Er5 vs gpz500
si1986
PostPosted: 17:33 - 16 Apr 2011    Post subject: Er5 vs gpz500 Reply with quote
Hi I have an er5 engine that is in pretty good condition but I want to make it the same as a gpz500 I also have an older gpz500 engine that I would like to use and a donor. I want to make the er5 engine the same as a gpz engine I know the cams are different and also the comp ratio is different apparently this is down to either piston height or con rod length anyone know any more info on this?. Does anyone know any other differences between the two?
Moo.
PostPosted: 18:11 - 16 Apr 2011    Post subject: Reply with quote
Best bet would be too get the manuals and compare numbers, i'm pretty sure the er5 is a de-tuned gpz Laughing sorry im no more help..
A2 Passed 18/6/10
si1986
PostPosted: 18:43 - 16 Apr 2011    Post subject: Reply with quote
Yeh it is or the gpz uses a tune er5 engine Laughing
crowe
PostPosted: 18:50 - 16 Apr 2011    Post subject: Reply with quote
Si1986,
Sign up here and ask. a Wealth of knowledge Smile
https://www.bikersoracle.com/er5/forum/index.php
Crowe Thumbs Up
Kawasaki ER-5
Asimo
PostPosted: 18:51 - 16 Apr 2011    Post subject: Reply with quote
Provided theres nothing majorly wrong with the gpz engine, why not use that instead?
To do what you want, you'd need to swap the cams, the carbs and airbox, probably the cdi as well and some other stuff I don't know about Very Happy
c_dug
PostPosted: 19:00 - 16 Apr 2011    Post subject: Reply with quote
Agree with the above, I would have thought swapping the engines was a better bet than fiddling with the internals.
si1986
PostPosted: 19:10 - 16 Apr 2011    Post subject: Reply with quote
I want to use the er engine because it's in far better condition the gpz lump is older and done more miles so if all I have to do is swap a few parts then it makes sense to do it. I'm running the er engine on a gpz cdi anyway.
So...
So far we have established...
Cams
Carb tunin
Anyone know anything about con rod differences?
PostPosted: 19:44 - 16 Apr 2011    Post subject: Reply with quote
Without checking part numbers I would be surprised if they swapped the con rods to adjust compression rather than just changing the pistons and / or head. Doing it using shorter rods would probably give a lousy combustion chamber shape. However con rod length is used to affect other things to do with the power characteristics (ie, different length of rod changes the angle of the rod onto the crank relative to the pistons position down the bore).
Personal guess would be cams, pistons, carbs and ignition.
fatpies
PostPosted: 19:59 - 16 Apr 2011    Post subject: Reply with quote
I remember searching about the GPZ and I remember an old thread by Stinkwheel. He transplanted an ER5 engine into a GPZ I don't think it worked.
si1986
PostPosted: 20:23 - 16 Apr 2011    Post subject: Reply with quote
The engines in a quad bike and runs but I need the gpz engine as I need to install a stage 3 dynojet kit because I need to run pods. They don't do a stage 3 kit for a er5 so if I can change the er5 into a gpz the all is good!
si1986
PostPosted: 07:58 - 18 Apr 2011    Post subject: Reply with quote
Could the comp ratio difference just come from the difference in the cam valves opening later etc? I may have that completely wrong?
PostPosted: 08:15 - 18 Apr 2011    Post subject: Reply with quote
Effective compression could but not a quoted static compression.
si1986
PostPosted: 10:32 - 18 Apr 2011    Post subject: Reply with quote
Ok this is strange then apparently the head, rods and pistons are identical. I'll get a manual soon and look into it further.
PostPosted: 10:54 - 18 Apr 2011    Post subject: Reply with quote
Haven't got any figures to hand for the compression ratios. What are they?
Looking in a service book the compression (ie, when cranking over - so affected by valve timing, etc) is actually a bit lower on the GPZ and varies between the earlier and late shape models.
si1986
PostPosted: 12:55 - 18 Apr 2011    Post subject: Reply with quote
I can't remember off hand think the ER is 9.8:1 and the GPZ is 10.8:1. I'm not overly worried about the extra 10hp its just I have no room in the quad for the airbox so I am goin to have to use pod filters so I have a stage 3 dynojet kit but it's for the GPZ not the ER and they don't do a stage 3 for the ER so I'm trying to make mine as close to a GPZ as possible.
The last post was made 14 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 16 - Page Size: 89.42 Kb
