Author |
Aibisi |
Aibisi L Plate Warrior
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Aibisi |
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Posted: 15:27 - 16 Feb 2021 Post subject: |
A quick fuelly search shows your fuel consumption is indeed on the high side. https://www.fuelly.com/motorcycle/honda/cbf500 ____________________ History shows again and again how nature points out the folly of men - BOC |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Aibisi |
Posted: 16:55 - 16 Feb 2021 Post subject: |
Robby wrote: | In that case it is possible there is something amiss inside the carbs - either something blocked with varnish, or something else loose or broken. Unlikely to be a misguided attempt at tuning, because people don't generally bother trying to make a CBF500 go faster.
Make sure the air filter is clear first. I do know from the earlier CB500 that a dirty air filter would really choke them up, as would any kind of mods to the air box. The CB500 used to pick up quite significantly around 6-8k rpm, which I assume was down to some clever matching between airbox and cam. Was a bit flat from 5-6k, but not to the point of feeling broken.
Check air filter. If that is all clean and properly fitted, and no-one comes along with a better idea, I would be getting the carbs off and checking them over for trouble. |
Just checked the air filter, its brand new and clean... was hoping its something this simple because I have no experience with carburetors at all, all my previous bikes were FI.
I have noticed something that might also be helpful in someway to discover what the problem is, if you try to start the bike from cold with the choke fully open it won't really start and if its running and you open it all the way, it just stalls, it does not like full choke at all, probably running too rich?
I found out a curiosity just now ( probably useless and just how an alternator works ) that the front headlight gets slightly brighter with some revs never had this on previous bikes . |
Back to top |
Nobby the Bastard |
Back to top |
Aibisi |
Back to top |
jeffyjeff |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
Aibisi |
Back to top |
Courier265 |
Courier265 World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Posted: 15:56 - 22 Feb 2021 Post subject: |
The only solution is to work through it until you find the problem.
Whilst valve clearances can have a small impact on how it runs, they don't tend to go that far out of spec and are one of those that people just suggest because it's routine servicing that gets ignored, its difficult, and expensive if someone else is doing it. The valves should be in spec, but I doubt they would cause this problem.
I think it's related to fuelling. Logically it should be down to running rich, but logic doesn't always work. An air leak can also cause problems like this, illogically. Good places to look are any vacuum hoses - they fall off, get pinched, get a hole bitten in them. Vacuum ports for carburettor balancing can also be a problem, if the plugs or caps for the ports are loose or missing.
It's even possible that this is an electrical problem, if 6k rpm is a spot where everything is just wrong to make a good spark and you have a bit of corrosion in the system making the job a little harder.
In short, small problems are hard to track down. |
Back to top |
Britabroad |
Britabroad Banned
Posted: 18:52 - 22 Feb 2021 Post subject: |
I hope this helps, l do know that type of problem is not only a pain in the rectum, but quite a worry, especially if you thought you were buying a good 'bike. l'm going with a fuel delivery problem, but, there is a slight possibility it could be the plugs/leads!
https://www.cb500x.com/index.php?topic=8849.0 |
Back to top |
The last post was made 3 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
