slowlydoesit |
slowlydoesit Could Be A Chat Bot
Kickstart |
Kickstart The Oracle
Posted: 17:56 - 09 May 2014 Post subject: |
Not sure how much benefit you would get from just swapping the caliper to a 4 pot one. Twin pot sliding calipers have some advantages (they are stiffer generally - not really an advantage over the 4 pot Yamaha blue spot calipers).
You still would have the smaller disk. Bigger disk gives more heat dissipation, the disk is moving more quickly over the pads at any given speed generating more heat, plus possibly the caliper has more torque on the wheel (not that certain on this).
slowlydoesit |
Posted: 21:55 - 10 May 2014 Post subject: Re: Brakes done, sticky carb, slow rev counter |
slowlydoesit wrote: | Next step is to clean and rebuild the carb. |
A wet and very windy day in West Wales, made all the more obvious by the hilltop location of the workshop in which the KMX currently sits. The carb refurb kit arrived safely and seemed to have all the bits. While my friend worked on his car, I removed the carb from its mountings and started to strip it. Taking off the float bowl was complicated by the ruined heads of the existing screws but we muscled them off anyway with a molegrip-type tool.
Inside the carb was in pretty good shape. There was some crud in the float bowl, but nothing major. I cleaned it out with carb cleaner, a toothbrush and blasts from the compressor. (Apologies in advance for variable quality of pictures!)
Before:
https://i.imgur.com/mlEpy2r.jpg
After:
https://i.imgur.com/XjcZx6Q.jpg
The body of the carb was similar - mucky but not too bad. We replaced the main jet and most of the other components and cleaned it up a bit.
Before:
https://i.imgur.com/shgI0bN.jpg
After:
https://i.imgur.com/37HbRmc.jpg
I checked the float height, which was spot-on at 21mm. Then I put the carb back together. Thanks to my mate's stocks of useful odds and ends we were able to use new allen-headed M4 bolts to reattach the float bowl. At one corner the bolt interfered with the mixture screw, being just a bit too long. I took the bolt off and screwed a nut on the end leaving just a few millimeters of the bolt sticking out. I put the bolt and nut combination in the vice vertically so that the head of the bolt and the nut were both gripped and hacksawed the protruding bit of the bolt off by cutting horizontally. Then I unscrewed the nut to leave a clean thread. Worked fine.
https://i.imgur.com/zpgIhf3.jpg
Then I put the carb back on the bike. Getting the throttle cable through the throttle valve while holding the spring and the retaining clip in took me ages. The spring got away from me a couple of times and I got paranoid about the spring exploding out of my fingers and into my eye. A pair of safety glasses made me more confident, but I escaped unscathed anyway.
Eventually I got the job done by compressing the spring into the throttle cap and holding this in one hand with the throttle cable sticking out, then poking the cable UP through the hole in the throttle valve, which I was holding inverted in the other hand. Well, I guess you had to be there.
When I had finished the valve didn't initially slide into place - it had to be prodded before it snapped shut - but that didn't strike me as a problem.
So, we put more petrol in the tank, took the bike outside and bump-started it. It ran fine once we had sorted out the idle, so we bumbled around the garden. It was very slippery on the wet grass and moss and I almost had an embarassing moment when the rear wheel slid, then gripped suddenly. A vision of myself highsiding at 10mph flashed in front of my eyes - oh the shame! Fortunately I didn't come off.
Then we noticed that every now and again the throttle wasn't returning properly, leading to runaway revs. Sticky throttle cable? Throttle valve slide sticking? Probably the latter.
Then when we put it inside a little petrol came out of the overflow again, the same symptom as last week. Disappointing in one sense but a productive day in another - at least we've taken a peek inside the carb and we know that the new parts should be fine. For me it was an educational few hours, as I haven't stripped a carb for twenty years.
Next week we'll take the carb apart again and have a closer look to see what we might have missed. ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
slowlydoesit |
Posted: 09:09 - 15 May 2014 Post subject: |
Just to recap, I bought the bike with an aftermarket expansion chamber (probably Big One brand) and two silencers, a DEP and an OEM Kawasaki silencer, but it's the silencer for the KMX125 not the KMX200. Frankly even with the OEM silencer the bike sounds horrible, not just two-stroke loud but harsh and buzzy.
