PLEASE HELP - Bike's voltage drops low (more info inside)
 Topic moved: from General Bike Chat to The Workshop by Kickstart (28 Oct 2012 - 18:24)
JBL
PostPosted: 18:48 - 27 Oct 2012    Post subject: PLEASE HELP - Bike's voltage drops low (more info inside) Reply with quote
so i'm a new rider with little experience on how the electrics work so apologies about that.
here's my problem, with a fully charged battery everything works great but it seems to drop a lot of voltage when riding with the lights on.
here's some results from testing:
-nothing on - 11.98v
-just engine on with revs - voltage rises to over 13v
-after engine is turned off from rising to over 13 it drops to about 12.2
(this makes me think that it isn't a problem with the battery charging)
-JUST LIGHT ON - drops immediately to a pathetic 8.9v
-engine and lights on with revs - very slowly rises from 8.9v to only 9.2v (lights too dim to drive safely at night)
I would really really appreciate if someone could tell me what to do from here, thanks.
Turkish
PostPosted: 18:57 - 27 Oct 2012    Post subject: Reply with quote
Should be in the workshop really Thumbs Up
What bike is it?
ZX-6R G2
CBR125R RW6
JBL
PostPosted: 19:03 - 27 Oct 2012    Post subject: Reply with quote
What bike is it?
rieju rs2 50 2004. piece of junk to be honest
J.M.
PostPosted: 19:41 - 27 Oct 2012    Post subject: Reply with quote
Not an expert by any means of the word, not sure even, but couldn't this be caused by a short/bad earth on the lights wiring somewhere?
2004 R1 & 2018 XSR900
BigGeeking
PostPosted: 01:40 - 28 Oct 2012    Post subject: Reply with quote
Hello and welcome to the forum mate
1st should be posted in the work shop for things like this but never mind.
With the volts dropping that low the battery is shit, is it a MF battery or a serviceable battery you can top up with electrolyte.
If it is the latter top it up and recharge.
The charging of the battery on the bike when running sounds good 13V
What are the volts across the battery when cranking it?
But with the info you have give us the battery is fooked new battery time.
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
Stalk
PostPosted: 18:49 - 28 Oct 2012    Post subject: Reply with quote
Just had exactly the same problem with w 125 Sanya, turned out to be a short circuit to earth on the rear light. Unplug all the lighting connectors. See if battery voltage is ok with lightswich on. Leave lightswich on and start to plug things back together. Voltage will drop sharply and dashboard will dim dramatically when affected light plugged in.. that should point you in the right direction. Than its a case of visual inspection and measureing for continity on that part. Where are you?
PostPosted: 19:31 - 28 Oct 2012    Post subject: Re: PLEASE HELP - Bike's voltage drops low (more info inside Reply with quote
Your voltage with nothing turned on is a bit low, so the battery might not be that healthy. A bit over 13V is probably about right with the engine idling. With the engine being revved to a half decent amount it should get up to about 14.5v.
However the lights on is dropping the voltage FAR too much.
Possible that you just have a too powerful headlight bulb in there, or something else that is putting a large load on the system (including a possible short).
Also probably worth checking that the wiring through the stator is OK. How many wires are there from the stator to the regulator / rectifier? If there are 3 then check the resistance between each pair of the 3 (ie, say we call them A, B and C, check A to B, then A to C and then B to C). Resistance should be the same, but possible one of the coils in there has fried leaving it only charging on part of the stator (had this happen on a GPZ500, charging was a little down but with the lights on it would slowly flatten the battery)
The last post was made 11 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 20 - Page Size: 60.1 Kb
