best spark plug for aprilia rs125 2001
leepick
PostPosted: 21:31 - 27 Jun 2011    Post subject: best spark plug for aprilia rs125 2001 Reply with quote
ive tried a br10eg and that was no good - i have a car spark plug in there at the moment and it works fine :s
what do you all recommend?
Aprilia RS125
Paddy.
PostPosted: 07:38 - 28 Jun 2011    Post subject: Reply with quote
Sell the bike... you cant just put any spark plug in there... Shocked
Restricted RS - BR8ES, Try a BR9 if the 10 didnt work, the 10 is for derestricted bikes..
Maybe you should just get the engine rebuilt by someone who knows what goes where... then you cant blame the spark plug Wink
Current ride : Triumph Street Triple - Suzuki SV650 track bike - Yamaha Majesty YP250 - Honda CB250 Superdream | Current car : Jeep Cherokee 2.5D
My biking history so far
leepick
PostPosted: 08:53 - 28 Jun 2011    Post subject: Reply with quote
its the derestricted bike. and mate i no whats going on im just asking questions INCASE im doing something wrong but im obviiously not cos the answers im getting i allready no!ive not long bought the bike so any problems were there when i got it. (not caused by me).
the BR10eg dont burn the fuel quick enough and causes the bike to bog down so im gonna order a BR9. im not asking because i dont no, im asking what people think is the best spark plug. i no what goes were and what everythings called. so take ya bad karma somewere else Mad
Aprilia RS125
hazza
PostPosted: 10:37 - 28 Jun 2011    Post subject: Reply with quote
You obviously don't know where car spark plugs go.
Just use the standard plug for the bike, any spares shop will have all the details on micro-fiche. Don't waste 15 quid on iridium nonsense, its not going to make any difference.
Id take the car plug out soon as though, you cant just put anything in there, Your lucky the plug hasn't smashed a hole in your piston. Also as you know, using the wrong heat rated plugs opens up a whole world of possible seizures.
leepick
PostPosted: 14:39 - 28 Jun 2011    Post subject: Reply with quote
i no but it was what worked at the time. its probly why my bike seized in the first place. im gonna get the br10eg and br9eg and see which one it takes best. br8 is to hot for the derestricted i understand and br10 maybe too cold so in the middle should be ok... the teflon coated mitaka piston an rings came today just waiting for the gasket kit. got a full kit to do the whole engine it needed it... i probly dont no as much as you lot but im not dumb i just wanna double check stuff so i dont make the same mistake twice.
thanks for your help
Aprilia RS125
hazza
PostPosted: 15:13 - 28 Jun 2011    Post subject: Reply with quote
This may not be true in my case, I can think quite logically when diagnosing other peoples problems, but i often get stumped and come to the forums for advice with my own machine!
leepick
PostPosted: 15:19 - 28 Jun 2011    Post subject: Reply with quote
i only found this forum a few days ago. pretty good. you get good advice here but you get a load of funny pr**ks who just want to belittle you aswell
Aprilia RS125
Paddy.
PostPosted: 16:21 - 28 Jun 2011    Post subject: Reply with quote
Well, im trying to be as helpful as possible, my RS ran absolutely spot on.
Mitaka pistons use cheap rings, so if you have the standard rings, you'll need to rebuild the top end again very soon.
Upgraded rings are made by Rikken, if you bought the kit from PJME they upgrade the rings for free as standard.
BR8 is for the 14hp 11kW RS125.
BR10 is for the derestricted FP RS125.
That is it...i wouldnt put 8 in a FP bike, and I wouldnt put a 10 in the 11kW bike.
How do you know its not burning it quick enough?
Its not belittling you, I've only owned 1 RS, so I cant be 100% correct, but I would trust most people on here to be helpful, especially as probably 50% have owned RS125's.