Based on advice in this post from dangerousdave, who's already been through the whole "how can I get a better exhaust" cycle, I decided to try to get an OEM KMX200 pipe and silencer. After a little googling it looks like I may have been able to source one of each, but it will be a week or two before I take delivery and can check the quality of the items. The silencer looks okay other than a little dink on it, the pipe also looks all right, bit of surface rust but claimed to be otherwise fine.
The perils of buying on auction sites.
https://i.imgur.com/qCU5nPE.jpg
https://i.imgur.com/OFy6yop.jpg ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter
dangerousdave |
dangerousdave Traffic Copper
slowlydoesit |
slowlydoesit |
Posted: 20:52 - 17 May 2014 Post subject: Re: Brakes done, sticky carb, slow rev counter |
slowlydoesit wrote: | Next week we'll take the carb apart again and have a closer look to see what we might have missed. |
Well, it's not clear what we missed but to begin with the conclusion, the bike is no longer pissing petrol everywhere and I'm going to book an MOT next week.
An absolutely glorious day here in West Wales and a nice drive over to my friend's workshop. About five minutes from his house I come up to a shallow junction on a back road and see a bike coming down the hill with a car behind it. The bike peels neatly off the main road into my side road - and promptly loses both wheels on the sheet of gravel that covers the centre of the junction. As it does so, I realise that the face behind my visor is that of my friend. Somehow he controls the slide, recovers, and zips off down the road behind me. His hoon was nearly over before it started.
While he's out I take the carb off the KMX and strip it again. I look thoughtfully at the pieces of the carb refurb kit that we didn't use last week. There is a mystery rubber O-ring that doesn't seem to have a place, a float valve and a tiny circlip for the needle jet. We didn't use that as the existing circlip seemed fine.
https://i.imgur.com/2ygCRck.jpg
We didn't use the new float valve partly because the old float valve looked good enough to use. There is some wear on it, but very minor and not enough to change the form factor of the component. Still... I whip off the float pivot pin, remove the float and have another look at the old float valve.
https://i.imgur.com/C3QdCjk.jpg
As I'm comparing the old and new float valves, my friend comes back from his ride, parks up the bike and bustles up to the workbench. He has another look and notes that the new float valve doesn't have a little spring on it like the old float valve - that's the other reason we didn't use the new valve last week. The little spring on the old valve goes over a tang on the float and is what opens and closes the float valve. Not only does the new float valve not have a spring, it doesn't seem to have anywhere to attach a spring. Have we dropped the spring? Quick search on hands and knees. No. Nor do we remember ever seeing one. I don't have a good picture of the new float valve, but you can see it blurrily in the image below.
https://i.imgur.com/oSurGh0.jpg
My friend prods the tiny nub on the end of the new float valve and realises that it's spring loaded. One end has the tip that seats in the carb body, the other end has a sproingy bit. So with that in mind, do we even need a spring like the one that on the old float valve? We reason that the valve can't fall out once the float is in place, even if there is no spring attaching the valve to the tang of the float. Hmm. We decide to reassemble using the new float valve.
Back together goes the carb, in goes the needle into the throttle slide. While replacing the carb, my mate uses cable ties to compress the spring under the carb cap until he's managed to thread the throttle cable through the body of the slide. This works well - should have thought of this myself. Once he's done that he goes back to work on his bike. I faff around getting the inlet and outlet rubbers back on the carb, then reattach the choke and the fuel pipe.
We turn on the ignition and it starts second kick. Nice. The carb no longer leaks petrol. We take it in turns riding round the garden and field and agree that it's idling a lot better now. It's smoking quite a bit but not worryingly so - probably needs a good run.
I will book an MOT for the end of next week. The front brake may need another bleeding before then - it's still not very good. Hopefully it will get me through the MOT. Beyond that, I have ordered the brake upgrade kit described in this post and that may make a difference to braking performance. ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
slowlydoesit |
stevo as b4 |
Posted: 23:18 - 18 May 2014 Post subject: |
Hi Mate, If your VM26 is knackered, you should find any other VM26 can be jetted the same, and a lot of the differences in sub types as you describe it are often for things like carb mounted choke vs remote choke, and handed carbs where everything is on opposite sides etc. Nothing insurmountable I would say though if you found a new carb cheap, with such differences.
