Author |
Alexio |
Alexio World Chat Champion
Back to top |
Jeansy001 |
Jeansy001 Nova Slayer
Back to top |
Alexio |
Back to top |
Jeansy001 |
Back to top |
Alexio |
Posted: 23:56 - 27 Aug 2009 Post subject: |
Thanks for the advice It's weirdly hard to be objective sometimes when just wanting your bike working how it used to. |
Back to top |
Jeansy001 |
Back to top |
Odie |
Odie World Chat Champion
Posted: 08:39 - 28 Aug 2009 Post subject: Re: Exhaust problem |
Alexio wrote: | Hi. I own a Honda cg 125cc which recently started to sound terrible and lose power so my friend did a compression test on it. It got just 55psi so I was assuming it was a piston ring problem or valve problem etc.
However, I've just discovered two small holes in the exhaust where it connects to the engine, which would explain why it's a bit louder and sounding worse, and even why some power is lost, but would this explain a loss of compression in my cylinder? I'm still concerned there's something wrong with the engine as well, and yes it does have enough oil in it.
Thanks. |
Holes in your exhaust have nothing to do with the commpression in your bores, look at the rings and valves.
Do a wet commpression test, pop a bit of oil in the cylinder and do the test again, if the commpression goes up its rings if it dont its valves.
Odie ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
Back to top |
Alexio |
Back to top |
Noxious89123 |
Noxious89123 World Chat Champion
Back to top |
Alexio |
Posted: 13:31 - 29 Aug 2009 Post subject: |
Well, I still haven't gotten around to diagnosing it further yet seeming as it's still just about hanging on to life. The small exhaust holes are on the manifold and apparently just £10 to fix.
But I hope I'm not potentially doing any further damage to it as I really don't have any more money to fix my piston and or valves when this turns out to inevitably be the problem
Still CG's are tough things, it'll pull through. |
Back to top |
Alexio |
Back to top |
Alexio |
Posted: 14:35 - 09 Sep 2009 Post subject: |
Just a bump on this thread to say my bike is all fixed now
After having my exhaust fixed, everything is suddenly and magically fine. The person that welded my exhaust back to health did another compression test for me and got near 150PSI and told me that when I was doing it I probably wasn't holding the throttle open and therefore doing it completely wrong would have been nice if anyone else I had talked to could have told me that
What I'm the most surprised about is that my bike definitely has more power now. I'll have to wait until I fix the last thing broken on my bike, my speedo, until I know for sure if it's the same as it ever was. Anyway, I'm very, very happy
Now where to find a speedo cable... ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
Back to top |
The last post was made 14 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
