Wanted - 40mm silver steel (for hardening)
steven_191
PostPosted: 19:32 - 18 Nov 2011    Post subject: Wanted - 40mm silver steel (for hardening) Reply with quote
I'm only going with silver steel as I've used it before for hardening.
I need to make some top hat type bearing sleeves that will need to be hardened.
I need 40mm diameter or maybe just over to play with and length wise around 200mm. I know I can get a 13" length for around £35 but just wondering if I can get it cheaper anywhere?
Also is there a better material I could or should be going for? The part will be between the swing arm bolt and the bearing inner race on one side and on the needle bearing on the other. This will need hardening to stop the needles pushing into the sleeve.
The last post was made 1 year, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Everything Else All times are GMT + 1 Hour
Debug Mode: ON - Server: peanuts - Page Generation Time: 3.80 Sec - Server Load: 0.06 - MySQL Queries: 16 - CDN Objects: 28 - Page Size: 30.05 Kb
