Iveco daily rear brake caliper diagram needed
Stalk
PostPosted: 16:23 - 20 Feb 2011    Post subject: Iveco daily rear brake caliper diagram needed Reply with quote
Hello,
Did not want to put this in workshop as I was not sure if that was OK.
I have a 2001 Iveco daily 35s11 and am looking for an exploded view of the rear brake caliper as the handbrake will go on but not come off. It looks as though the mechanisam has sized where it goes through the body of the caliper and I thought it would be a good idea to study a drawing before I decide if I will attempt a repair or just replace. Repairing will save me about £150, but as the van with all the bits in it is just over 3 tonnes I am a bit hesitant to go in blind and start bodging. Have just spent 2 hours trawling the net with no luck, but I can get a cd manual on ebay quite cheap.
Maybe I am being a bit tight?
Thanks in advance
Stalk
andyscooter
PostPosted: 19:09 - 20 Feb 2011    Post subject: Reply with quote
can get one but wont be till 7 tomorrow night
dodgydog
PostPosted: 21:26 - 20 Feb 2011    Post subject: Reply with quote
Is it the same Brembo caliper they use on Sprinters 06 on?
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Raffles
PostPosted: 21:49 - 20 Feb 2011    Post subject: Reply with quote
I run a small fleet of Iveco Dailys and the rear calipers are notoriously troublesome. Carrying out your own repairs isn't feasible or cost effective.
I seem to recall paying around 80-100 pounds to a company in the West Midlands for an exchange recon unit last year.
I now carry a spare pair of calipers as I can not afford to have any of my vehicles laid up.
Faldo
PostPosted: 23:43 - 20 Feb 2011    Post subject: Re: Iveco daily rear brake caliper diagram needed Reply with quote
Stalk wrote:
Hello,
Thanks in advance
Stalk
Not got an exploded diagram, best I can do is this:
https://img137.imageshack.us/img137/6508/3535289.png
They are a very common problem. If you decide to order one make sure you specify that it's a single wheel rear axle as the twin wheel axle calipers are different. If it helps, Budweg do a caliper service kit, but if it is indeed the handbrake mech that's buggered you probably will need a full replacement caliper.
Dog
'06 on Sprinter uses Bosch rear calipers (Brembo at the front).
Current: ZZR1400
Spooky_b329
PostPosted: 20:59 - 01 Mar 2011    Post subject: Reply with quote
Hi, just registered so I can reply to this thread...
The workshop manuals are available for free from https://www.ivecoforums.com. You just need to register and then download the manuals as a PDF. Hope this helps.
Stalk
PostPosted: 00:13 - 02 Mar 2011    Post subject: Reply with quote
Thank you Spooky. Downloading now.
Spooky_b329
PostPosted: 08:05 - 17 Apr 2011    Post subject: Reply with quote
I've got exactly the same problem now...was searching for replacement calipers and came across this thread again Smile
Noticing your rear wheel has smoke pouring off it whilst filling up with diesel is a little worrying Smile
Raffles
PostPosted: 11:55 - 17 Apr 2011    Post subject: Reply with quote
If you go back to The Iveco Forum that you mentioned in your earlier post then you will find a post there that offers a possible solution to your problem.
All the best to you and do please let us know if this solution works.
The last post was made 13 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 16 - Page Size: 62.83 Kb
