stoorty |
stoorty L Plate Warrior
Posted: 12:58 - 18 Mar 2010 Post subject: GSXR 600 SRAD wont start. |
Hello there,
Im looking for some help with a problem with my bike. It started recently, where i cant get it too start anymore. I took it out one day to work, and when i got home i put the side stand down while it was still in gear which caused it to kill the engine, nothing new there. However, when i put it back into neutral and went to start the bike again i got nothing.
Usually when i press the fob for the alarm it will disarm and then i turn the key and the fuel pump usually kicks in, but now when i do it, im not getting the fuel pump coming to life
I've tried the usual suspects like fuses and kill switches, and i even tried to check out some of the electrics, but they seemed to check out. Bought a brand new battery, removed the alarm/immobiliser but it still wont come to life. I even tried running power straight to the starter and the fuel pump and they both want to go.
Now as this is my first bike, im not too clued up, but i would like to think i aint as daft as a brick either lol. Is there anything anyone can suggest for me to try as its really making me lose interest in my bike, when all i wanna do is get out and play on it!!
Thanks,
James
P.S. Its a 00 model, 600, carb'd, and broke |
Tim.. |
Tim.. World Chat Champion
stoorty |
Tim.. |
stoorty |
dibbster |
dibbster Nearly there...
Posted: 14:24 - 18 Mar 2010 Post subject: |
Do you get the neutral light coming on when you switch it on?
The side stand switch doesnt control the fuel pump priming it is the bike been in neutral. It sounds like the bike is not recognising been in neutral, I would investigate that. ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
stoorty |
Alex A |
Alex A World Chat Champion
Liam_ |
Liam_ World Chat Champion
Alex A |
stoorty |
Posted: 17:16 - 18 Mar 2010 Post subject: |
Sorry for the confusion, both the starter motor and the fuel pump will prime if connected to the battery directly.
And i have disconnected the alarm/immobiliser unit, and jumpered the correct pins to bypass the immobiliser but the bike still wont prime |
lonner |
lonner Spanner Monkey
Posted: 19:40 - 18 Mar 2010 Post subject: |
have you checked the fuel pump relay
if you can get the pump to run off the battery then check the relay circuit as it may be faulty or have a dirty contact.
hth |
stoorty |
Gazdaman |
Gazdaman I did a trackday!!!
stoorty |
Gazdaman |
The last post was made 14 years, 41 days ago. Instead of replying here, would creating a new thread be more useful? |
