Recluso |
Recluso Brolly Dolly
Easter Bunny |
Easter Bunny World Chat Champion
Posted: 23:12 - 28 Apr 2011 Post subject: |
You do know you're not allowed on the motorway on a provisional licence?
If a copper sees L-plates on the motorway, he'll pull you for sure Then he can choose between MW10 (Disobeying special motorway regulations) which gives you three points or LC20 (driving otherwise than in accordance with a licence) which gives 3-6 points.
If you take the L-plates off and are caught. It's 3 points per missing L-plate PLUS the above and you could be looking at a ban.
In answer to the original question. I would, and have taken a 125 on the motorway. In fact, I've taken a C90 on the motorway. I also take my Enfield on the motorway and it is slower than a 125. I do however have a full licence so I'm allowed to. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Rogerborg |
Rogerborg nimbA
Posted: 00:03 - 29 Apr 2011 Post subject: |
I've taken my 125 and (slowwww) 250 onto motorways and 70mph dual carriageways, and didn't enjoy it at all. Ragging your bike to its utmost just to keep up with the slowest traffic gives you very few options if anything goes screwy.
Your indicated 60-65 is more like an actual 56-61, the same speed as an artic. That's fine until you get involved in a game of artic leapfrog, and you get hidden in the middle. Drivers generally do not check the left lane just after overtaking a large vehicle, so you're very vulnerable.
So no, I wouldn't recommend it. If you do it, I'd suggest that you adopt a "C90" mindset, don't try to keep up, and give other traffic every encouragement to overtake you so that get behind them and remain visible.
But then as soon as you're legal to go on the motorway, you'll be able to get a bigger bike anyway. A fast 250 capable of an actual 75 or 80mph with a little in reserve is the minimum bike I'd want to take on a motorway. ____________________ Biking is 1/20th as dangerous as horse riding.
Glenben92 |
Glenben92 Nearly there...
Posted: 00:08 - 29 Apr 2011 Post subject: |
Speed wise, it's easily achievable. Distance is the problem that I find. I have quite a high level of mechanical sympathy and topping out or almost topping out my bike for long periods of time is not something i'm at ALL comfortable with. I always try to avoid using 60/70 roads if possible but won't go TOO far out of my way to do so. ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 00:38 - 29 Apr 2011 Post subject: |
Depends what motorway!
I live in Nuneaton.... about three miles from M6 J3, just off the M42, just off the M69, and not far from M1 or M5...
M6.... heading north.... no problem!
Nothing bludy moves more than 45mph in daylight!
M69... no problem..... virtually empty, apart from rush hours, and even then, only really a niggle when you hit the Leicetser M1 interchange!
M42... no bludy chance! That ones just lairy!
As others have said, motorways are duel carriageways where 'special rules' apply, hence no L-Plates. Otherwise, if you'd ride down a duel carriageway, why not a motorway?
Depends on the bike to some degree, as well. I used to do Coventry Stafford up the M6 a fair bit, when I had my AR... but that was 20 years ago! Spaghetti is a little interesting at more than 50, due to it being all elevated sections, and its rather windy! and the AR125 was very light! 105Kg from memory, lightest of the sports 125's and 10Kg less than a CG!
End of the day, its swings and roundabouts, and what your most comfortable with. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Recluso |
Posted: 09:43 - 29 Apr 2011 Post subject: |
I don't see why people have difficulty. Riding at 50mph in the left hand lane is not a problem. Motorways are designed to allow for overtaking. The only issue I have is that it's boring. It can be a bit tricky moving across into lane 3 where a four lane motorway splits but I've found wagon drivers to be very courteous in this respect and they will flash you out.
What'll surprise you is how many vehicles you overtake yourself. Heavily laden lo-loaders and old shape transit vans with a palette of concrete blocks in the back will not be doing much more than 50. Military vehicles are usuaually doing 50mph on the nose too.
I've never had a problem with tailgating or people cutting past halfway between lanes when in the left lane. It's reps and boy racers who do that sort of stuff and it exclusively happens between lanes 2 and 3.
Best one is a full petrol tanker. These usually sit at nearly bang-on 60. You can slipstream one on a 125 for miles and miles with the throttle barely half open. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Nai |
Nai World Chat Champion
Posted: 10:14 - 29 Apr 2011 Post subject: |
I do the A40 every day past Northolt (NSL stretch, 3 lanes either side) and I have never had an issue. Helps having a bike that can make 70, even if that means raggin the teets off it. But the left lane seems to move between 50-60 at its fastest anyway. Even off rush hour times.
Do I guess thats a yes from me. |
Livefast123 |
Livefast123 Nearly there...
