The Artist |
The Artist Super Spammer
hmmmnz |
hmmmnz Super Spammer
Posted: 12:38 - 09 May 2010 Post subject: |
right,
1,
set the bike to tdc.
to do this you need to remove the little cap on the side of the crank case, and the one directly below it (to turn the crank)
turn the crank over by hand untill in the top hole you see the timing mark
it will be marked with a " T| " the | will match up with a little notch in the top of the hole, you bike is now at top dead center,
2.
setting the cam in the right position.
get the cam and place it in the head with the lobes facing down (if its a rocker arm system) and the 2 - - marks on the cam sprocket running parallel to the angle of the head or the line of the holder that the cam sits in,
put the chain in place and release the tensionor
that bottom mark T| and the 2 - - marks should be still in the same place.
if the cam moved when you released the tensionor, the slip it back a tooth and try again,
once you are confident every thing is lined up, put the cam caps in place and bolt up the head,
then turn the bike over by hand from the crank, it should hit anything.
when you have done that, check the clearances on the rocker arms and adjust them.
and you are good to go,
have fun ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
hmmmnz |
smegballs |
smegballs World Chat Champion
Posted: 16:44 - 09 May 2010 Post subject: |
hmmmnz wrote: | i have a gn125 manual in french, (where the images are from)
and a rv125 (which is a 2 stroke so not really any use to you)
the gn manual is
here |
I think he probably meant the new "van-van" (I'm assuming it still uses the RV model name) which is a four stroke, wouldn't suprise me if suzuki used the same basic 4t 125 engine in all 3 bikes. |
The Artist |
hmmmnz |
The Artist |
hmmmnz |
molex |
molex Renault 5 Driver
There is a gap of 4 years, 162 days between these two posts... |
unitynotsocri... |
unitynotsocri... Banned
Posted: 16:47 - 18 Oct 2014 Post subject: |
oldies but goldies ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
N cee thirty |
N cee thirty Banned
The Artist |
unitynotsocri... |
Posted: 11:52 - 19 Oct 2014 Post subject: |
Soz for redigging an old post, I have a few probs and don't know how to link things for the lad with the gs. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
The last post was made 9 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
