dextersaurus |
dextersaurus World Chat Champion
Posted: 10:07 - 03 Sep 2010 Post subject: Indicators not working. |
Hi.
So that's the GPZ500s 99.999% finished, i'm just having some problems with the indicators.
I noticed they weren't working before and i put it down to the stock ones not working, but i replaced with some mini ones, and now they still aren't working.
I don't have a multimeter though i will buy one if needed, just want to get this sorted out.
I checked the fuse, and it's fine, and all the connections are good.
I don't have a manual for the bike so i'm not too sure where the indicator relay is, or how to check it.
Dunc ____________________ 2002 RSV Mille | 2003 955i Tiger | 1998 CBR900RR Streetfighter | Fazer 600 hardtail chop
I was MrDunkable in a previous life. Then questioned why I was the one being dunked... |
pinkyfloyd |
pinkyfloyd Super Spammer
Posted: 10:12 - 03 Sep 2010 Post subject: |
My first thought would be to check the relay flasher unit thingy. Not very technical explination I know but now and then on my bike the connectors come lose from the relay flasher and a quick push sorts it out.
If the unit is broken completly it should be easy to get a replacment
https://www.bitzforbikes.co.uk/Flasher_Relay-ref-10303-6720-182.html
Edit. check under the pillion seat for the relay. Lots of bikes have them situated there. ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
The Artist |
The Artist Super Spammer
dextersaurus |
Posted: 10:21 - 03 Sep 2010 Post subject: |
Checked everything, apart from the flasher relay, as i have no idea where it is!
when i press the switch on the switchgear to the left or right, nothing happens AT ALL.
the lights on the clocks don't flash, and the indicators do nothing.
no clicking or anything.
This is with the engine running.
Anyone tell me where the relay is?
Kickstart |
Kickstart The Oracle
Posted: 10:40 - 03 Sep 2010 Post subject: |
Not got a manual for the later GPZ500, and the early manual isn't really helpful about where the relay is. However on the early ones (and hopefully the later ones) the wire from the relay to the switchgear is orange and is the only orange wire on the wiring diagram. Hence examine anything that looks like a relay for an orange wire going to it.
truslack |
truslack World Chat Champion
N cee thirty |
N cee thirty Banned
rob_scott92 |
rob_scott92 Could Be A Chat Bot
Posted: 15:28 - 03 Sep 2010 Post subject: |
If absolutely nothing is happening when you flick the switch then i'd say the switch could be all gummed up inside. Try taking it apart and check theres good connections when you move the switch. And like rob yarr said, give it a blast with WD40 to make sure.
I had a similar thing when my rear brake light stopped working on the Gs, took the switch apart and it was all green and corroded inside so it just wasn't making a connection. I used some light-ish grade emery paper which i had lying around to clean it up, sprayed with WD and jobs a good'un
Does that switchgear operate anything else on the bike (Ie. horn???) If so, then it probably wont be a bad earth in that switch causing the problem as long as the horn is working ok.
Welcome to the world of electrics
Have fun ____________________ First bike: 1982 Suzuki Gs 125 'The beast MK1' > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p |
molex |
molex Renault 5 Driver
truslack |
molex |
pits |
pits World Chat Champion
dextersaurus |
The last post was made 13 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
