HotdogMcDraw |
HotdogMcDraw Scooby Slapper
Posted: 00:42 - 05 Oct 2014 Post subject: |
I had a similar problem with my carb when the needle was sticking, reaked of fuel every time i started my old bike up.
Having said that, the drain screw is just above the overflow you mentioned, could be a bad screw that might need replacing? ____________________ https://www.bikechatforums.com/viewtopic.php?t=284963 - What to expect on a MOD 1 (contains video footage) - Posted by BG5067
Honda Rebel 125 (L Plate Warrior) - Nov 2013 to Aug 2014, BMW G650 GS ABS - Aug 2014 to Current |
Knacker |
Knacker World Chat Champion
Posted: 00:48 - 05 Oct 2014 Post subject: |
I posted a Video in May of it running quite happily and haven't touched the engine or carb since so I'm going to whip the carb off tomorrow and give it a clean.
And will also check to see if I have a spark ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Previous: K1 GSXR 1000 |
Knacker |
Knacker |
chris-red |
Knacker |
chris-red |
Knacker |
Knacker |
Knacker |
Posted: 10:56 - 10 Oct 2014 Post subject: |
Well Iv cleaned the carb again removed the jets and cleaned them set the fuel mixture screw to Haynes spec and set the float levels at 24.5mm.
Edit: Also sat the main jet in as it all looked a bit bodged so that's now set in properly.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-34.jpg
If this doesn't cure it then I really am stumped. ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Just_James |
Just_James Could Be A Chat Bot
Posted: 23:41 - 10 Oct 2014 Post subject: |
Some squiffiness of the spring is normal and is the tension of the cable just pulling the top to one side, it will sit straight enough once it's back in the carb.
That said, there does seem to be quite a bit of tension on that - have you checked that your cable is adjusted correctly, not got any snags or crimped parts etc that could be putting tension on it? Looking at that pic it seems the cable is heavily adjusted at the carb end - try winding the carb top back upto that lock nut and slackening off the tension.
Failing that, a thought of another possibility of your problem... although I don't know the specifics of that carb' most will only allow the slider to go in one way but others will let you put it in more than one way (i.e. the right way and a wrong way). Do you have full smooth movement of the throttle or does it feel like it's already part open?
I just remember messing with a mates MT50 ( ) field bike in my younger days when first getting into bikes and we had a problem with just your symptoms that had us stumped.... turned out we had put the slider in wrong so the alignment slots were in the wrong position and it was trying to start / run on pretty much full throttle
Just make sure the slider is going all the way down and that your throttle feels normal, if in doubt try it the other way about and see if its any different |
Knacker |
Posted: 20:14 - 12 Oct 2014 Post subject: |
Well thanks to mentalboy who came over and helped me today the bike is up and running again so the project may continue
Time to order a new caliper ____________________ Current: Gsxr 600 Srad - GS125 - DT125
slowlydoesit |
slowlydoesit Could Be A Chat Bot
Knacker |
Posted: 21:02 - 12 Oct 2014 Post subject: |
To be honest the carb was on and off so many times changing the components and double checking earths and throttle cable and choke etc
So glad to be able to get on with it again and it's all thanks to Mark ____________________ Current: Gsxr 600 Srad - GS125 - DT125
impulsive |
impulsive Two Stroke Sniffer
Posted: 21:55 - 13 Oct 2014 Post subject: |
you got yours running same time as me
https://vid.me/OLn |
Knacker |
Posted: 19:04 - 16 Oct 2014 Post subject: |
Just a quick question, When we got the bike running again it did seem a bit on the noisy side, now Iv got my old engine which used to run as sweet as a nut albeit 5 years ago.
In that time it has mainly sat outside without the inlet or exhaust port covered is it scrap or could it be salvaged?
If the latter would it require a top end rebuild first or at least a strip down?
In the mean time here's a picture of an Air Filter
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-35.jpg ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Knacker |
Posted: 16:47 - 19 Oct 2014 Post subject: |
Shall have an exciting update in about 2 hours ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Knacker |
Posted: 18:51 - 19 Oct 2014 Post subject: |
Knacker |
Posted: 11:33 - 22 Oct 2014 Post subject: |
Just_James |
Posted: 23:10 - 22 Oct 2014 Post subject: |
Looking good
Are they original? 50 ponds for the lot seems a bargain |
Knacker |
Posted: 10:24 - 23 Oct 2014 Post subject: |
Knacker |
Knacker |
Knacker |
Posted: 17:57 - 18 Nov 2014 Post subject: |
I know to most this wasn't the most exciting of Projects but I'm glad to have made this thread.
First of all I'd like to thank my mother for not swallowing me, I'd like to thank the Lord Jesus Christ for his insight, and of course myself because nobody congratulates themselves these days.
https://i210.photobucket.com/albums/bb259/Squeaky_86_2007/imagejpg1-40.jpg
It Haz pass! ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Just_James |
Posted: 11:05 - 19 Nov 2014 Post subject: |
Well done that man |
The last post was made 9 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
