Yamaha FZS600 cam chain rattle - rebuild!
scottyboyfzs6...
PostPosted: 19:37 - 16 Mar 2011    Post subject: Yamaha FZS600 cam chain rattle - rebuild! Reply with quote
First post so bear with me!
So the fazer was suffering from a common cam chain rattle, took it to the garage and sent away with advice to "rev it up a bit n it'll quieten down".
Be warned, what actually happened was the cam chain came off on the dual carriageway! So now im faced with a engine strip and rebuild. Today I took the panels, battery, carbs, distributor/coolant pump bracket, cam chain tensioner and cam cover off. No signs of any damage on top but the cam chain is stuck...will take the head off tomorrow and work my way down to the crankshaft to find the culprit. More to follow!
0l0dom0l0
PostPosted: 00:34 - 17 Mar 2011    Post subject: Reply with quote
Good luck.
I did the top end on mine and the thread can be detailed here:
https://www.bikechatforums.com/viewtopic.php?t=207665&highlight=fazer+oil+leak
Nice engines to work on actually, the top end was pretty easy to do without to many problems. Only real major issue was setting the timing, but neither me or my dad had done it before and we weren't going to get it wrong Very Happy.
Pics, and keep us posted!
garth
PostPosted: 06:57 - 17 Mar 2011    Post subject: Reply with quote
Mine rattles at very cold temperatures, but goes after about 1 minute. Doesn't do it when warm, I'm not overly worried.
scottyboyfzs6...
PostPosted: 11:22 - 17 Mar 2011    Post subject: Reply with quote
Garth, this was a constant rattle from start up to revving. Got progressively worse then SNAP! I would advise anyone to trust their instincts and if it sounds bad it probably is!
Pics to follow this evening.
scottyboyfzs6...
PostPosted: 21:40 - 18 Mar 2011    Post subject: Reply with quote
Well after stripping the head and block off I can say that it is definitely f*$ked. Piston 2 (sitting on the bike L to R) was stuck in the barrel whilst the rest turned over. Con rod has snapped taking off a chunk of the barrel wall as well Sad guna be surfing eBay for parts i reckon... more pics to follow as i attempt a repair!
https://s1205.photobucket.com/albums/bb427/scottyboyfzs600/?action=view¤t=IMG_0145.jpg
head off
https://s1205.photobucket.com/albums/bb427/scottyboyfzs600/?action=view¤t=IMG_0155.jpg
underside of the head with damaged looking valves
https://s1205.photobucket.com/albums/bb427/scottyboyfzs600/?action=view¤t=IMG_0164.jpg
block off piston 2 missing...
https://s1205.photobucket.com/albums/bb427/scottyboyfzs600/?action=view¤t=IMG_0162.jpg
...there it is! stuck in the barrel
scottyboyfzs6...
PostPosted: 23:49 - 18 Mar 2011    Post subject: Reply with quote
cant get the img code to work so here are the links:
https://i1205.photobucket.com/albums/bb427/scottyboyfzs600/IMG_0145.jpg
head off.
https://i1205.photobucket.com/albums/bb427/scottyboyfzs600/IMG_0155.jpg
valves
https://i1205.photobucket.com/albums/bb427/scottyboyfzs600/IMG_0164.jpg
https://i1205.photobucket.com/albums/bb427/scottyboyfzs600/IMG_0162.jpg
broken con rod
scottyboyfzs6...
PostPosted: 11:16 - 19 Mar 2011    Post subject: Reply with quote
would there be any damage to the crankshaft? can it be bent?
mrr1
PostPosted: 21:26 - 13 Apr 2011    Post subject: Reply with quote
scottyboy - how you getting on with this job?
Its stories like this that make me struggle to not worry about the squeaks, rattles and rasps my 30k fazer makes whenever I jump on it. Thing is I've now got a 1989 er250 hack that makes me realise how wonderfully smooth and modern the old fazer is.....
TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis.
The last post was made 14 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 72.85 Kb
