| Author |
| Aff |
 Aff World Chat Champion
| Back to top |
| Aff |
| Back to top |
| paddlesat16 |
 paddlesat16 Crazy Courier
 Posted: 16:12 - 10 Apr 2012 Post subject: |
The gaskets are dry
Regards ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
| Back to top |
| Aff |
 Posted: 16:17 - 10 Apr 2012 Post subject: |
| Back to top |
| Aff |
| Back to top |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:11 - 10 Apr 2012 Post subject: |
Err, yeah, that looks rather NASTY!
Co-Incidentally, I may be able to help you out with replacement cases... I have a CD200 motor, I bought to knock down, for a Super-Dream project..... just been loath to do so as its a runner as it stands... but we can talk about that later.
Engine mounts dont just 'break'!
I would be rather more worried about what has CAUSED that boss to fracture AND accross BOTH cases.
Best case, numpty prebiouse owner 'dropped' the engine, with it out of the frame, and caused a crack that has grown.
Worst case, and possibly the more likely is that the bike had a hard impact that has twisted the frame., putting that boss under stress causing it to fatigue fracture.
Curiouse though; engine is semi-stressed in the frame, and the rear mountings are the major load bearing points.
Front down tube, simply completes the triangulation from the head stock.
Quiet common for the front mounting bracket to be left 'loose' or have a bolt out, and then the frame flexes, and that COULD cause undue stress on the rear mounts, BUT, not where I would expect damage to occur, unless the whole engine has been left shaking itself to bits, with ALL the bolts undone!
You ARE unfortunately not too nearby, or I'd suggest hauling it over here to have a shuftie, see how my engine lines up in the frame.
Meanwhile, I'd get some bits of string, chalk, and a dry patio and see if I could do some alignment checks... get the bodywork stripped back, look for stress witnesses in the frame, that kind of thing.
No point getting another engine, or rebuilding an engine to find it wont fit, because the frame is bent; bike rides like a camel, because its not straight, and or misaligned mountings simply do to another what hath been done to that! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Back to top |
| Shaft |
 Shaft World Chat Champion
 Posted: 22:28 - 10 Apr 2012 Post subject: |
I was wondering if someone has dropped the motor before and undone everything, leaving that bolt until last, then the engine has tried to 'swing' around that point and cracked the case. ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| chrysanthy |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 chrysanthy L Plate Warrior
| Back to top |
| Aff |
 Posted: 09:47 - 11 Apr 2012 Post subject: |
Thanks for the reply Mike,
I did check the frame when i first got it and all seemed good (will probably do a more detailed check now i have everything off it).
Like i said i rode it back and it was riding absolutly fine (or as well as it can with no rear dampening)
The bloke i bought it off said that it was dropped at about 15 mph in the wet about a year ago and slid quite a way down the road (didnt hit anything though), you can see the marks from this on the inspection cover. He said that after this, there was a very slight oil leak. It passed its MOT about a month after the crash. After the MOT he rode it 40 miles a day 5 days a week and he said the leak got progressivly worse.
Due to the nature of the engine its very viby so i just assumed that it started as a crack near a mounting point and worked its way around untill eventually it broke itself away. (maybe even my ham fisted engine removal technique finished the job the engine started)
I will definatly be chacking it again but im quite confident that the frame is OK  ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
| Back to top |
| mattb_uk |
 mattb_uk Two Stroke Sniffer
| Back to top |
| Aff |
| Back to top |
| mattb_uk |
| Back to top |
| Aff |
| Back to top |
| paddlesat16 |
| Back to top |
| Aff |
 Posted: 17:07 - 28 Apr 2012 Post subject: |
| Back to top |
| Usher4566 |
 Usher4566 Spanner Monkey
| Back to top |
| Usher4566 |
| Back to top |
| Aff |
| Back to top |
| Usher4566 |
| Back to top |
| Aff |
 Posted: 18:00 - 14 Jul 2012 Post subject: |
Ok its been bloody ages, but my collar bone is finally back in 1, almost straight, piece. Took a couple of weeks to get the er6f back on the road, but now i can concentrate on the CD.
Whilst I was stuck at home for a month I was able to source a donor engine and got a courier to pick it up.
Last weekend i stripped it all down and rebuilt the original engine back up with the new crank cases. Unfortunately i didnt have a camera with me so havent got any photos.
It all went very smoothly though, as the donor engine had much less rust. If you read my previous posts backwards it will give you an idea of how it went back together.
Today i carried on stripping the frame down.
Took all the wiring loom off, its a bit of a mess, its probably about 40% choc blocks and 60% electrical tape.
The wiring in the headlight seemed to be the home to about ten thousand baby spiders, all nice and crispy from the heat of the light/lack of flies living in the housing.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMAG0016.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMAG0017.jpg
I will come back to and tidy the wiring up later on.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0769.jpg
Started taking the rear end apart, the rear shocks are completly shot, will have to buy some new ones. Also they were held on by 2 different nuts and an assortment of about 15 different washers...
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0766.jpg
Wheel isnt as bad as i though it was.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0765.jpg
Drum brake is a bit grubby and needs new shoes.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0768.jpg
Does this sprocket need replacing? Im replacing the chain anyway.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0767.jpg
Swinging arm out, was worried it would be seized, but apart from some odd sized nuts it came off fine.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0763.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0764.jpg
The swinging arm was caked in about a half inch thick layer of oil/mud/general road crap.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMAG0026.jpg
Spent hours trying to clean it off, eventually got it all off and about 50% of the paint fell off with it, there was a fair amount of surface rust but nothing that looked serious.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0770.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0771.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0772.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0773.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0774.jpg
I will strip the rest of the paint off then respray it when we get some better weather. Then ill have to do the same to the frame ...
Has anyone got any tips on getting the crap off a bit quicker? I was using parafin and a stiff brush.
Cheers!
Chris ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
| Back to top |
| mccluskeyd |
 mccluskeyd Two Stroke Sniffer
| Back to top |
| Aff |
| Back to top |
| nfo |
 nfo Nova Slayer
 Posted: 19:36 - 14 Jul 2012 Post subject: |
Nice work. Headlamp full of bodges and crispy spiders is just like my CB125
I see that the CD200 has the same tank mounting arrangement as my bike - what's the trick to getting the lip on the tank into the rear rubber mount? ____________________ Mar's Law: Everything is linear if plotted log-log with a fat magic marker.
1975 CB125S 'repair and tidy up' project thread here... |
| Back to top |
| paddlesat16 |
 Posted: 14:04 - 16 Jul 2012 Post subject: |
Scrap the sprockets, nice new shiney new ones when you do the chain
| Back to top |
| Aff |
| Back to top |
The last post was made 13 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
