jason3249 |
 jason3249 Nitrous Nuisance
 Posted: 13:58 - 29 Dec 2013 Post subject: what problems can a bad stator cause |
Hi all just wondering what problems can a bad stator cause
Thanks all.  |
WD Forte |
 WD Forte World Chat Champion
Islander |
 Islander World Chat Champion
 Posted: 15:28 - 29 Dec 2013 Post subject: |
Yep, this. ^^
You can test the output using the AC ranges of a multimeter.  |
WD Forte |
 Posted: 15:48 - 29 Dec 2013 Post subject: |
Just had alook for some pics
Heres a typical 'charge only' Bike stator
https://thumbs1.ebaystatic.com/d/l225/m/mSYmZ-IMwSmIsXYCzhIySYA.jpg
The first test I do is measure the resistance between all pairs of the yellow wires.
You want to see very low resistance between any pair < 1 ohm
and very high resistance between any wire and the stator body
which is earth or ground.
You want to see megaohms or off the scale here.
Anything in between is often suspect in my experience
If you can disconnect the stator when the bike is running
you can measure the AC voltage between pairs at tickover
and may get around say 20VAC.
This voltage will rise to possibly approaching 100VAC when you rev it
on a healthy stator.
This all depends on the size of bike and stator of course.
Testing and recording your results when its all going well gives you
a reference point for later if it starts to play up. ____________________ bikers smell of wee |
ZebraDriver |
 ZebraDriver Scooby Slapper
 Posted: 17:12 - 29 Dec 2013 Post subject: Charging Faults |
Came across this site the other day. It gives a very clear/concise description of how to find/identify charging faults
https://www.crowitis.com/images/fault_finding.pdf
If you can print stuff its probably worth printing it for the day when you do need it.......
ZD |
jason3249 |
 Posted: 18:41 - 29 Dec 2013 Post subject: |
Can a bad stator cause back firing and out the carb spluttering and the bike wont run right rev bog etc
Kickstart |
 Kickstart The Oracle
ZebraDriver |
jason3249 |
RhynoCZ |
 RhynoCZ Super Spammer
ZebraDriver |
RhynoCZ |
 Posted: 22:51 - 29 Dec 2013 Post subject: |
ZebraDriver wrote: | Nope. If it breaks down it can start to let more and more unregulated voltage through. When my reg/rect broke down recently I was measuring more than 18 volts across the battery. At that voltage things like the coil and ignition system start to malfunction, hence you can get shitty running, backfiring etc. It can also fry your battery
ZD |
Isn't the rectifier just a diode that lets the current go only ''one way'', so it changes it from AC to DC? So when the diode is busted, it won't let anything through, just like if cut the wire.
I might be wrong, as always.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
ZebraDriver |
ZebraDriver |
Kickstart |
 Posted: 17:22 - 30 Dec 2013 Post subject: |
Regulator / rectifier units tend to be combined and can fail in a few ways. I have had them stop charging totally, and also had them send the voltage too high (which can fry other components). Never had one fail and give out AC instead.
As to the pit bike, I would like to see a wiring diagram for that particular bike. My guess is that the stator includes the charging circuits and the trigger for the ignition. Could be worth trying a timing light on it and checking that the timing is correct.
MartQ |
 MartQ Two Stroke Sniffer
jason3249 |
 Posted: 13:30 - 01 Jan 2014 Post subject: |
It was the stator its running now you can ride it but does keep bogging and dying out some times at hight speed
But does start well now and idols fine revs up just bogs some times and at mid range
What you think on that
MartQ |
jason3249 |
 Posted: 18:30 - 01 Jan 2014 Post subject: |
All ready tried a new cdi been playing with the carb but cant get it any better
gone try the needle settings
Put new gaskets on the inlet manifold
Have played with the carb does get a little better but cant get it bang on
The last post was made 11 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
