Author |
Fat bloke |
Fat bloke Derestricted Danger
Back to top |
A100man |
A100man World Chat Champion
Back to top |
redeem ouzzer |
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
Fat bloke |
Back to top |
Fat bloke |
Back to top |
WD Forte |
Back to top |
A100man |
Back to top |
Fat bloke |
Posted: 14:39 - 18 Feb 2021 Post subject: attachments |
Thanks WD Forte that is exactly what I have. I am a bit of a dinosaur when it comes to computers but every time I try to add a photo I am told that the attachment is too big. Any tips on how to attach photos will be appreciated.
I will carry on trying though.
____________________ You're only supposed to blow the bloody doors off! |
Back to top |
WD Forte |
Posted: 15:02 - 18 Feb 2021 Post subject: |
Not sure how useful that regulator A100man points to would be
as its a solid state dynamo (DC) regulator
which replaces one of these old things
https://www.britishmcparts.com/images/cache/Electrical/Volt_Reg.500.png
What you need is a rectifier and regulator (RR) to rectify the AC to DC then regulate that voltage
to suit the system, 6v or 12V. ____________________ bikers smell of wee |
Back to top |
Fat bloke |
Back to top |
Fat bloke |
Back to top |
Fat bloke |
Back to top |
Fat bloke |
Back to top |
WD Forte |
Posted: 16:52 - 18 Feb 2021 Post subject: |
Back to top |
Fat bloke |
Back to top |
A100man |
Posted: 22:14 - 18 Feb 2021 Post subject: |
Ah yes - good spot. It was listed the rectifier/regulator section so I made a rash assumption without reading the description.. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
Fat bloke |
Back to top |
WD Forte |
Posted: 20:36 - 20 Feb 2021 Post subject: |
I wouldn't say its complicated.
It looks a pretty common system for that age and size of bike.
I reckon that it could be converted/modded in a number of ways
from a simple led upgrade up to a 3 phase 12v DC system using the points
to trigger a 12V CD CDI or TI ignition system.
Output Power will always be limited by the physical size of the magneto,
coils & windings, magnetic flux density and speed etc, so leds would be a good move in any case.
Parking lights could be dispensed with, who uses/needs parking lights?
The existing switch gear could be retained but the wiring modded to suit
the modifications done.
If you want simple get a Mobylette
https://www.bikechatforums.com/viewtopic.php?t=324407
1 coil 1 sodding coil was all I had to play with but got led lights to work on it
in 2018 and they were still working when he dropped in here with it a month or two ago.
I wanted to develop it more but he was keen to go off on it. ____________________ bikers smell of wee |
Back to top |
Fat bloke |
Back to top |
WD Forte |
Posted: 22:37 - 21 Feb 2021 Post subject: |
clue
AC is rectified to DC by a diode
LED means Light Emitting XXXXX?
geddit?
Many leds will work on an AC supply but there's nothing stopping you
fitting a say 10A schottky diode on the yellow lead and going all
LED throughout the bike.
a 5W even 10W* LED bulb wil give out more light than
a 6V 25W bulb but use less than half the power and it really is the simplest option as most older bulbs
have direct one for one led replacements available.
(* I'm talking actual power used in the circuit not the nominal/equivalent values often stated by sellers so best check for this)
for instance check out
https://www.classiccarleds.co.uk/collections/6-volt-collection
and
https://classicandvintagebulbs.com/
for reference ____________________ bikers smell of wee |
Back to top |
The last post was made 3 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
