honda xr 125 l indicators stopped working!
lyndonroberts...
PostPosted: 17:33 - 10 Oct 2011    Post subject: honda xr 125 l indicators stopped working! Reply with quote
hey guys first post here
i went to work this morning with my indicators working no problems, went to start my bike earlier and went to indicator out of where i work and nothing! no signal on the display in front of me to show the indicators are on and none of the bulbs illuminate.
y first protocol was to check if the fuse had blown. it was visually fine but i thought i better check by replacing with a new one. no luck
am abit stuck where to go from here. could it be a problem with the switch itself? or possibly the bulb on the display not lighting up? would this stop my indicators coming on?
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
lyndonroberts...
PostPosted: 17:56 - 10 Oct 2011    Post subject: Reply with quote
the indicators just randomly came on :S like u mentioned could be abit of damp however i have had to slide the button 2/3 times to the right to indicate right if that makes sense. rather than the usual once.
donniemateno
PostPosted: 06:57 - 11 Oct 2011    Post subject: Reply with quote
any idea where it may be located? manual with the bike is no help and i dont no if you know but from my own research theirs no sort of haynes manual on this bike which is shit! there is on the old models but not the 00's reg's.
P.
PostPosted: 10:06 - 11 Oct 2011    Post subject: Reply with quote
I would look towards the switch personally.
When my relay went the dash light came on solid as did the indi's
Try the relay as its pretty cheap to find a generic one but you could have some worn area in the actual switch or just water... spray the switch with some WD40.
serlant
PostPosted: 11:39 - 11 Oct 2011    Post subject: Reply with quote
What paddy said, i've had this on my VTR1000 and my XJ600, corrosion on the contact in the switch, hence switching it 2 or 3 times scratched some off? i'd take the switch apart and give the contact a clean i used some wet and dry.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.86 - MySQL Queries: 16 - Page Size: 57.08 Kb
