marco 125 |
marco 125 Derestricted Danger
G |
G The Voice of Reason
Posted: 11:36 - 09 Feb 2012 Post subject: Re: Is it safe to bump start a motorbike from a car ? |
Bump starting a bike is where you push it along and release the clutch to force the engine to turn over from you pushing it.
Unless you're a reasonably skilled stuntman, I expect this is quite a dangerous method!
It should be fine to jump start a bike from a car battery without the car running. This is where you connect electric cables between the too.
It's possible it could cause damage if the car is running. However, as bike's need a good chunk less starting current, you shouldn't need the car running to keep the battery topped up/give it a bit of extra kick as you might for a car. |
marco 125 |
Posted: 11:42 - 09 Feb 2012 Post subject: Re: Is it safe to bump start a motorbike from a car ? |
G wrote: | Bump starting a bike is where you push it along and release the clutch to force the engine to turn over from you pushing it.
jump start thats what i ment ahah
how would i do this ?
would my bike have to be in gear or so on ..............
im not sure how to go about doing this as i havnt done this before |
Ericck |
Ericck Scooby Slapper
Posted: 11:49 - 09 Feb 2012 Post subject: |
You'll need a set of jump leads.
Attach leads to the car battery and to your bike battery.
Then start the bike as normal (not in gear), bike will use
power from car battery to turn bike over. ____________________ Current Bikes: 2006 Suzuki Bandit 1200, 2008 Suzuki SV650N.
Previous Bikes: Yamaha FS1E, Mobylette Moped Thingy, Suzuki GS125, Kawasaki Zephyr 550, Kawasaki Zephyr 750, Kawasaki ER500, Suzuki Bandit 600, Honda CBR600F, Triumph Street Triple 675, Suzuki V Strom 650. |
Polarbear |
Polarbear Super Spammer
G |
marco 125 |
Posted: 11:56 - 09 Feb 2012 Post subject: |
thanks for the help , much appreciated
thanks |
Polarbear |
marco 125 |
whitedevil |
whitedevil World Chat Champion
whitedevil |
Dilyan |
Dilyan World Chat Champion
G |
wilz1234 |
wilz1234 Trackday Trickster
Tarmacsurfer |
Tarmacsurfer World Chat Champion
G |
Posted: 12:58 - 09 Feb 2012 Post subject: Re: Is it safe to bump start a motorbike from a car ? |
I should add that doing it with a tow rope is cheating - done that enough times myself (and with other bikes etc).
I was thinking standing in the door/window/rear/bonnet of a car while holding the bike, getting a good lick up, then jumping from the 4 wheeler to the 2, landing on it and kicking it in to gear .
To be fair, there is, on consideration, a lot of easier and less dangerous ways for the same situation - however less spectacular too .
Have attempted it holding on by hand to another bike/rider, but not a car. However all have been from an already seated position. |
Marcbrown46 |
Marcbrown46 Derestricted Danger
G |
Rogerborg |
Rogerborg nimbA
Posted: 14:23 - 09 Feb 2012 Post subject: |
marco 125 wrote: | then start the car ? (also heard that you should not rev the car) ? |
Just to clarify, when you're starting a car from a car, then you generally want the engine running.
However, when starting a bike from a car, don't run the car engine. There's a small (but why risk it?) chance of shagging the bike reg/rec.
If you have to buy jump leads anyway, then why not buy a basic charger instead? You'll want to get your battery fully charged, and taking it for a ride might not do that.
Also, if you're in any doubt about why your battery is discharged, spend £5 or so on a cheap multimeter and learn how to use it, you'll save yourself a load of time and money in guessing where the problem(s) are. ____________________ Biking is 1/20th as dangerous as horse riding.
pinkyfloyd |
pinkyfloyd Super Spammer
Posted: 15:01 - 09 Feb 2012 Post subject: |
I erm. Um. Started my bike from one of these once.
https://farm4.static.flickr.com/3543/3781112389_1387f6868d.jpg
Bike fired up instantly. ____________________ illuminateTHEmind wrote: I am just more evolved than most of you guys... this allows me to pick of things quickly which would have normally taken the common man years to master
Teflon-Mike:I think I agree with just about all Pinky has said. |
weasley |
weasley World Chat Champion
Polarbear |
Posted: 15:03 - 09 Feb 2012 Post subject: |
That was probably because of the fumes ____________________ Triumph Trophy Launch Edition |
Edgar Jessop |
Edgar Jessop L Plate Warrior
Posted: 15:18 - 09 Feb 2012 Post subject: |
I've jump started quite a few cars and vans over the years. The hardest are diesels, because it requires a good few amps going through the starter motor to turn them over. If you try and do that from a stationary car you probably won't get enough current to turn it over. With the engine at idle it may just stall as the load comes on. That's why they say rev the engine up to a fast idle.
To start a little engine like a bike from a big battery like you'd find on a car or van I'm sure you could just do it on static battery, ie no need to run the other engine.
Like the man says the most important thing is to connect +ve to +ve and -ve to -ve NOT the other way round, unless you like trying to pull red-hot copper wires off the terminals before the battery catches fire ____________________ Never break more than one law at a time, or carry more grass than you're prepared to eat. |
G |
Capt Castle |
Capt Castle Scooby Slapper
Posted: 21:08 - 09 Feb 2012 Post subject: |
I have been to that very kebab van after a night in the Gloc in Oxford. ____________________ Bikes: GZ125>CBR125>Yamaha MT03>Triumph Sprint ST 955i
CBT: 06/06/08 DAS:14/07/09 |
The last post was made 12 years, 79 days ago. Instead of replying here, would creating a new thread be more useful? |
