosted: 16:59 - 03 Dec 2008    Post subject: Reply with quote
Interesting.
It must be similar to 2-stroke expansion chamber pulse tuning.
I wonder what would be the best way to optimise the 'effective length' of the air passage-way for the KLE/ER-5?
I wonder if modifying the KLE/ER-5 air box would have any benefit on a standard engine? -obviously not wanting to run lean.
TDM850
mudplug
PostPosted: 17:51 - 16 Dec 2008    Post subject: Reply with quote
Not seen a KLE air box (and none on ebay to compare lol) but the ER5 air box is pretty big.
For the benefit of all readers, I was thinking about modifying the air inlet on my ER5 air box to supply extra air, if I re-jet to GPZ spec, along with the camshaft swap.
However I'm now concerned that even though my planned mod (a hole in the centre of the inlet cover) isn't engine-side of the air filter, it might still mess up the pulses.
It would effectively be by-passing much of the the inlet trunk-tube thing; which I notice is also a feature of the GPZ air box.
Maybe some sort of hole nearer the tip of the trunk would be of more benefit; I suppose the ideal would be a larger-diameter trunk, not easy to fabricate.
ER5 airbox photo:
https://i10.ebayimg.com/05/i/001/01/b5/fb73_1.JPG
PostPosted: 18:16 - 16 Dec 2008    Post subject: Reply with quote
Suspect the important part is the length of the trumpet from the carbs into the airbox.
Playing with the tubes feeding air into the airbox might upset things. Shape wise the intake is probably quite good (the shape of the edges of the intake is pretty important to the flow), and drilling extra holes might screw that up.
I do have a GPZ500 airbox floating around.
PostPosted: 21:38 - 16 Dec 2008    Post subject: Reply with quote
Me too, although it isn't very handy just now and I intend to fit it to the KLE at some point (intentions and real life actually happening are not necessarily the same thing though).
Here's a picture of a GPZ500 one I found on ebay:
virus
PostPosted: 21:43 - 16 Dec 2008    Post subject: Reply with quote
Jesus christ who designed that airbox? it looks like someone has been playing too much tetris. Laughing
No wonder joe had so much trouble refitting his at R+S with no tools.
John
own: 81 xs1100g...
PostPosted: 21:49 - 16 Dec 2008    Post subject: Reply with quote
It was designed by an accoustics engineer, not a motorcycle engineer.
If you think that's big, you should see the one on a ZZR1100.
virus
PostPosted: 22:09 - 16 Dec 2008    Post subject: Reply with quote
GPZ750r/900r airboxes are quite random, there a complete pain in the arse to get in the frame let alone connected to the carbs.
I keep telling myself to keep it and not convert to K+n's, its got to have some use other than a battery box.
John
own: 81 xs1100g...
Smooth
PostPosted: 09:02 - 17 Dec 2008    Post subject: Reply with quote
Are those 'side pods' part of the airbox itself?
It would be interesting to know how the lengths of the ram pipes, inlet rubbers and distance from carb bodies to the back of the air box etc. differed between the ER5/KLE/GPZ.
Presumably the GPZ air box is designed to have a natural or resonant frequency that coincides with the power-band of the engine, but allows smooth running at low rpm.
TDM850
mudplug
PostPosted: 12:05 - 17 Dec 2008    Post subject: Reply with quote
I think the 'pods' house the inlets.
So is the route anyone takes in trying to tune these engines just a matter of choice, or more of common sense?
What I mean is, I'm sure it would appear to be the cheaper option to go down the route of cone filters and bigger jets, but there are so many stories of people never getting the fuelling right; even if they get more top-end power, it's at a big pay-off regarding how usable the engine is.
Whereas the manufacturers had all the time, money, expertise etc to put into development, so used the pressure-wave approach to tune it. It's obviously going to produce both more top-end power and more usable power across the rev range.
I don't have the facilities that they do. But I can buy an airbox which they've developed. (Don't know if it fits in the frame yet.)
Does it make sense to utilise the development Kawasaki put in, rather than using more basic methods (which won't really achieve the same results)?
Or does it make sense to be content with a smooth, average bike, and accept it's substantial merits rather than looking at it's relative flaws...
I suppose a lot is down to what I'm going to use my bike for. (i.e. not racing.)