Also, stating you know what you are doing, yet putting a piston in the wrong way? Neutral
Either way, i've given you as much info as I can... check other things rather than blaming a spark plug.
leepick
PostPosted: 17:57 - 28 Jun 2011    Post subject: Reply with quote
it wasnt personally aimed at you mate, i appreciate the help/advice but not the sarcasm and the belittlement some people (not just you) give out. they wouldnt talk like it to most peoples faces so theres no need on the internet really. and i no the br8 is no good what about br9? inbetween . and i said i ent dumb i didnt say i no everything thats probly why i put it on the wrong way lol... but im not completly thick when it comes to them.there was a br10eg in the bike when i bought it and the bike would start and idle for about 15 seconds then bog down and cut out so i put a diffrent spark plug in and it started and stayed running (that was the standard spark plug not sure if it was car plug or not just banged it in there) yeh thats probly why it blew but at the same time it proves it was the plug because i also cleaned the carb jets. im gonna get another br10eg because the bike is 100% derestricted it does 110+ and gets a major boost around 8k. but if br9eg works maybe one of them would be worth getting as a spare just incase the br10 bogs again
Aprilia RS125
Paddy.
PostPosted: 23:02 - 28 Jun 2011    Post subject: Reply with quote
You need to find the reason why its bogging down.
It wont be the plug, if it does those speeds it will not be the plug.
Also, if you haven't rebuilt it fully yet (im assuming you are waiting for piston kit) then wait till that arrives rather than risk killing the barrel.
leepick
PostPosted: 10:57 - 29 Jun 2011    Post subject: Reply with quote
hi, thanks for the reply.
ive got the mitaka piston an rings im just waiting for the full gasket kit which should be here this morning/afternoon
ive bought new coil, new piston kit,gasket kit, new con rod and bearings. so not sure what else it could be. the bike was running ok with the spark plug i put in (but it was just a normal spark plug) but that more than likely caused it to blow so im thinking after the rebuild if i put a brand new br10eg in it should be running back to normal again ( i hope )... most the problems do sound spark plug related tho i.e (not idling proply at low revs, bogging down, etc)... unless it could be an underlying problem
Aprilia RS125
mJZ
PostPosted: 12:07 - 29 Jun 2011    Post subject: Reply with quote
I recommend BR10ES Thumbs Up
BR10EG is excellent if you trash your derestricted bike, ES is a bit better if you ride like a fanny, as it's a bit more oil resistant even though it's not a hotter plug.
truslack
PostPosted: 13:09 - 29 Jun 2011    Post subject: Reply with quote
How is a larger center electrode more oil resistant? Surely it would be the other way round (as in iridium plugs, thin centre electrode)
Current: Suzuki RG 125 Gamma, Honda H100(x2), Kwak ZX9R, Kwak ZZR600
Tomorrow's just another day.
mJZ
PostPosted: 14:29 - 29 Jun 2011    Post subject: Reply with quote
Saying from experience. ES has much larger electrode which doesnt get covered by oil as easily as EG plug. I experimented with both plugs (had a few EG and ES plugs) and was adjusting oil pump and increasing the oil flow. ES takes more oil and runs where EG dies.
You clearly don't have practical experience with both.. but everybody has the right to share his theory I guess. I prefer a practical approach Smile
leepick
PostPosted: 14:33 - 29 Jun 2011    Post subject: Reply with quote
lool i dont ride like a fanny. im not a nutter but id probly be better off getting the BR10EG. thanks for the advice tho.
Aprilia RS125
The last post was made 4 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Precision & Measuring Tools
2.05 - Buy It Now
Other Hand Tools
7.80 - Buy It Now
Spanners
5.59 - Buy It Now
Pliers
13.12 - Buy It Now
Other Hand Tools
6.99 - Buy It Now
Other DIY Tools
8.99 - Buy It Now
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 0.11 Sec - Server Load: 0.9 - MySQL Queries: 17 - CDN Objects: 39 - Page Size: 97.32 Kb
