at106 |
at106 Brolly Dolly
P. |
P. Red Rocket
Posted: 16:47 - 30 Aug 2011 Post subject: |
Have you built it backwards?
Can you bump start it running the correct way... Im sure 2 strokes can run backwards anyway |
at106 |
at106 Brolly Dolly
Pete. |
Pete. Super Spammer
Posted: 17:04 - 30 Aug 2011 Post subject: |
Your timing is out. Try bumping it and see what happens.
Oh - be ready on the clutch
EDIT: actually, first-off pull the flywheel and check the woodruff key isn't sheared. ____________________ a.k.a 'Geri'
Kickstart |
Kickstart The Oracle
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 17:16 - 30 Aug 2011 Post subject: |
Sounds like your timing has TOO much advance.
Kick it over, kicker turns engine the 'right' way, but kick it too slow, piston comes up, early spark lights the fire, and piston doesn't have enough momentum to over centre against expanding charge.
Hows the timing set? Are you doing it merely by points gap, or are you swinging the back-plate?
Working 'blind' without book; I would start by loosing the back plate, and closing the points; turning rotor to get poiston at TDC measured with a pencil or similar through the plug hole, NOT marks on the rotor.
Piston at TDC, I'd rotate back plate so that the points were just 'starting' to open, then back off, so they were 'just' shut....
That would give aprox ZERO advance.
THEN with timing hugely retarded, bike should start up forwards.....
Wont RUN brilliantly, but should run in the correct direction!
Then, I would start advancing the ignition, an 'nth' at a time, rotating the back plate, and starting it, until I got reverse running again..... than 'back off' an 'nth so it stars forewards again... And THEN measure the points gap with piston at TDC..... and compare THAT measurement to what the book says it ought to be.....
It's PROBABLY the way you are trying to set the timing, and I suspect it will be that the book says to set a certain points gap at TDC.... BUT if the back-plate has been shifted, then points gap alone isn't setting correct timing, becouse it could be up or down the ramp of the cam on the rotor....
Hence you need to find the correct points possition, THEN set the points gap.
If you wip the rotor off, you may find that there are timing marks on the back plate, or 'wiotness' marks where its spent most of its life clamped up, that you can use to give you a 'guide' where it ought to be.... but no garantees..... propper timing swing, as described though... old fasioned, time consuming, but garanteed way to sort it.
After swinging to get startng sorted, you can then adjust to get best throttle response and running.....
Not that I have had much practice at this, but I went to look at the rotor on my Yam yesterday, and just thought I would see if the rotor puller for my Montesa would fit..... wouldn't reach isn't long enough, annoyingly! BUT there were three in the draw..... YES I have, in quarter of a century worn out at LEAST two flywheel pullers setting points and timing, on an old two stroke!
Have fun, all gryst to the mill and good experience! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
at106 |
at106 Brolly Dolly
Pete. |
Pete. Super Spammer
Posted: 17:24 - 30 Aug 2011 Post subject: |
Yes and it will cause a lot of damage if you run it any amount. ____________________ a.k.a 'Geri'
at106 |
at106 Brolly Dolly
Teflon-Mike wrote: | Sounds like your timing has TOO much advance.
Have fun, all gryst to the mill and good experience! |
This bike doesnt use points as it's one of the later models. Behind the rotor there is the stator plate which has four coils. 3 for the charging circuit and one for the primary ignition. The stator plate has 3 bolts mounting it to the crankcase, if you loosen the bolts you can turn the stator plate.
On the stator i found marks where it had previously been tightened and set it to this point but it still ran backwards. So then i put it completely the opposite way hoping it would run forwards but it made no difference. |
Kickstart |
at106 |
at106 Brolly Dolly
Kickstart |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 23:21 - 30 Aug 2011 Post subject: |
at106 wrote: | Is there nothing internally in the engine which could cause the engine to run backwards? |
Its a two stroke, it CAN run backwards becouse it completes one combustion cycle per revolution, charge controlled via holes in the cylinder wall opened and closed by the piston going up and down, makes no difference to the workings which way the crank turns.
So... No, basically, really the ONLY way that it can be made to run backwards is if you bump-start going backwards, or as described, timing is so advanced, that the piston comes up on an expanding charge without enough momentum to carry it over Top Dead Centre, and so gets blown back, and picks up enough momentum to complete the cycle running backwards,m with effectively hugely retarded ignition.
If no points, then there is still a 'trigger' somewhere on the ignition, usually an inductance coil pulsed by a lug on the rotor..... which may need looking into, but the back-plate is still out of sync with where you want the spark.
And / Or, its the CDi unit, which has an inbuilt advance curve, and rather than firing coil directly off points trigger. at LOW revs..... it fires late, by a process known as advance by retard...
Basically at higher revs you tend to want the spark earlier in the cycle.... but at low revs you want the ignition later in the cycle....
If you set your trigger pulse for low revs, you would be having to 'guess' when you want the spark ahead of the trigger signal, BUT if you set trigger pulse for where you want it at high revs, you get trigger before you want spark at low revs, so you simply set a 'delay' counter to retard it to what you want.....
Make sense?
So, if you have CDi unit, and its gone 'duff' could be its NOT delaying the timing for low rev running, and firing at the advanced high rev timing......
HOWEVER; one 'simple' thing that springs to mind; some more rudimentary CDI ignitions were either rather simple, or rather clever, depending on how you look at it.
