R1stu |
R1stu Shrek!
Ja7 |
Ja7 Crazy Courier
Alpha-9 |
Alpha-9 Super Spammer
R1stu |
R1stu Shrek!
Alpha-9 |
R1stu |
R1stu Shrek!
Nexus Icon |
Nexus Icon World Chat Champion
KLR600 |
KLR600 World Chat Champion
Posted: 13:58 - 16 Apr 2013 Post subject: |
I had one and ran it into the ground. I did put about 30k miles on it though and learnt a fair bit about bikes from it. Keep on top of maintaining the brakes, I went through a total of 5 calipers I think - 3 fronts and two rears. They're not hard to work on though and I rode through all weather and lived next to the sea so not exactly easy going on it!
The most I ever had out of mine was 118mph (on a private road) but it was absolutely screaming and was downhill with a tailwind! In the end the clutch thrust bearing ate itself and the bike was very tired by that point so I got the ZRX to replace it. ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
ChrisJ |
ChrisJ Two Stroke Sniffer
garth |
garth World Chat Champion
Posted: 16:59 - 16 Apr 2013 Post subject: |
For some bizarre reason I quite liked my old one. I've no idea why though, so it's probably rose tinted specs. |
sidewinder |
sidewinder World Chat Champion
Posted: 20:51 - 16 Apr 2013 Post subject: |
Same with mine i think it's because there so honest
Divvy tip: give all the breather pipes a good old clean out |
KLR600 |
garth |
R1stu |
R1stu Shrek!
R1stu |
R1stu Shrek!
Alpha-9 |
Posted: 12:40 - 21 Apr 2013 Post subject: |
Mines the best thing ever coming up from a 125
Nice to be able to get up to 70mph within a few seconds ____________________ Fzr-600 1999 |
There is a gap of 2 years, 90 days between these two posts... |
R1stu |
R1stu Shrek!
STONEY! |
STONEY! Brolly Dolly
R1stu |
R1stu Shrek!
sidewinder |
R1stu |
R1stu Shrek!
Posted: 10:13 - 03 Aug 2015 Post subject: |
Well a lot has been done this weekend! I have managed to get the mechanics together, and go her fired up, here is a breif rundown.
Well Friday all my pices I needed to get up and running had arrived.
1m of 7mm hose
1m of 6mm hose
1m of 4mm vacum hose
Fuelcap
Cable oiler.
I wanted to get the fuel line in purple, like the vacumn hose, however they did not do fuel line version of it. So instead I have the cotton coated version of the fuel hose.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0189_zpsorh9yd55.jpg
I drilled and hammered the old lock from the fuel cap. Unfortunate the other half lost all my keys to all of my bikes so I have to replace them all.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0190_zps24bfin8s.jpg
I removed all of the old fuel system the main pipes are ok, however I wanted to route them better and get the fuel filter somewhere more safe, and convienient.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0192_zpssxi9ap0g.jpg
New fuel cap is all fitted and looking good!
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0191_zpsvbf6ymnh.jpg
Started to put the carbs back on and plumb in the fuel system then noticed a small issue.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0193_zpss42bi42v.jpg
This engine was off a newer bike, so it was missing the vacum pipe for the fuel pump, and also the oil pipe in the cover for the carb heaters.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0195_zpsdybyvebp.jpg
So off to the old engine to remove the number 2 inlet stub and swap over.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0196_zpskllbsfrl.jpg
Um nice and yukky, so a quick clean off later and all better.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0197_zpssz3vkixn.jpg
So I fit this to the engine and then spend the next 10minutes trying to get the carbs on. I give up. Turns out the stumps are slightly different shape, so the new number 2 was ever so slightly out of alignment with the rest of the carb outlets. Another 30mins later. I have all the old ones off from the engine, and swapped over. Carbs go straight back on!
Next hour was spent measuring the hoses and working the best routing, I then hose clamped some of them, and the other that fitted nice already I put a couple of red cable ties on there to give colour burst.
I sorted the breather hoses and bolted the airbox on and routed everything.
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0198_zpsl3x5uwvz.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0199_zps8f9adchi.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0200_zpsxycmk7wd.jpg
https://i145.photobucket.com/albums/r232/stuartkeith/DSC_0201_zps0doq7ff9.jpg ____________________ Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished) |
R1stu |
R1stu Shrek!
sidewinder |
Posted: 00:36 - 05 Aug 2015 Post subject: |
His burnt orange divvy looked stunning ____________________ "Nitrous is like a cheap hooker, you want to hit it but are scared of the consequences |
R1stu |
R1stu Shrek!
Alpha-9 |
The last post was made 8 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
