Pete. |
Pete. Super Spammer
Posted: 21:30 - 30 May 2014 Post subject: |
How much did the fire-proof carpet cost? ____________________ a.k.a 'Geri'
Aff |
Aff World Chat Champion
Aff |
Posted: 11:17 - 31 May 2014 Post subject: |
OK, first batch of 50 charged.
I have changed my setup a bit. I spaced them out so much because it made it much easier to put together, the magnets are so strong that it is constantly tying to turn itself into a big ball of firey mess.
The downside of this is that I cant pass much current through the nickel strip and I dont have enough to layer t up over that distance.
The strip was hitting about 50 deg C at about 15A. So I spent some extra time and done this:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0605_zpsefbf12d1.jpg
This lets me put lots of layers of nickel strip to handle the current.
This has halved the temperature of the nickel strip:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0606_zpseae8ed79.jpg
Now I'm being held back by the croc clips. they get very hot above 15A and this charger is capable of 40A so I will try and do something about it so I can reduce my charge time. These amperage levels are nothing for the cells, they are all rated at about a 1C charge rate, meaning that this lot of cells can be charged at about 130-140A, so charging at 15A or even 40A is absolutely nothing to them.
These also turned up this morning:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0604_zps37be3e0a.jpg
Not so hopeful about these, but they were cheap and I have plenty of good cells now.
:edit: Changed all the croc clips to soldered on 10AWG wire, now changing at 25A, stip is at about 30 deg C. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
Aff |
Aff |
stevo as b4 |
Posted: 20:03 - 06 Jun 2014 Post subject: |
I like the trick new oversize disc!
Need to get a bigger disc on my Giant, as it's only a 160mm, which is a bit lacking at speed really. |
Gazz |
Gazz World Chat Champion
Posted: 23:42 - 06 Jun 2014 Post subject: |
This thread is fucking amazing. You are a genius!!!
Cant wait for more updates.
What was the box thing for? (I know nothing of batteries or physics).
TT Zero for you next year my friend. Mugen wont stand a chance. |
Aff |
KLR600 |
KLR600 World Chat Champion
Posted: 19:54 - 07 Jun 2014 Post subject: |
The bigger disc will definitely help but it's that Avid brake that is the main problem. I have 3 Avid brakes and they're all a bit rubbish once you really get going. For the kind of speeds you're going you should really be upgrading the brake as a whole. I'd look at something like a Shimano Saint or a Hope Tech 3. Yes they're expensive but I'd much rather have something like that on a bike that you'll be zipping around on at 40mph. ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
Aff |
Posted: 19:57 - 07 Jun 2014 Post subject: |
The actual braking force is fine, can still stoppie at most speeds (which I think is quite good considering all that weight at the back). It just has a ridiculous amount of fade.
I'm gonna give these a clean and a good bleed and see how things go. If not will have to upgrade. Cheers for the suggestions. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
KLR600 |
Gazz |
Aff |
MattWadz |
MattWadz Trackday Trickster
Aff |
G |
G The Voice of Reason
Posted: 10:34 - 08 Jun 2014 Post subject: |
If you wanted cheap, you could consider some sliding pin pit bike brakes - but chunky and you'd need to make a bracket etc.
But then, keeping adding more weight and you'll need more power. Which will need strong components. And... then you've got a pit bike, basically . |
chris-red |
G |
chris-red |
KLR600 |
Posted: 00:15 - 09 Jun 2014 Post subject: |
G |
KLR600 |
G |
400bandit |
400bandit World Chat Champion
G |
The last post was made 9 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
