yamaha xt 125r lighting problems
jim231187
PostPosted: 20:22 - 07 Jun 2009    Post subject: yamaha xt 125r lighting problems Reply with quote
Hi every1, i've just got my self an xt 125 2005 as a cat c write off. I've done all the repairs but im having a nightmare with the lighting. When the bike is running, the little sidelight in the headlamp works, the rear no plate lamp works and the brake light works. The main headlamp doesnt work, neither does the tail lamp. Also the full beam indicator stays on even if you switch off the main beam but goes off if you remove the front bulb. I've replaced all of the bulbs but this didnt make a blind bit of difference. Please help!!! Thanks.
nowhere.elysium
The Pork Lord
PostPosted: 20:45 - 07 Jun 2009    Post subject: Reply with quote
Have you checked the fuses?
It might also be worth going over the wiring loom with a multimeter, to check for continuity.
jim231187
PostPosted: 21:58 - 07 Jun 2009    Post subject: Reply with quote
Thanks for your reply mate, do you know or know a way where i can find out where the fuses are? i can only see a main fuse by the battery and thats fine.
nowhere.elysium
The Pork Lord
PostPosted: 10:40 - 08 Jun 2009    Post subject: Reply with quote
Well, having found a wiring diagram (here) for an XT250, it looks like there may only be the one fuse, so apologies for getting that wrong.
In which case, I'd start looking for shorted connections. Look for anywhere the wires are in immediate contact with anything else, and check to see that insulation hasn't been worn away: sometimes you'll get bare patches caused by the vibration of the engine.
It may be something that looks totally silly, too: my 125 had a short on the front left indicator, and it was stopping the bike from starting.
Check the condition of the wiring as best you can. If you can't see anything, then get ready to go over it with a multimeter.
I'd also have a look at all available switches and connection points, too, to make sure there's not any corrosion that's playing havoc.
The last post was made 14 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 41.92 Kb
