honda cg no compression
lozza59
PostPosted: 21:16 - 19 Jul 2011    Post subject: honda cg no compression Reply with quote
well i bought an old cg to play with. it was only 10 miles from me and got it with tax and mot for 70 including delivery to the door!
pretty good i think Cool
it does however have an issue.
take a look at pics!
TUG
PostPosted: 21:18 - 19 Jul 2011    Post subject: Reply with quote
Ha sweet! I'm jealous! I love CG's and might be holy... but make sure you remove the rest of the debris and they are pretty basic engines anyway. Thumbs Up
Haz ER-5, innit!
lozza59
PostPosted: 21:28 - 19 Jul 2011    Post subject: cg Reply with quote
so now you have seen the piston and i am still looking for the head from the valve that went through it Laughing
barrel is fooked too.
amazingly the bottom end turns and im wondering do i really need to split the bottom end to get all the bits out, is there another way to get any bits out that may be in there? i am assuming splitting the bottom end would be normal procedure??
one other part i am after is an inlet rubber from the carb to the engine the style usually found on chinese engines, specifically a hongdou chituma ctm 125, but im quite sure others such as kymco, ajs, yamasaki, skyjet, jialing and other chinese single cylinder cg type motors would be the same as i have a cylinder head but it takes a different inlet rubber. (need one with the mounting holes to the engine facing the ground and the sky not the left and the right if that makes any sense Confused )
stonesie
PostPosted: 23:07 - 19 Jul 2011    Post subject: Reply with quote
There is no other way of getting all the bits out, they are alloy so you can't even fish them out with a magnet.
They are such easy engines to work on though, and parts are cheap.
2013 Multistrada S
Ade75
PostPosted: 00:28 - 20 Jul 2011    Post subject: Reply with quote
I think thats broken Thumbs Up Laughing Bargain though, well found Thumbs Up
CBT Passed: TBA Theory Passed: TBA Mod 1 Passed: TBA Mod 2 Passed: TBA
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.
TUG
PostPosted: 02:20 - 20 Jul 2011    Post subject: Reply with quote
For the sake of it, I would look into how small the oil ways are first and if the oil goes through the strainer before being picked up.
To be perfectly honest with you though, I would split it and clean it out. Its easer with a bike so small like a CG, I wanted to sort my VTR out but no space. Crying or Very sad
Haz ER-5, innit!
stonesie
PostPosted: 11:08 - 20 Jul 2011    Post subject: Reply with quote
As it happens I have the piston and barrel from the 150 engine in the shed (standard, used 125 fare) some marks on the piston but should help to get yours up and running, no spare head though...
2013 Multistrada S
lozza59
PostPosted: 11:40 - 20 Jul 2011    Post subject: Reply with quote
thanks for the info everyone Thumbs Up
looks like im going to be stripping the engine further then...
this thought did cross my mind but as you say it wont fish the alloy out, checked with the local motorcycle shop that agree with the engine being stripped completely but they thought the bike wasnt worth it Shocked and that a cheap complete engine is the best way.
I think thats broken Bargain though, well found
thanks i thought so! full tank of petrol too Very Happy
Posted: 12:08 - 20 Jul 2011 Post subject:
sounds interesting, if i can successfully rebuild the bottom end i will look into it Thumbs Up
Samber
PostPosted: 12:57 - 20 Jul 2011    Post subject: Reply with quote
Is this any use to you? Might be a quick way to get the bike running again.
Seller is nothing to do with me by the way.
2011 Sukida SK125-2 (CG clone)
1977 CZ 125 476 series
mccluskeyd
PostPosted: 19:08 - 20 Jul 2011    Post subject: Reply with quote
The problem with another engine is that the wiring may not be exactly as per the CG's.
Especially if it is a Chinese copy, which mainly use pattern bits from the electric start engines which are slightly different internally than what looks to me as being a pre-Brazil model....?
I would try and put your own engine back together, as if you want to do it the correct way (!!??) you would have to inform DVLA of an engine swap which is often more troublesome than the bike itself. (i.e. they sometimes want proof that a garage did it for you, or a RAC check etc).
