Lights problem, flickering
DaveS
PostPosted: 01:55 - 08 Apr 2004    Post subject: Lights problem, flickering Reply with quote
The headlights on my TZR do what they want Confused
When I brake, they get brighter, when i rev they get dimmer and when i indicate they just get dimmer and brighter in time with the flashing.
The battery is ok as I have just replaced it and fully charged it. This improved the situation a bit but still pretty distracting for other drivers (and me when I open the throttle out of a bend and the lights dim so I cant see where i'm going!)
Any help appreciated thankyou.
..DaveS
PostPosted: 17:29 - 09 Apr 2004    Post subject: Reply with quote
Check the circuit from the "alternator" to the regulator / rectifier unit, and from there to the battery. Check the connections are tight and also check that none of the connections are corroded / broken (it is quite easy for the connections to be broken but appear OK at a glance).
It does sound to me as though the regulator / rectifier unit is gone though. As the revs go up the ignition system needs more power, and without the bike charging up it lands up taking the power from the lights.
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 32.24 Kb