Posted: 10:55 - 29 Apr 2011 Post subject: |
I take it your referring to the stretch of M5 around Junction 19. It is pretty flat for miles south from there apart from Tickenham Hill and Naish Hill so the 125 should do it without an issue when you get your licence
Plenty of clued up traffic cops around those area's and all it takes is a driving licence check ____________________ Current ride - Yamaha MT-07 |
locked |
locked Could Be A Chat Bot
N cee thirty |
N cee thirty Banned
Recluso |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 15:21 - 29 Apr 2011 Post subject: |
rob yarrr wrote: | i'm next to the m6,but wouldn't fancy it on the cg in the slow lane as the massive grooves left from the lorries would be a reet pain in the anus |
Most of the M6 is a bit rectum twitching on a bike.
Elevated sections from about J5 to J9 are....
OK.... VF-Thou... MACK-ruddy-TRUCK of a motorcycle. 600Lb of metal, before you through your leg over it, not a bike that 'lacks' stability...
M6?
VERY twitchy on those windswept sections, but the worst bit is the truck slots and the fact that the road is like a roller coaster... with square wheels!
The sections, individually are flat, but gong up and down the different levels, they are jointed, and its not just up and down, but left and right, as they are tilted into the curves... and THEN you find the trucking slots!
Honestly, first time I did that section on that bike, I thought THIS is going to be a breeze... BIG stable bike, soft suspension.... should be confy as an armchair.....
Approaching Spahgetti, I was bounced from the overtaking lane, progressively, slab by bludy slab into the inside, and was riding teh 'burm' of them truck slots, to make it round.......
Mind.... it was late at night.....and I was doing a 'little' over the speed limit!
Defintite twitch time!
With others though on them being boring.... tend to avoid unless I just need to get miles covered, or want an 'easy' ride at the end of the day or something.
Do agree with Stink on the slip stream though..... CAN be rather sphincter twitching, because you have to get in close on the tail, and it helps to do a weave and let the trucker see you in the mirrors from time to time.... have had one to spot me and give me thumbs up, and do things like double dip the brake lights to give me extra warning they are slowing and stuff, but was a godsend in my student days.... used to be able to do Manchester Plymouth on a tank full in the AR holding 56 behind a tautliner! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Recluso |
Posted: 15:49 - 29 Apr 2011 Post subject: |
Okay, now I must admit I've gotten a bit confused by the talk of slipstreaming and weaving. I'm only fairly new to this don't forget
But it's still good to hear that people think that it will be a viable option to jump down the motorway when it's convenient to do so ____________________ 'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900 |
blurredman |
Posted: 17:19 - 29 Apr 2011 Post subject: |
Recluso wrote: | Okay, now I must admit I've gotten a bit confused by the talk of slipstreaming and weaving. I'm only fairly new to this don't forget
But it's still good to hear that people think that it will be a viable option to jump down the motorway when it's convenient to do so |
Slipstreaming does not work unless you're doing 100mph, 6 inches behind the vehicle in front ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (bored to 295cc) - 38k, 1989 MZ ETZ251 - 49k, 1979 Suzuki TS185ER - 9k, 1973 MZ ES250/2 - 17k. |
Frost |
Frost World Chat Champion
Posted: 18:12 - 29 Apr 2011 Post subject: |
A shit load of the M4 has a 50 limit enforced by average speed cameras, so that'd be perfect for a 125. But as said above no learners. Some bits of motorway can be very heavily policed, and it's not like you'd have anywhere to hide! |
Frost |
N cee thirty |
N cee thirty Banned
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 20:02 - 29 Apr 2011 Post subject: |
Blurredman wrote: | Slipstreaming does not work unless you're doing 100mph, 6 inches behind the vehicle in front |
DaFrostyOne wrote: | If that were true, why do they do it on the tour de france? |
Trucks doing 56, reckon it does. Ask a haulier... they reckon that slip streaming can drop the diesel consumption by as much as 30%.
It all depends on the dynamics, and how big a 'wake' the lead vehicle creates.
In F1 GP, with the cars so acutely streamlined and running so much air management, probably wont get much suck between them. Likewise race bikes, mainly becouse of the size of them... but behind a bludty great artic doing 50+ there is one HELL of a hole in the air that will suck you along....
I mean have you ever been stood on the pavement when one has gone past at 40? The wake is enough to buffet you accross the pavement, and teh slip stream enough to suck you clean into the road. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
blurredman |
Posted: 20:11 - 29 Apr 2011 Post subject: |
No one knows whether it works in certain circumstances compared to other circumstances. The cyclists can't tell because it's so little gained speed. And then if they do feel faster, is that because they're in a cluster of cyclists? Things can just seem faster the closer they are.
And yes I admit, you can do it behind lorries because they are tall and slab backed. But would you really want to do that? They cannot see you in their mirror, and you cannot see infront of them. If a crash occurs, you're head will explode before you even think about applying the brakes. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
CaNsA |
CaNsA Super Spammer
lozza |
lozza Nova Slayer
Gazza M |
Gazza M Crazy Courier
prawny1 |
prawny1 World Chat Champion
The last post was made 12 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