As for a head ; breakers are full of them, same with the Carb inlet rubber. You are better sticking to CG stuff, as if you go the Chinese route it may not fit exactly.
Splitting the engines :
You quite often need an impact driver to undo the casing bolts as it may never have been opened. Having someone with you that has done it before is a good idea.
As for the internals ; they are very simple inside, and make sure and have plenty of clean workspace to work on, and label everything as you go.
As for the bike ; it's a cracker at that price ; I love CG's and have had a few, they are brilliant little machines.
All the best,
DMcC.
mccluskeyd
PostPosted: 20:05 - 20 Jul 2011    Post subject: Reply with quote
Aaaaah !!!
Thought you would bring that one up Rob ! Very Happy
And very grateful I was as well....!
All the best,
David.
Xenocide
PostPosted: 20:59 - 20 Jul 2011    Post subject: Reply with quote
I've got a paperweight on my desk which is the battered remains of a cg piston. I quite like it. No hole in the top though.
You win.
KTM LC4 400 | Honda VTR1000
lozza59
PostPosted: 22:38 - 20 Jul 2011    Post subject: Reply with quote
Posted: 13:57 - 20 Jul 2011 Post subject:
thanks for the link but i want to keep it all honda, Very Happy
i thought about making it into a 'cafe racer' style when i noticed it on ebay but as soon as i saw it with all the original bits including the mirrors i decided against it, might go as far as a custom exhaust but not at the expense of the one on it as that doesnt look a week old!
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
lozza59
PostPosted: 21:42 - 21 Jul 2011    Post subject: Reply with quote
Cos its a points model it looks like the timings been wrong and as people abuse em and dont change the oil they can overheat
im glad you mention this, how do i check/adjust the points?
thanks
also ive been to another bike shop today and they recommend i just get another engine, if i go down this route i will be looking for the later cdi honda cg engine and loom. having said that i do have a cb100 engine, its ohc but should bolt straight in, anyone know if the cg loom would work with it? only as an alternative to buying another honda engine, i have two chinese engines that would go in but i hate those things!
humanbeing
PostPosted: 12:04 - 22 Jul 2011    Post subject: Reply with quote
thanks
the chinese way to do it cheaply http://www.motoyes.net/bbs/forum.php?mod=viewthread&tid=193561
AB glue the CD70 pickup / some welding / DC CDI (ie. bigger size & a extra red wire) / GY6 rectifier Razz
lozza59
PostPosted: 00:39 - 23 Jul 2011    Post subject: Reply with quote
the chinese way to do it cheaply http://www.motoyes.net/bbs/viewthread.php?tid=193561
thats amazing! Thumbs Up
lozza59
PostPosted: 23:06 - 23 Jul 2011    Post subject: Reply with quote
thanks for the info everyone but its all done and back together now with original engine, runs sweet enough and ive done 100 miles on it today starts first kick too.
i planned to get another cg engine so for the sake of it i turned the original motor upside down and shook it, flushed with petrol and shook again, i think most/all of the bits are out of it now and the lot works very well. how lucky is that!
humanbeing
PostPosted: 06:00 - 24 Jul 2011    Post subject: Reply with quote
There's also another way to CDI that don't need new pickup & welding http://www.chegongshe.com/News/20074/car_N_412.html BUT Embarassed the "points" need to be in working order
That config is LESSER problem than "pure" form due to no "amp" passing on it BUT the "gap" ...
The last post was made 4 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Other Garage Equipment & Tools
13.95 - Buy It Now
13.95 - Buy It Now
Clamps
32.96 - Buy It Now
Clamps
42.49 - Buy It Now
Other DIY Tools
19.99 - Buy It Now
Debug Mode: ON - Server: discovery (www) - Page Generation Time: 0.10 Sec - Server Load: 0.82 - MySQL Queries: 16 - CDN Objects: 51 - Page Size: 128.45 Kb
