Just_James |
Just_James Could Be A Chat Bot
Posted: 17:35 - 19 Jun 2015 Post subject: |
Great news! Well done fella
Will look forward to updates ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
RyanTZR125 |
RyanTZR125 Scooby Slapper
Posted: 20:49 - 23 Jun 2015 Post subject: |
pepperami |
pepperami Super Spammer
Posted: 08:23 - 24 Jun 2015 Post subject: |
Impressed Pepperami is impressed how you keep on getting in there and not letting the situation beat you
10 out of 10
I saw a article on "teh net" about how people tune these little bikes ?
I think it was from Germany?
If I see the article , I will link it, but don't hold your breath as it was a while ago.
Any stop whatever you are doing and get out there and get that engine sorted, NOW! ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
RyanTZR125 |
pepperami |
RyanTZR125 |
Just_James |
Posted: 17:02 - 28 Jun 2015 Post subject: |
Looking good
Where did you manage to source that engine from? ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
RyanTZR125 |
Posted: 17:38 - 28 Jun 2015 Post subject: |
I found a scrapper on ebay, lucky for me he'd listed 2 h100s for breaking the day I started looking 150 for the engine on buy it now, no carb or inlet as that was listed separately, I messaged him asking for a deal on the carb and he kindly threw it In free of charge.. ____________________ 1980 Honda H100A, Cafe racer. (SOLD)
1998 Yamaha TZR 125 4HX.
1999 Yamaha R6 YZF |
RyanTZR125 |
Posted: 15:56 - 29 Jun 2015 Post subject: |
Fitted the transplant engine in today, have had to use the top end from the A engine so the exhaust fits, also changed the chain cover from the A engine as the S has a slightly different cover...
It runs and idles... I almost fooked it though, with a true rookie mistake, I fired it up without any oil in
The clutch isn't working so need to pull that apart to investigate, I have a complete spare from the old engine so just a case of swapping over maybe......
https://i3.photobucket.com/albums/y87/NitroCowBoy/BIKE/Honda%20rebuild%202015/22087_10153352012989020_5448223573817678532_n_zpsdhpusc95.jpg ____________________ 1980 Honda H100A, Cafe racer. (SOLD)
Fladdem |
Fladdem World Chat Champion
Posted: 16:34 - 29 Jun 2015 Post subject: |
Good find, I think I paid £100 for H100S engine. I've got a carb off an 80's CR80, I think, for my 100, which bolts up to the inlet, I think it's a 28mm? I've got no idea, I've just been buying random stuff from 80's two stroke Hondas for years, I don't know what's what anymore.
Could you check to see if the cylinder head mounts are different between A and S? My idea is to stuff the 100 engine in my MT50, but I bought an S rather than the A, which is the engine everyone else uses. Apparently the S requires more modification to get to fit on the top engine mounts. I may have to source a 100A top end if that is the case and do as you've done.
I'm going to need to use the original MT50 chain cover as well, to fit in my frame. When you say no oil, do you mean no two stroke or no gearbox? Like Pepperami said, your patience is better than mine, I did a mini resto' of my TTR and I did 300 km's and the gearbox went, I've just parked it up and left it since April. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
RyanTZR125 |
Posted: 18:55 - 29 Jun 2015 Post subject: |
The differences from the S and A are the head and barrel are different, in shape, the S is a more squared shape to the top end with the exhaust mount at a different angle, The A ans S are pretty much the same engine, just a few cosmetic differences as stated, all head mounting holes are the same as are the bottom end the only difference in the bottom end is that the S has an extra cable coming from it for a rev counter where the A didn't have a rev counter. Also the middle engine mount is shorter on the S so the spacer needed shimming to take up the extra gap.
The S replaced the A (1980-1983) in 1984, possible as already in production for the A, they just made very subtle changes, so using the surplus A left overs? The changes where more cosmetic giving a sleeker look, by squaring off the barrel and head, adding the rev counter and changing the chain cover for a more sleeker looking cover..
The A and S share the same gaskets..
It was the gearbox oil I forgot to fill before fire up
Didn't run for too long before the penny dropped, so hopefully no damage done, I will drop the oil tomorrow and replace again to make sure no metal is present... ____________________ 1980 Honda H100A, Cafe racer. (SOLD)
RyanTZR125 |
Posted: 19:10 - 19 Jul 2015 Post subject: |
I just can't stop fettling with this little Honda, today I fitted performance reeds, cleaned and up jetted the carb to 130, fitted a cone filter, removed the air box, side panels and rolocated the battery. This is about where i imagined her when I set about this project, so feel she is finally now complete............. (Although I never did get to fit those rear sets. ummmm maybe i should hang on to her till i get round to that )
well almost, I have a new piston kit on order which i'll be popping in next weekend
I fired her up and she sounds amazing with the filter, a little raz up the road and I could feel the difference
She is for sale, as i've just blown a wad on a 98 TZR import and only have space to park one bike But really tempted to stash her up somewhere and keep her
Anyway here are possibly some of the last updates on this beast.... It's been real fun and she makes me grin from ear to ear..
https://i3.photobucket.com/albums/y87/NitroCowBoy/BIKE/Honda%20rebuild%202015/20150719_122934_zpsnaxy7jmj.jpg
https://i3.photobucket.com/albums/y87/NitroCowBoy/BIKE/Honda%20rebuild%202015/20150719_122943_zpswdtixigj.jpg
https://i3.photobucket.com/albums/y87/NitroCowBoy/BIKE/Honda%20rebuild%202015/20150719_134133_zpshpla6wd9.jpg
https://i3.photobucket.com/albums/y87/NitroCowBoy/BIKE/Honda%20rebuild%202015/20150719_134154_zpshdcdetju.jpg ____________________ 1980 Honda H100A, Cafe racer. (SOLD)
Tr1gg0R |
Tr1gg0R Borekit Bruiser
RyanTZR125 |
stevo as b4 |
Posted: 09:38 - 21 Jul 2015 Post subject: |
You made a fantastic job of this bike, and I think I speak for many when I first saw it and wasn't sure about it's desire in custom bobber spec.
But as a clean sorted café racer with a very smart paintjob it looks stunning! It's a shame you didn't get to try out the rear sets, they would have set it off very nicely (and I always wondered how you rode the thing in comfort without them). Oh and of course a spannie which I'm sure you were coming round to the idea of more and more!
All is forgiven though with your choice of new project bike, and I'm sure much fun is going to be had with the Yam, even if it does lack the charm and basic simplicity of the air cooled café racer stunner you have now.
Good luck with sale and your new 100mph GP replica though! |
RyanTZR125 |
robs321 |
robs321 Could Be A Chat Bot
RyanTZR125 |
The last post was made 8 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
