Ant132 |
Ant132 World Chat Champion
Posted: 20:44 - 30 Nov 2009 Post subject: Will idle, but will not rev up |
Hi all, ive just put a new engine in my Triumph Trident, however, now that its up and running it refuses to rev. It will generally idle fine but will not rev up past about 1750/2000 rpm without cutting out.
Any idea on what to look at?
Thanks, Ant ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
oldbiker |
oldbiker Nitrous Nuisance
Posted: 20:55 - 01 Dec 2009 Post subject: |
Hard to diagnose from so far away,
cutting out through weakness?
I would check for fuel starvation first, Is the fuel line blocked or kinked, tank breather clear?
Then check for carb problems such as crap in the filters or a loose slide needle.
Cutting out due to richness?
Check the chokes are not staying on.
Check that all the jets are secure, has a main jet come loose? ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
The Artist |
The Artist Super Spammer
temeluchus |
Alexio |
Alexio World Chat Champion
Posted: 03:41 - 02 Dec 2009 Post subject: |
Last time this happened to me I just could not figure it out. Idles fine, but dies as soon as you tough the throttle. Then I looked at the fuel gauge and realised I was empty Switched to my reserve tank and all was well. It's just amazing that I got my bike home with no problems and used up exactly the right amount of fuel to empty my tank without it dying.
Anyway, it's sure to be a fuel / carb problem as suggested above. ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
Ant132 |
Posted: 12:57 - 02 Dec 2009 Post subject: |
Thanks for the replies
I had the carbs back off yesterday and found them spotless, cleaned them anyway but didnt find any blocked jets or anything.
I put them back on and made sure the airbox and inlet rubbers were tight and on properly. The fuel lines are all clear and routed OK with no kinks or snags.
It works 'ok' on the choke but seems to rev up very quickly. As in, the slightest bit of choke will make the revs shoot up, but the throttle wont.
Ignition rotor was supplied with the engine. Also, i definately have enough fuel. Im running it on reserve to make sure but ive also tried it on prime - no difference.
As i say ive already cleaned them again but i havent tried it, due to there now being a dodgy wire or something to the solenoid. All im getting is the occasional clicking. But i dont get anything unless i wiggle the wires about. One thing after another..
Thanks all, Ant ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
Alexio |
Posted: 13:25 - 02 Dec 2009 Post subject: |
Could be weird throttle linkage, or a weird electrical problem them where every time the throttle is opened, it shorts two wires somewhere and it all just dies That would be unlucky indeed. ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
Ant132 |
Posted: 14:35 - 02 Dec 2009 Post subject: |
Right, sorted that dodgy wire. Turns over now.
Bad news is that the carb job yesterday hasnt done alot of good, the good news is that it seems to rev now but the bad news is it wont idle so well and now when you rev it the revs stick on. Say, you rev to 3-4 k and loosen the throttle - the revs stay there.
Theres quite a bit of white smoke from the exhausts too, and it also leaks fuel on prime . I reckon the clean up is not enough, i think i may need actual new float needles and not just cleaned ones. What you think?
If not, next step electrics then ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
oldbiker |
Posted: 20:52 - 02 Dec 2009 Post subject: |
leaking fuel on prime?
could be crap in the float valve,
or the float needle could be worn possible if the bike is say 8 or more years old.
it`s also possible that you may have altered the float height.
carb sticking?
Sounds like the carb cable has got twisted or caught up.
(I`m sure you will get there in the end) ____________________ It`s all powerfull white mans magic
The last post was made 14 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