Purplepill
Edit: beaten to it
''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack''
mudplug
PostPosted: 12:30 - 17 Dec 2008    Post subject: Reply with quote
Interesting reading for anyone (like myself) that only has a basic understanding of how this works:
Wikipedia pages on Manifolds and Helmholtz Resonance.
I'm sure there are more accurate and detailed sources, but Wiki's free Laughing
Smooth
PostPosted: 12:50 - 17 Dec 2008    Post subject: Reply with quote
Resonant frequency indeed.
Those links takes me back to uni days... although I've only an appreciation, rather than an in-depth knowledge of waves and vibrations, having not looked at it for about a decade.
what I recall:
Mass, spring constant and damping constants are the major considerations (as they are in many aspects of engineering)
For acoustics, column length is important.
Interestingly, the EX500 (The USA GPZ500)has this air box
EDIT: These are the SIDE covers, I can't tell if they are different to Mudplug's photo
https://www.stevemorley.com/ex500/airbox/sidebyside.jpg
https://www.stevemorley.com/ex500/airbox/open.jpg
The accepted mod from the resident guru on the EX-500.com forum for this airbox is to
drill a second 1" intake hole as shown here in this link
https://www.stevemorley.com/ex500/airbox/aftersm.jpg[/b]
TDM850
PostPosted: 21:45 - 17 Dec 2008    Post subject: Reply with quote
Possible, as I would think that the trumpet on the intake into the airbox is pretty irrelevant for performance. The intakes from the airbox to the carbs I think are far more important.
stevo as b4
PostPosted: 22:27 - 17 Dec 2008    Post subject: Reply with quote
I'd consider going for the K&N type clamp on filter's, but only if when they are fitted that they are fairly well covered by the tank/seat/side panels etc. I think running any bike on exposed filters is a pain, and wet weather could really bugger up the carburation and running. I would also try and fit the K&N's as far back as possible and use some long ram tubes of a similar length and design as those that go from the carb bellmouths, to the airbox. That way it's likely to be a bit less hassle getting the jetting close to what is needed.
It goes without saying that you should also use the biggest sized filters that you can fit in, as they will take longer to clog up and will be less sensitive to airflow restriction.
I'd be dissapointed TBH if the route of a set of open filters+ 2-1 exhaust and race can+ stage 3 dyno jet kit or alternative jetting kit, could not find you another 3-4bhp at peak. The midrange would possibly improve more than this however. I don't know how the ER5 lump would respond to a 3-4deg ignition advancer, but fitting one and using super unleaded, could possibly sharpen up the throttle response noticably.
To get the full 60bhp, you either would need GPZ or aftermarket GPZ cams, and or a gas flowed head at least. This is much more expense and finding the last 10bhp might not be worth the cash for the results? If going to those lengths i would consider a Big bore kit, as tuned 600-650cc big bored lumps, have seen over 76bhp at the crank.
tsmith
PostPosted: 09:02 - 19 Dec 2008    Post subject: Reply with quote
if you are considering engine work on the EX500, check out
https://www.enginedynamics.com/kits/kawasaki.shtml
Smooth
PostPosted: 09:17 - 19 Dec 2008    Post subject: Reply with quote
That goes against the ethos of cheaply modifying a bike to reach its full potential.
ps. 10bhp wouldn't make much difference to a litre sports bike, but would be a fairly significant addition to 50bhp.
TDM850
stevo as b4
PostPosted: 09:54 - 19 Dec 2008    Post subject: Reply with quote
True that unless you had a specific reason to tune the ER5 lump significantly or were trying to make the bike competative in a race class etc, then the cost is not justifiable in most cases.
However the cost of say re-building a worn engine, or buying a GPZ engine to transplant, would go some way towards tuning the original motor possibly with a big bore kit, cams and head work etc.
I agree that you probably wouldn't need 10bhp to make the bike feel nicer to ride and more responsive, so some good VFM breathing mods and some time spent on the carburation/dyno setting up, could land you a more responsive bike that is slightly faster, for a reasonable amount of spend.
I used to see a guy riding around near where i live with an ER5 that had motocross wide bars on it, and a short race can fitted. It seemed to go well, and you could hear the popping from the exhaust which sounded Thumbs Up .
Purplepill
PostPosted: 12:44 - 19 Dec 2008    Post subject: Reply with quote
Interesting Thumbs Up didnt realise they sold many tuning parts for this bike.
The last post was made 17 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.48 - MySQL Queries: 16 - Page Size: 142.08 Kb
