Removing sprocket carrier bearing remains...
Mungel
PostPosted: 07:11 - 26 May 2012    Post subject: Removing sprocket carrier bearing remains... Reply with quote
Found the source of the strange clunking noise when moving off from stand still....
https://cdn.bikechatforums.com/files/bearing1.jpg
That is the remains of my sprocket carrier bearing Shocked
Those are the few ball bearings which remained intact.
The squashed bits were also ball bearings, once..
Now I have a problem. As the bearing has collapsed, the outer ring of the bearing is stuck in the sprocket carrier and despite soaking it all night with plus gas, it just won't budge. I'm thinking I might try to dremel it out, but I don't want to bugger up the carrier. Any ideas?
https://cdn.bikechatforums.com/files/bearing2.jpg
Mungel
ZZR600 (dead) - ZX9R (sold) - FZ1S
alun111
PostPosted: 07:31 - 26 May 2012    Post subject: Reply with quote
Have you got a socket the same size as the recess? If so put it in there and hit it hard with a lump hammer or something.
Mungel
PostPosted: 07:59 - 26 May 2012    Post subject: Reply with quote
Unfortunately the outer bearing shell fits flush to a lip on the carrier, so you can't get anything on the bearing to hit it with. (it only comes out in one direction)
See my wicked paint diagram that shows what I mean
Mungel
Walloper
PostPosted: 08:23 - 26 May 2012    Post subject: Reply with quote
Are you just oot yer bed???
If he hits it with a socket or sumfing it will just do nothing.
If you can get the wheel to an engineers, garage, welding shop they can run a bead of weld around the inside of the old outer race.
When it cools the bearing will fall out when the wheel is turned over.
I want Karma for that.
If you are in a panic.... You could cut a groove in the bearing with your Dremmel and try knocking it from the other side using a punch.
Nick_Giles
PostPosted: 09:17 - 26 May 2012    Post subject: Reply with quote
Similar happend to me the other week changing a sprocket bearing on an ER5
I GRADUALY tapped it out with an old screwdriver and hammer.
first few 'whacks' quite hard to break its self created seal.
Then gentle hit / tapping order of :-
12 o'clock - 6 o'clock
9 o'clock - 3 o'clock
Take your time and dont rush even when its nearly out.
I know its far from textbook bearing removal but it worked for me. Then used the old bearing ring to drift the new bearing back in.
Nick
p.s. -------- Did I mention. Take your time, tap it gradually & dont rush. Wink
PostPosted: 09:33 - 26 May 2012    Post subject: Reply with quote
Take the rubbers and sprocket off and put the whole thing in the oven for an hour or so at 200 degrees.
Set it with the open end of the bearing seat facing down and it might even fall out itself.
If it doesn't, lift it out (carefully), set it on a couple of bits of wood and see if you can get a punch on the edge of the race from the back.
If it is your own oven, carry on. If it is likely to cause domestic strife, make sure it's fully degreased then washed in hot soapy water before proceeding out or the kitchen will smell of burning oil when they get back and they'll know you were up to something.
A small groove in the bearing seat cut with a dremel shouldn't prevent the new bearing seating. Good luck cutting it with a dremmel though.
Mungel
PostPosted: 10:30 - 26 May 2012    Post subject: Reply with quote
Very Happy
Thanks for all the advice.
How will this work? Will outer race contract inwards with the weld cooling?
This is what I have been doing, but the bloody thing is not budging.. I can't get any purchase on the race with the drift.
That's a big no no.. I'd never hear the end of it if the kitchen or oven smelt even slightly..
This is my next attempt, if I can get my hands on a dremel today. I should be able to get more of a grip on the race with the screwdriver head.
Mungel
Nick_Giles
PostPosted: 10:35 - 26 May 2012    Post subject: Reply with quote
Take it to your mums oven. .................. Mums always forgive sons. Very Happy
Nick
PostPosted: 10:49 - 26 May 2012    Post subject: Reply with quote
Nick
And remember. It is easier to ask for forgivness than permission.
Casper
PostPosted: 11:08 - 26 May 2012    Post subject: Reply with quote
My bottom head bearing was the same when trying to tap it out from the other side. I just used an old small chisel which managed to open a slight gap when tapping round and round. Once it was a wider gap i could get in with an old screwdriver.
Mungel
PostPosted: 12:13 - 26 May 2012    Post subject: Reply with quote
Well, I've had no luck locating a dremel and my hands are sore from hitting the bloody thing with a chisel/screwdriver/punch. It won't budge. Not even slightly.
I have a blowtorch to hand. Maybe some heat can help things along? What bit should I try to heat up? The race or the carrier? Will it even help? Crying or Very sad
Mungel
mentalboy
PostPosted: 12:50 - 26 May 2012    Post subject: Reply with quote
Alloy expands a lot quicker than steel so heat carrier as best as you can, just be careful with the torch and try to heat around the carrier as evenly as you can. Paintwork will probably suffer unless you've got a surgeons touch,
Good luck
Make mine a Corona.
Pete.
PostPosted: 13:26 - 26 May 2012    Post subject: Reply with quote
That's an easy one. Re-build the bearing without the cage by putting all the balls in one side, offering up the centre part and then moving the balls around to distribute them evenly. Use grease to make them stick in place. You need to use a minimum of three balls but six or more would be better.
Now you can whack out the bearing using a drift on the inner race.
a.k.a 'Geri'
The Artist
PostPosted: 13:35 - 26 May 2012    Post subject: Reply with quote
Having done this a couple of times before, one time it was exactly like yours, destroyed bearing, I say hit it harder. Get a punch on the inside of the race and hit it as hard as possible. It will go, it just needs persuasion.
Mungel
PostPosted: 14:30 - 26 May 2012    Post subject: Reply with quote
Mr. Green Mr. Green Mr. Green Mr. Green
If I could, right now I would be kissing you...
I fished out the ball bearings (x6) from the bin, rebuilt the bearing with copious amounts of grease to hold the bearings, spaced them out carefully with a small screwdriver and then whacked it out with a socket.
https://cdn.bikechatforums.com/files/bearingout.jpg
Many thanks for all the other suggestions too.
Mungel
Pete.
PostPosted: 14:58 - 26 May 2012    Post subject: Reply with quote
Cool Thumbs Up Thumbs Up
a.k.a 'Geri'
Casper
PostPosted: 15:27 - 26 May 2012    Post subject: Reply with quote
I dont understand how that works. Would the centre not just fall out when you turn it over? I take it there is a lip holding the bearings in place at both sides and the bearings are taking the impact.
Mungel
PostPosted: 16:10 - 26 May 2012    Post subject: Reply with quote
There is a slight recess on the inner and outer races that the bearings sit in. Its very slight but once you have the bearings spaced equally around, the inner race won't fall out. It makes perfect sense, but I would never have thought of it.. Smile
Mungel
Casper
PostPosted: 18:06 - 26 May 2012    Post subject: Reply with quote
Now i understand, thanks as i need to order one for myself. Handy to know just incase mine falls apart when i take it off.
PostPosted: 18:12 - 26 May 2012    Post subject: Reply with quote
Genius. Never heard that one before. Added to my bodge-bank. Karma
Sako
PostPosted: 06:23 - 28 May 2012    Post subject: Reply with quote
that is a brilliant piece of advice, impressed! Karma
The last post was made 13 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.84 - MySQL Queries: 15 - Page Size: 118 Kb