Conventional ignition has 'something' battery, or generator of some sort providing current to 'energise' a coil, then a 'trigger' that breaks the supply to the coil, creating a field colapse and a huge reverse voltage, which provides the 'beef' to get electricity to jump the gap in the spark plug.
On a points system, trigger was the points opening.
On a CDi system, conventionally its a 'pulsar' coil, very small coil, that when a lug on the rotor passes it provides a verty small, bery bried 'pulse' of induced current, enough to be 'sensed' by a balenced electronic circuit and flip a transistor, to break the supply to the coil, mimicking the points, or, by the advance by retard method, starting a counter, that then flips a transistor and colapses the coil field...
However; on a magneto ignition, the generator is supplying a 'pulse' of electricity every time the magnets in the rotor pass the coil, being a bit clever, and saving on electronics, and wiring, using ONE WIRE from the magneto, that is supplying the current to set up the field on the coil, a CDI can simply monitor the voltage on that feed, and when it 'inverts' from a rising voltage to a decaying voltage, marking the peak of the 'pulse' from the magnet passing the coil.... trigger the field collapse, or again, start delay counter.....
This is a 'one wire' CDi ignition system, as opposed to a pulsar system that would use two wires, one for feed, one for trigger.
But there is yet another system, and that, I believe was used by Yamaha for a while, which is a 'pseudo' Cdi system, and instead of having an expensive bit of electronics, timing engine revolutions, and from a map, setting 'retard' delays, they simply had a 'duel' one wire CDi system, where there were two ignition windings, seperated on the back-plate by aproximetely 12 degrees; one provided low rev timing, other provided high rev timing, and the CDi unit simply switched between them at a pre-deturmined engine speed.....
I dont know the ignition system on your bike; BUT if you had such a duel winding CDi system, and had the wires switched so it was trying to fire from high rev winding at low rpm and low rev winding at high rpm... could explain your situation....
Running forwards, you might have 18 degrees of advance on the High Rmp winding, which would account for it it starting backwards not over centreing against burning charge....
But, running backwards your 18Deg of advance would become 18 degrees retardation, after TDC....
Not great for running at low speeds, as your low speed spark would be set something like 4 degrees advance of TDC...... but running backwards that would become 4 degrees in retard of TDC, so actually more 'advanced' than the high speed spark....
So it could still 'sort' of run nicely, backwards if you revved it! especially if the backplate had been twisted to retard the ignition, and effectively 'advanced' timing when running backwards!
Err... start with the back-plate and ignore the witness marks, see if you can retard it enough so that this start up business doesn't have it back running......
Then look at the ignition wiring and diagrams and see if anything occurs to you from ideas offered. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
at106 |
at106 Brolly Dolly
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 12:28 - 31 Aug 2011 Post subject: |
https://images.cmsnl.com/img/partslists/magneto-ts50-1987-xkh_bigsue0010fig13_4429.gif
Pic I found of TS50 Stator. Three screw attachement; you could be rotated one screw either way, but with that much extra advance or retardspark would be happening nearer BDC that TDC, probably with ports open, so I suspect engine wouldn't even run, in either direction!
Pic you linked (Use mouse right on original pics to 'copy Picture URL' then past in post, and add {img} address {/img} tags, but swap curly brakets shown for square ones, to make pic display in post) doesn't look like one shown in Suzuki Micro-Fishe; that seems to have three equipment windings, and one for the ignition, then uther gubbins I cant see inside. One in your picture seems to have four equipment windings, then for the ignition, and a 'black thing' which may be a pulsar, and possibly the CDi as well, hence one wire to coil... BUT I'm, speculating, withouty schematics for the bike.
Microfishe parts list peculiarly unhelpful; describing coil merely as Unit & Coil assembly; which may suggest CDi unit/Coil, or could just be coil with bonded HT lead!
You know... they might be a pain in the arse, needing the contacts cleaning frequently, might be a compromise between low speed sand high speed timing, they might infuriate with condensors breaking down.... BUT.... I am apreciating old fasioned points more and more these days! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Blau Zedong |
Blau Zedong Banned
at106 |
at106 Brolly Dolly
Posted: 15:39 - 31 Aug 2011 Post subject: |
Teflon-Mike wrote: | [img]
You know... they might be a pain in the arse, needing the contacts cleaning frequently, might be a compromise between low speed sand high speed timing, they might infuriate with condensors breaking down.... BUT.... I am apreciating old fasioned points more and more these days! |
The picture in your post is what is on my bike, the one i linked to was just to try and explain my idea of completely turning it around.
When i get time i'll try all of the suggestions and hopefully one of them will work!
I haven't run the engine much backwards ive just got it started, put it in gear and released the clutch to find the bike goes backwards. |
Pete. |
Pete. Super Spammer
Posted: 16:07 - 31 Aug 2011 Post subject: |
I bought a MBX50 once which had the wrong rotor fitted, and was firing on TDC with no advance. It would start fine and idle but had a top speed of 18mph. I had to re-time the engine by slotting the backplate.
Is your backplate mounted like in the picture with the long winding at the bottom? ____________________ a.k.a 'Geri'
at106 |
at106 Brolly Dolly
at106 |
at106 Brolly Dolly
Ed Case |
Ed Case World Chat Champion
at106 |
at106 Brolly Dolly
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
