dudejb46 |
dudejb46 Nova Slayer
Posted: 22:25 - 11 Jun 2010 Post subject: Headlight bulb keeps blowing please help me its expensive :( |
hi guys i have now bought a yamaha dtr 125 1998
https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs358.snc3/29524_1486489407391_1388581737_1279488_7666709_n.jpg
now to my anger it keeps blowing bulbs i am using this bulb
https://www.hq-auto-lighting.co.uk/images/H4--HQ-Xenon-Bulbs.jpg
and everytime i ride the bike from idle as the revs get higher it dims more and more and then at around 10 000 rpm it goes pop litterly cracks sometimes other times just the filament goes.
i did have the origianl bulbs in but it went and im unsure weather this was wear and tear as it came with the bike or if it was the same problem.
now i have no clue what it is weather its in the loom or battery is wrong :S
another thing to bear in mind when diagnosing it not sure if its related but when the headlight is on and working if i apply brake or indicators it dims for the brake and flashes with the idicators.
if anyone can solve this you will be saving me so much money ill be so so happy please please help ____________________ 2002 zip 2002 bandit project 2004 fzs1000 2009 883r |
Paxovasa |
Paxovasa World Chat Champion
dudejb46 |
doggone |
doggone World Chat Champion
dudejb46 |
Vincent |
Vincent Banned
dudejb46 |
Kickstart |
Kickstart The Oracle
dudejb46 |
Vincent |
Vincent Banned
27cows |
27cows World Chat Champion
Raffles |
Raffles World Chat Champion
Pete. |
Pete. Super Spammer
Robby |
Robby Dirty Old Man
Raffles |
dudejb46 |
Raffles |
dudejb46 |
27cows |
Pete. |
Pete. Super Spammer
Posted: 17:20 - 12 Jun 2010 Post subject: |
I still don't understand. With the bulb earth disconnected, using main beam nothing should happen except the main beam warning light would show as there's no return-path after that, and using dip would put +12v(ish) across the dip, main and main beam warning light filaments in series so they would all show dimly.
Why does it dim as revs rise, and why would it blow the bulb with the earth off? There's something else going on IMO. ____________________ a.k.a 'Geri'
dudejb46 |
finpos |
finpos World Chat Champion
27cows |
Posted: 17:51 - 12 Jun 2010 Post subject: |
dudejb46 wrote: | 27cows wrote: | DO NOT use the lights until the dangling black wire is connected. There should be a connector nearby for it to plug into. Or at least a black wire missing its connector etc. It's possible you may have to bodge that black wire into the system. But without it connected, the h/l bulbs will blow every time the revs rise. |
shit i did use them again with another bulb....and it went again, now today i bought a new bulb and it wont even light up i have since tried 3 other bulbs, none worked, all other lights work on the bike though?!?
you say bodge it in, where too?
thank you |
Photos would be helpful, get some idea if the wiring looks bodged or damaged.
That dangling wire should be connected - you need to find the other end, the wire it should be joined to but isn't. That would be the first port of call.
But as others have said, the dimming issue is odd. It's something I've had happen on bikes myself and usually indicates a short somewhere. You need to carefully go over the wiring, making sure the connectors (particularly the various earth wires) are clean and that there's no damage, chafed wires etc anywhere. Keep putting new bulbs in is completely pointless because they'll just blow until the issue is sorted. ____________________ The RXS100: vehicle of choice for Chuck Norris |
Pete. |
Pete. Super Spammer
Posted: 18:07 - 12 Jun 2010 Post subject: |
There are only three things that I can think of that will cause a bulb to blow prematurely:
1. Vibration
2. Over-volting
3. Intermittant connection.
Vibration is common on small bike headlights - the vibrations cause the filaments to shake until they fail.
Over-volting is almost always caused by a failed reg/rectifier. Most all other failiures of the charging system cause low-voltage. On small bikes a duff battery can cause it too.
An intermittant connection causing the filament to heat up & cool many times will shorten it's lifespan. ____________________ a.k.a 'Geri'
delvey91 |
delvey91 Crazy Courier
The last post was made 13 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
