Aprilia AF1 125 Replica - Full Rebuild - Updated 6-11-18
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
dransy
PostPosted: 22:13 - 17 Mar 2014    Post subject: Reply with quote
Ive got a right hand side fairing for that bike, same colours on my garage wall if you want it Very Happy
Phil_B
PostPosted: 22:41 - 17 Mar 2014    Post subject: Reply with quote
MissTamsin wrote:
fraggie wrote:
this should cause you jailtime.
Never use a screwdriver to split a case, you don't need much strength to damge the sealing edges..
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Rotax%20123%20Strip-down/8%20-%20Separating%20The%20Crankcases/PB282119_zps81ecdef4.jpg
I did wince a little when I saw that...
Taken from the rotax manual - see position 5, screwdriver splitting case using the provided splitting tabs Smile
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Mobile%20Uploads/image_zps344729c5.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Mobile%20Uploads/image_zpsa1e12b9a.jpg
Phil_B
PostPosted: 14:25 - 18 Mar 2014    Post subject: Reply with quote
Finally some photos with something positive Thumbs Up
Got hold of some replacement fairings and sub-frames, so did a quick rebuild with the parts just to check the fit before I made the first trip to the powder-coaters.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/image_zps21af6fb0.jpg
Took lots of brackets, the frame & sub-frames and the wheels to the powder-coaters. Beginning to look like they should belong on a bike instead of the rubbish tip!
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9172003_zps7ec080c9.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9172002_zps80297a36.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9172001_zpsd29dca03.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9172000_zpsad985c05.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171999_zpsa31dcb14.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171997_zps63c728f1.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171996_zpse801db56.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171992_zps6d6bafde.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171991_zpsd6d63156.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171990_zpsde2245f4.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171987_zps639b84b2.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171986_zps4e67423c.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171985_zps86d55237.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P9171984_zps123883ea.jpg
Did a partial rebuild to test as much of the electrics as possible, amazingly everything that I could try worked. I'm thinking of replacing as many of the connectors as possible just to refresh it a little.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/PA192006_zps562c9340.jpg
Got the tyres on and the front disc – need to get a spacer for the front wheel though as it’s missing!
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/PB042007_zpsed3ad2c0.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/PB042008_zps681ae20a.jpg
After the engine strip down, I sent the cases off to be powder-coated, not done in the original colours but it’s come up well considering how it looked before. It needs a few bits sorting before re-build.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122259_zps0f47c97d.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122255_zps618f4f30.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122254_zps84a095c1.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122256_zps073c1b33.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122257_zpsb900bd56.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Powdercoated%20Parts/P3122258_zpsaecca134.jpg
That’s where I’m at right now. Hopefully going to get my replacement forks stripped, bottom castings repainted, and new seals in the next couple of weeks. Then I’ll be dropping my cases off for new seals and bearings before I go on holiday, hoping they’ll be ready for when I’m back.
Tamsin
PostPosted: 15:04 - 18 Mar 2014    Post subject: Reply with quote
You really are cracking along on this. Really impressive rate of work!
Phil_B
PostPosted: 15:11 - 18 Mar 2014    Post subject: Reply with quote
Thanks, although this has been over the last 6 months really, just only got round to putting a thread together on here.
The updates now will be as they get done. The engine will go away for work to be done whilst I'm on holiday, that is the last of the big 'outside' jobs to be done. Hopefully it should go together reasonably quickly after that....just wish I had more spare time!
BenR
PostPosted: 13:12 - 23 Mar 2014    Post subject: Reply with quote
Nice work they are a labour of love. Will be following this one.
Phil_B
PostPosted: 13:30 - 24 Mar 2014    Post subject: Reply with quote
Cheers, has been a good project so far. I just hope it's as much fun as I remember!
This restoration is ruining my bank balance! Restoration project - 1991 Aprilia AF1 Replica
Yamaha R3
expat200
PostPosted: 10:52 - 25 Mar 2014    Post subject: Reply with quote
Phil_B wrote:
Seems to be a Rotax speciality, the old 4 stroke air cooled singles have levering surfaces between the barrel and head!
Matt B
PostPosted: 11:31 - 25 Mar 2014    Post subject: Reply with quote
This is coming along really nicely Thumbs Up
Phil_B
PostPosted: 16:44 - 25 Mar 2014    Post subject: Reply with quote
Thanks Matt Smile
Just put an order in to a place in Germany for some parts I've been unable to source elsewhere. Still a few bits to get, but I'm not far from having a complete bike again....even if it is all in pieces!
Yamaha R3
bandit_engineer
PostPosted: 20:45 - 25 Mar 2014    Post subject: Reply with quote
Keeping an eye on this!
Brings back memories of the RS back when i was 17.
