1989 Kawasaki KX125 won't start - mega headscratcher.
Gazdaman
I did a trackday!!!
PostPosted: 14:33 - 09 Jan 2011    Post subject: 1989 Kawasaki KX125 won't start - mega headscratcher. Reply with quote
So I recently swapped this bike, and it came back because it randomly won't start.
I've had it for about 2 years, completely stripped it down and rebuilt it, it has been running absolutely fine.
So the guy says that he start it, pulled away, to the near top of first gear, about to change into second and it died. Instantly died, and rolled to a stop, no spluttering etc.
Today I've:
-Compression check: 120psi ~8.5:1 as it should be.
-Carb cleaned, idle and main jet both clear
-Fuel tap clear and working
-Spark nice and strong
-Reed valves in tact and seated properly
-Air filter clean
-Power valve appears free
-Exhaust taken off and checked for blockages (none).
I'm completely stumped, it should start! But it doesn't. It just doesn't seem to fire. I've even tried a nice big bump start, and it turns over absolutely fine, and kicks over fine. Just doesn't fire at all.
Good compression must rule out any major piston or barrel failure, good spark must rule out poor electrical connections on coil, pickup, HT lead etc.
Fuel is clearly getting into the carb, the jets are clear, no crap in the float bowl, I can smell fuel in the exhaust and out of the plug hole if I kick it over with the plug out.
All I can see it really leaving is timing. I did pop the generator cover off, and everything looks ok in there. But I suppose it could have sheared the woodruff key and spun on the crank or something.
Any input or things I could try would be very much appreciated.
Gaz
devojunior
PostPosted: 14:58 - 09 Jan 2011    Post subject: Reply with quote
sounds weird pal although you say your getting a strong spark i would try a new plug for the sake of a couple of quid and a 1 minute job,
when you try start it without any luck what colour is the plug and is it wet if its wet with fuel then try putting th eplug in the oven or heat up really well with a blow lamp ect cant think what elso to try,.
good look and let us know how you get on.
Gazdaman
I did a trackday!!!
PostPosted: 16:25 - 09 Jan 2011    Post subject: Reply with quote
Yeah, new plug is my next purchase just for the sake of ruling it out. I've never heard of a plug sparking outside of the cylinder, but not inside though.
And then cooking it was my next try after that.
When I take it out it's wet with fuel, so I know it's getting through.
I'll check the timing after that I guess, but the generator seems to be tight on the crank, so I'm not too hopeful it's that (although it would explain everything).
The old ritual, compression fuel and spark. This bastard has all 3 and still won't go.
Gaz
PostPosted: 16:46 - 09 Jan 2011    Post subject: Re: 1989 Kawasaki KX125 won't start - mega headscratcher. Reply with quote
That does sounds electrical.
Check around the HT lead when it's plugged in to make sure there's no arcing.
If you can whip the head off fairly easily, I'd be tempted to try the spark plug screwed into the head to make sure there's not something dodgy going on with the HT lead when it's plugged in.
If you spin it over slowish, you might be able to get an idea if it's sparking at around the right point
I presume the carb definitely had fuel in (ie stuff spilled out when you opened it etc) and the float was moving freely?
Gazdaman
I did a trackday!!!
PostPosted: 17:25 - 09 Jan 2011    Post subject: Reply with quote
Yeah, float was moving fine, and the float bowl was full of fuel that spilt all over my hand when I spun it round to clean it out.
I am starting to think electrical, either no spark, or timing wrong. That would fit.
Gaz
mad4it028
PostPosted: 17:37 - 09 Jan 2011    Post subject: Reply with quote
ha i had that happen on my old kx 250 the stator plate had come loose and turned simple fix if its the same
Gazdaman
I did a trackday!!!
PostPosted: 18:19 - 09 Jan 2011    Post subject: Reply with quote
Good suggestion. I'm thinking more and more that I need to whip the generator off.
IIRC the stator can only spin a few degrees on elongated holes, so was the timing just mega-retarded/advanced or had it come completely loose and moved loads?
That's the order of play tomorrow I think, Halfords for a new spark plug, gearbox oil and coolant. Try the new spark plug, when that fails to fix it, generator off, check timing.
If that doesn't fix it. I'm back to being stumped.
Gaz
mad4it028
PostPosted: 18:29 - 09 Jan 2011    Post subject: Reply with quote
mine was just mega loose screw had fallen out i managed to refit and tighten with lock tight without removing the fly wheel
bikersupermot...
PostPosted: 20:25 - 09 Jan 2011    Post subject: Reply with quote
Gaz
so the fuel is gettin in but its not igniting -
quickest and cheapest thing to try is new plug (did this on my gilera that wudnt start and she started 1st pop) iv read that under compression conditions if there is a fault in the insulation it can spark inside the plug and not in the tip.
then id say timing - its got fuel and a spark - the only thing left is the spark isnt at the right time.
good luck an let us know how u get on with it. Thumbs Up
tinybikes
Gazdaman
I did a trackday!!!
PostPosted: 12:24 - 10 Jan 2011    Post subject: Reply with quote
For those of you that guessed timing, give yourselves a pat on the back, the woodruff key had sheared allowing the generator to play havoc with itself.
Just need to get a new one and hope that's the only problem.
Gaz
bikersupermot...
PostPosted: 01:54 - 11 Jan 2011    Post subject: Reply with quote
great uv found the prob! ... btw im liking your list of owned bikes! Thumbs Up
tinybikes
Gazdaman
I did a trackday!!!
PostPosted: 19:44 - 11 Jan 2011    Post subject: Reply with quote
Thanks, that isn't my owned bikes though, that's my current bikes.
My list of current and past bikes are here: https://www.gaz-racing.co.uk/content.php?page=viewvehicle.php&vehtype=all
Just waiting for my new woodruff key to arrive, £2.44 off eBay (posted). Hopefully it'll go after that.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 15:36 - 13 Jan 2011    Post subject: Reply with quote
Fitted the new woodruff key today, popped the generator back on.
Kicked it over and it burst into life on the first kick.
Excellent!
The guy came and collected it within about 3 hours of me telling him it was fixed, a tad excited he was.
All's well that ends well.
Gaz
The last post was made 14 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 85.73 Kb
