mysterious_rider |
mysterious_rider World Chat Champion
Clutchy |
Clutchy World Chat Champion
Posted: 01:22 - 30 Dec 2012 Post subject: |
I had something similar, so I adjusted the clutch cable and made it so it 'pulled the clutch in more' sorry don't know how else to word it and that fixed it for me, have a play/look at that first id say. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
Kickstart |
Kickstart The Oracle
Posted: 01:31 - 30 Dec 2012 Post subject: |
ZZR600 always has a reputation for a clunky gear change (and the normal thing to blame when that gets worse is worn cush drive rubbers), but not sure that what you are describing sound like clunks. the grinding sounds more like it isn't going into gear immediatly.
Might be worth lubing the gear change linkage and adjusting the lever down a touch (to get you to move the lever more).
johnsmith222 |
johnsmith222 World Chat Champion
Posted: 07:54 - 30 Dec 2012 Post subject: |
check your chain is adjusted properly also as this many seem to have experienced these problems more frequently when the chain is needing adjusted (including myself).
I'd also second keith's recomendation to removed the footpeg and lube the shifter. |
Stonefly |
Stonefly Scooby Slapper
Posted: 11:08 - 30 Dec 2012 Post subject: |
Mine is exactly the same. Its worse when its cold, but it still lurches a bit even when hot. I have found that the gear change gets very clunky through the gears if the chain is not kept properly tensioned at all times. It will help to do as the others have said, and get everything cleaned (i use paraffin) in the drive train, then give everything a good lube with fresh grease and/or oil. I really wouldnt be worrying about it to be honest. it seems to be one of the 'features' of the ZZR's. Best to just try and live with it.
Just for the record, a friend bought a brand new one in 1996 and gave me a go on it with just 800 miles on the clock.......it lurched when it went into first from neutral!!! ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
mysterious_rider |
Posted: 19:40 - 30 Dec 2012 Post subject: |
Okay I have indeed sourced the problem (sorta) Adjusting the clutch cable so it pulls on the lever (even when not in use) sorts it. The bite point is quite far out though and theres no play in the lever once you let go. The cable is taught all the time at the moment.
Changes gear beautifully now though... And no slippage. Just my fucking bite point is out a fair bit. Possible clutch plates need changing?
Like I said though, no slippage thus far... ____________________ KAWASAKIIIII |
Clutchy |
Posted: 19:49 - 30 Dec 2012 Post subject: |
Kickstart |
mysterious_rider |
Vincent |
Vincent Banned
mysterious_rider |
Hetzer |
Hetzer Super Spammer
P. |
P. Red Rocket
ricklincs45 |
ricklincs45 Nitrous Nuisance
jimspeed |
jimspeed World Chat Champion
mysterious_rider |
jimspeed |
mysterious_rider |
Posted: 22:29 - 01 Jan 2013 Post subject: |
EBC are supposed to be very good. It's KYOTO you gotta avoid! Never again! they used to get hot, and expand/contract and fook up the adjustment at the lever.
Mine doesn't do any of that you see. Maybe it was just the freeplay in the lever after all. I shall check it soon. cheers. ____________________ KAWASAKIIIII |
The last post was made 11 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
