BillyJ |
BillyJ Nearly there...
Aff |
Aff World Chat Champion
Fladdem |
Fladdem World Chat Champion
Posted: 18:12 - 05 Jan 2014 Post subject: |
Generic post to obtain updates. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Aff |
Posted: 18:18 - 05 Jan 2014 Post subject: |
Just done a bit of Googling, and yes it appears that I will have to leave the mains earth on the second PSU unattached to avoid a short.
This means that I will also have to isolate the cases. Some seem to recommend having a small neon light connected to the 2 cases to warn you if the cases become live. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
BillyJ |
Aff |
BillyJ |
Aff |
Aff |
Pol Anorl |
Pol Anorl Banned
Posted: 23:55 - 07 Jan 2014 Post subject: |
I see imminent failure unless motor is badass or you run some odd gearing system..
rear wheel weighs 9kg bike weight 12kg + battery weight-- single cell = 4kg + rider guess 76kg
101kg not including any extras.
if it moves at a speed worthy of using ill eat my hat. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
Aff |
Ste |
Ste Not Work Safe
Posted: 00:27 - 08 Jan 2014 Post subject: |
My rc car has 30 volts, laptop batteries are not going to be enough. |
Aff |
Pete. |
Pete. Super Spammer
Aff |
Posted: 20:53 - 11 Jan 2014 Post subject: |
OK started sorting out the PSU wiring.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0411_zps9cf896bf.jpg
Took a fair amount of faffing to figure out what combination of wires I needed to connect to make it turn on.
Including making this monstrosity.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0418_zps51ee2f10.jpg
I didn't have any power resistors so made this 30 ohm 24W thing, worked pretty well, but turned out not to be needed. These power supplies didn't need a load on on eof the rails to start, they needed to following:
The thin orange wire (sense) connected to the orange 3.3V rail.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0412_zps60b33bd9.jpg
Connect the Brown ("Power Good") wire to Ground:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0414_zpse57ede6a.jpg
And a switch for the Green (Soft Power) to Ground.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0413_zps95d3419b.jpg
The I just grouped all the 12V wires and the remaining Ground wires.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0415_zps90d1c8a1.jpg
Seems to be working fine.
I also changed all of my connectors over to Anderson Powerpoles. I really like them, they can be configured however you want with the little tabs on the side and they are neither male or female, I suppose you could call them asexual connectors? Makes them really easy to use, will definitely be using them in the future.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0417_zps69257f9e.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0416_zpsf82748a7.jpg
I also had to strip down both the batteries because they each had a dead cell. When a Li Ion cell dies it basically turns into a resistor, which all the other cells in parallel with it discharge though. This is usually why you see things like rechargeable drills and laptop batteries suddenly die, it is likely that all but 1 of the cells are fine, but they are just discharging through that 1 dead cell.
I'm not really sure of the best way to find them, I couldn't find any obvious differences using a multimeter, so in the end I stripped the batteries and charged all the suspect sells individually, I then put them on top of a fan to make them nice and cool, then left them on the table for half an hour.
I could then tell which ones were dead because they became warm (discharging itself through the internal short) whilst the others stayed cold. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
LongJohn22 |
LongJohn22 Trackday Trickster
Ste |
Ste Not Work Safe
Aff |
Ste |
Ste Not Work Safe
Posted: 21:09 - 11 Jan 2014 Post subject: |
Excellent news, will be interested to hear how the test ride goes. |
bladerunner |
Aff |
Posted: 18:21 - 12 Jan 2014 Post subject: |
Didn't get to test it today unfortunately.
The throttle they sent me has a smashed chip, so no way of fixing it or running the motor.
A new one is in the post but wont be here till Thursday.
Unfortunately I probably wont make much progress for the next few weeks as I'm away for work. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
dydey90 |
dydey90 World Chat Champion
Posted: 16:57 - 13 Jan 2014 Post subject: |
Should have used an Agni motor, like they do for the TT Zero
...Although they seemed to have some problems.
https://fayazkadir.files.wordpress.com/2009/11/mavizen_agni_95r3.gif ____________________ This post is probably not serious and shouldn't be taken literally.
Past: CBR125,ER6f NINJA 650, ZZR600 Current: VFR750 |
Aff |
dydey90 |
Posted: 10:20 - 14 Jan 2014 Post subject: |
JackDaniels |
JackDaniels Trackday Trickster
The last post was made 10 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
