lilredmachine |
lilredmachine World Chat Champion
lilredmachine |
lilredmachine |
Posted: 06:46 - 08 Nov 2014 Post subject: |
Pete. |
Pete. Super Spammer
Posted: 07:41 - 08 Nov 2014 Post subject: |
Good times for a novice on an upright ____________________ a.k.a 'Geri'
lilredmachine |
Posted: 07:58 - 04 Apr 2015 Post subject: |
Right, the new season begins, that means new mods, a rebuild and a reboot.
Carrying on work wth the bandit:
New sprocket carrier bearing beat in using the heat to the rim and bearing in the fridge method lol.
https://s11.postimg.org/a7a28c3df/11083619_10153180167388485_1422748195358344199_n.jpg
https://s11.postimg.org/n7h7r10k3/11053360_10153180167858485_497386690728766997_n.jpg
Couldn't for the life of me remember why I was so keen to change the bearing. It was feeling ok. When I prised the dust cover off I remembered that it was because the bike was going for a dyno session and the sprocket bearing had failed. In my haste the only one I could find was an open bearing, should be sealed.
https://s11.postimg.org/ky2a7r6dv/11083841_10153180167988485_4601572822203365229_n.jpg
Hub pins cleaned up (scrubbed with emery cloth) and lightly greased ready for the new 42t sprocket.
https://s11.postimg.org/xckguc8ib/11059364_10153180166078485_6894855378593586937_n.jpg
Headers rewrapped - due to the way the pipes are arranged, in order for the turbo setup to fit behind the front wheel, header wrap is an absolute necessity in order to prevent the exhaust system using the oil cooler as a heatsink.
https://s11.postimg.org/4gfagv5zn/10676148_10153150423563485_7656646860321782687_n.jpg
https://s11.postimg.org/psmsejpxv/10985900_10153150423868485_6530757811962984610_n.jpg
Looking rather bare at the moment, lets rebuild it!
https://s11.postimg.org/mpm2b6az7/10430885_10153150423333485_3291139289047158657_n.jpg
Remember what I was saying about pad material buidling up in the vent holes of the disc? the bottom holes have been punched out, the top holes are how they start out. How much material can really be in them?
https://s11.postimg.org/i8yaq8m4z/10356728_10153150423108485_3398569408086483308_n.jpg
Lots. And to prove how often I do this, I can tell you there are 64 vent holes in the discs of a 2005 GSXR 600, not many people can tell you that off the top of their head.
That done, and having already cleaned up the forks, parts start going back on the bike.
https://s11.postimg.org/v2wcjkzkj/11083928_10153180168088485_1174148124373287387_n.jpg
Turbo assembly bolted back up with new exhaust gaskets.
https://s11.postimg.org/hgvmr1hxv/11081089_10153180166933485_6919566660210396296_n.jpg
New UK made Ramair tubing with a 6mm internal/10mm outer. Should prevent ballooning. The old pipework used to visibly expand under load at 5psi, so upping the boost this is probably a good idea.
https://s11.postimg.org/xduenrac3/11081223_10153180168198485_8364531677662959612_n.jpg
Forks back in. At this point I decided I didn't like the Dommies anymore so started tarting with a new big headlight. not sure what it's off, but it's all metal and has the 'S' for Suzuki stamped on it.
https://s12.postimg.org/bymjd81fh/11129639_10153187846918485_5302676470333223522_n.jpg
Came out rather nice I think. My mate told me I'd need a new screen as you can't cut the airblades without cracking them. I laughed and proceeded to dremel the screen to the right shape, turned the brackets inside out, bent them the other way and redrilled them and bob's your uncle... new screen.
Front wheel back in with cleaned and painted discs and new bearings.
https://s11.postimg.org/yvfuzbf2r/11082543_10153180166653485_8799220837221296338_n.jpg
https://s11.postimg.org/qoj9tzzmb/10347401_10153180166798485_8300148521894547518_n.jpg
With a new filter...
https://s11.postimg.org/3w09e6cr7/11081002_10153180166268485_7693584640465776141_n.jpg
Out of pics, nex post... ____________________ Bikes: too many, too much for one man to maintain anyway. |
lilredmachine |
stevo as b4 |
lilredmachine |
lilredmachine |
Posted: 06:07 - 07 Apr 2015 Post subject: |
chris-red |
lilredmachine |
There is a gap of 1 year, 284 days between these two posts... |
lilredmachine |
Chesh |
Chesh Derestricted Danger
Posted: 01:16 - 06 Feb 2017 Post subject: |
That is so incredibly sexy if I may say so (Although I did prefer the naked front end). What made you go for the fairings? Tired of getting battered by the wind on the strip?
Also, if I'm not mistaken, this thread still lacks video |
lilredmachine |
The last post was made 7 years, 79 days ago. Instead of replying here, would creating a new thread be more useful? |