Looking forward to the end product! Cool Mr. Green
Previous: 2002 Speedfight 50, 2000 RS125, 2002 RS125, 1997 Bandit 600N, 2003 SV1000S
Current: 2007 GSXR 750 (Isle of Man)
Phil_B
PostPosted: 21:37 - 25 Mar 2014    Post subject: Reply with quote
It's good to see some interest in this. I know it's not a big beast of a bike, but it had some pretty neat stuff when it fist appeared. The upside down forks and the single sided swing arm made it stand out. I think it still looks good now Smile
Yamaha R3
Tim..
PostPosted: 21:53 - 25 Mar 2014    Post subject: Reply with quote
Following Thumbs Up
www.marshallracing.co.uk
j.silvs
PostPosted: 15:35 - 26 Mar 2014    Post subject: Reply with quote
Following
At least you know the history of the bike from when it was new!
Phil_B
PostPosted: 22:47 - 26 Mar 2014    Post subject: Reply with quote
Started to strip the forks, found a stripped thread in the drain hole, will have to get that sorted at work!
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262266_zps41216023.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262267_zps1a0a5472.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262268_zpse7c86f7e.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262269_zps9c037bc1.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262270_zps84d8bd52.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262273_zps1c88f4e2.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262274_zpsb21e4ad2.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262275_zpsedeadf1b.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262278_zps32a54112.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262279_zps0864fce8.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262280_zps3906cc5a.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262281_zps8179b8d0.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262282_zps72a56cc8.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262283_zpscd1581fe.jpg
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P3262284_zps1f1069c5.jpg
Still got the other fork to strip, then I'll be repainting the bottom castings, fitting new seals, scraper, and I've also got some protectors to go over the chrome.
Yamaha R3
_mjs_
PostPosted: 04:58 - 27 Mar 2014    Post subject: Reply with quote
Just seen this for the first time, amazed at the difference a bit of powdercoat has made to those bits Shocked
Phil_B
PostPosted: 09:22 - 28 Mar 2014    Post subject: Reply with quote
Parts arrived from Germany, great, fast service Smile
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/image_zpsb548baf5.jpg
Yamaha R3
PostPosted: 18:28 - 28 Mar 2014    Post subject: Reply with quote
Who was the supplier in Germany?
mintex
PostPosted: 19:55 - 28 Mar 2014    Post subject: Reply with quote
+1 please tell lol Very Happy
Phil_B
PostPosted: 20:02 - 28 Mar 2014    Post subject: Reply with quote
I got the parts from here....
https://www.centroricambi.de/index.html
You'll have to translate the site as its in German, Google Chrome does a good job of most of it. He has spares for the AF1s and RS, not all the parts you may need are available, not sure if its Aprilias old stock or he still gets stuff made. As I don't have much experience with bike parts I don't know how it rates price wise, I was just thankful I could find the last few bits I needed.
You can pretty much work out what you need from the assembly drawings on the pages, worth a look if you're stuck for anything Very Happy
Yamaha R3
PostPosted: 20:28 - 28 Mar 2014    Post subject: Reply with quote
If you know the part numbers (I have the part lists here) then some are still supplied by Aprilia. Can find some here:-
https://www.apriliagenuineparts.co.uk/
although never ordered from them so don't know how good they are.
BenR
PostPosted: 12:52 - 05 Apr 2014    Post subject: Reply with quote
Any updates?.......c'mon chop chop you slacker. Laughing
Phil_B
PostPosted: 17:06 - 05 Apr 2014    Post subject: Reply with quote
Laughing The only update is I've fixed the stripped thread in my fork leg. Not had much spare time due to studying for my Divemaster exam. I'm dropping the crank, engine cases and barrel off at PJME on Wednesday. All the work should hopefully be done for when I get back from my holiday, then I can get the engine rebuilt.
It's slow going due to lack of time, but I'm not in any rush. I want to get it looking the best I can when it's finished Smile
Yamaha R3
Phil_B
PostPosted: 20:40 - 08 Apr 2014    Post subject: Reply with quote
Stripped the other fork and found an odd part inside, the one on the left is from the first fork, the one on the right from the second. I can only guess that in a previous strip the owner lost the original metal part, and thought it would be ok to replace it with a cut piece of plastic from something….the things people will do! Looks like I will have to strip my original forks to replace the bodged bit.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Stripdown/P4082286_zps5481eda6.jpg
All the cases, crankshaft and barrel packed ready to drop off at PJME tomorrow.
https://i1344.photobucket.com/albums/p655/Aprilia_AF1_Replica_Rebuild/Aprilia%20AF1%20Replica%20Rebuild/P4082285_zps2edeb32c.jpg
Yamaha R3
Shreeve
PostPosted: 22:09 - 08 Apr 2014    Post subject: Reply with quote
Love picture heavy restorations!
I agree with the comment about a little powder coating making it look amazing Smile
Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4
The last post was made 10 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.91 - MySQL Queries: 17 - Page Size: 148.55 Kb
