apple tango |
apple tango Crazy Courier
teabag |
teabag Renault 5 Driver
Noxious89123 |
Noxious89123 World Chat Champion
Reppyboyo |
Reppyboyo Nearly there...
instigator |
instigator Super Spammer
Noxious89123 |
Posted: 23:21 - 16 Dec 2008 Post subject: |
instigator |
Noxious89123 |
Posted: 23:35 - 16 Dec 2008 Post subject: |
Away with thee! Stop telling nasty lies about my beloved Mr. Honda.
And go fix your broken SRAD ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
MattShill |
MattShill Nitrous Nuisance
apple tango |
Kickstart |
Kickstart The Oracle
Posted: 23:09 - 17 Dec 2008 Post subject: Re: Does your bike ever warm up in this freezing cold mist? |
apple tango - I would doubt it is carb icing as it appears to be happening from cold. With carb icing I would expect it to be OK when started, and OK in low speed riding, and become a problem after running at speed.
Starting it and warming it up for a while would have negligable effect on carb icing, but would help if it is just running lean at idle.
If it is a bit lean or cold then check the thermostat is working OK, and consider blanking part of the radiator off (bodge but might help). Also consider richening the idle mixture up a touch.
apple tango wrote: | I bought a can of Silkolene Pro Boost today. I hope this is the same or similar to the FST stuff. It does say it reduces carb icing on the back. |
Think Pro Boost is just an octane booster.
iooi wrote: | Well the freezing point of petrol is -60, Yes i know that its mixed with very cold moist air. |
Carb icing is nothing to do with freezing petrol. It is moisture in the air freezing in the carb. Cold air going through the carb takes heat from the carb body, as does fuel drawn from the carb, resulting in the carb body being so cold that moisture in the air condensing inside the carb and freezing.
If it gets cold enough then it isn't a problem as the moisture content of the air becomes pretty much non existant.
From memory the ideal temperature for carb icing is between zero and 5 degrees.
I have had carbs covered in frost on the outside (where there is far less airflow) due to the heat taken from them, despite the carb sitting just behind that warm engine.
That said, carb icing is very rare compared to the number of times it is blamed for problems.
Noxious89123 |
ajb |
ajb Crazy Courier
Noxious89123 |
Posted: 23:51 - 17 Dec 2008 Post subject: |
I find that if i put in a full tank of fuel from being nearly empty, the motor has a fair bit of extra kick. Fuel fresh from the pumps is colder than whats been sat in your tank for a while, as it's stored in tanks under the ground, nice and cool.
Colder fuel = Denser, but more to the point, it cools the air that it being sucked in with it. ____________________
cicatrez |
cicatrez Crazy Courier
apple tango |
Posted: 09:54 - 18 Dec 2008 Post subject: |
[quote="Noxious89123
PS: Pro-Boost only has a minor effect on carburettor icing; it is primarily an octane booster. Likewise, Pro-FST
has a minor positive effect on octane rating, but it is not a good idea to use it as an octane booster, because it's a carburettor de-icer![/quote]
Quoted from here;
https://www.silkoleneoil.com/techtip7.htm
So it'll do what you bought it for, it's just that Pro FST would do it better.[/quote]
Cheers ____________________ CBR125 -> Bandit GSF600 '99 -> SV650 02 |
The last post was made 15 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