Can I ask a favour when you remove the Big one/Fresco pipe to fit the OE one? If you can take some external measurements of the header pipe diameter, the belly section, and the stinger diameter, I could do the same and compare my 125 pipe, just to put to bed if the Fresco KMX 125 and 200pipes are the same volume and shape etc.
My 125 pipe is coming off after running in and once it's been on the dyno for a power run and fueling check. If it performs well then I'll get it shot blasted and plated, but if not I'll be trying another pipe to compare performance wise. |
slowlydoesit |
slowlydoesit |
dangerousdave |
slowlydoesit |
dangerousdave |
Posted: 23:36 - 30 May 2014 Post subject: |
I remember when I bought this second KMX, the front brake was damn near seized. I mucked about with it a lot, rebuild, new pads etc. It was better, but never great.
I seem to remember the brakes being ok back in the day, but then I'd just ridden bikes equipped with drum front brakes. After a decade on Japanese sports bikes which offer blistering braking, the kmx's front brake seemed scary in comparison.
There is a lot to be said for gentle braking off-road, especially for novices. Don't want to loose the front end and all that. However, especially on the road I want to know I can stop quick if the need arises!!
One of the by products of swapping the front end is the improved braking. I can't fault it. Makes the knobbly squirm all over the place on tarmac, will be great when swapping to road tyres. People may say I have taken away the original spec of the bike, but it's not about that for me.
I hope your 2-pot caliper gives a good boost to the braking
At the very least, being a brand new part, it will work perfectly out of the box so won't have the faults associated with a used part. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
slowlydoesit |
Posted: 09:44 - 05 Jun 2014 Post subject: New expansion pipe |
The expansion pipe arrived from Japan. It has surface rust, but otherwise it looks in pretty good condition. This is probably the most important part for me, as I really dislike the noise the KMX is making with its aftermarket pipe. I guess I should decoke before using...
https://i.imgur.com/e5mzffK.jpg?1
The worst of the rust? Wire brush needed.
https://i.imgur.com/uf6Hyl5.jpg?1
Rust-coloured but doesn't look deep:
https://i.imgur.com/ErD5cfH.jpg
Looks solid:
https://i.imgur.com/GnGyXtJ.jpg ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter
slowlydoesit |
slowlydoesit |
Posted: 09:58 - 05 Jun 2014 Post subject: Tokico 2-pot |
As discussed earlier in the thread, here's the Tokico caliper with two pots. Brake pads were included in the deal. In the second image it almost looks as if those pistons have been inserted upside down! Nice of them to include copper washers for the banjo bolt. I'm hoping that when I get round to fitting it everything will go smoothly...
https://i.imgur.com/rKBDdSi.jpg
https://i.imgur.com/BzijklJ.jpg
https://i.imgur.com/5nWAHTk.jpg ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
stevo as b4 |
slowlydoesit |
stevo as b4 |
dangerousdave |
slowlydoesit |
Posted: 07:58 - 12 Jun 2014 Post subject: |
Apparently my tank has sprung another leak. I will have to check it at the weekend. I have seen lots of KMX125 tanks on Ebay but not many KMX200 tanks. Does anybody know if the KMX125 and KMX200 tanks are interchangeable? ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
dangerousdave |
slowlydoesit |
Posted: 20:40 - 15 Jun 2014 Post subject: Baby steps |
Not much good news despite working on the bike this weekend. It was really just a process of eliminating things one by one.
My friend welded the pinhole in the tank that I previously filled with putty and did a nice job of it. I then sprayed the bare patch on the tank with rattle cans and it looks fine. At the least it will prevent rust for a while.
We added the new brake caliper, which seems to work well.
I replaced the o-ring and other parts in the fuel tap.
The new exhaust I was worried about, but when it came to removal it came off easily, perhaps because I doused the bolts in Plus Gas a couple of weeks ago. The new exhaust is, as advised, comically heavy compared to the one I took off. It sounds much, much quieter as well and that's a good thing.
Unfortunately the problem with the revs running away is still not fixed. It doesn't happen always, just every now and again. I bought a fuel filter to exclude the possibility that crud in the fuel is getting trapped in the carb and preventing the float from returning smoothly but the filter turned out to be too large to fit in the space between the tank and the carb. So. Looking for a smaller filter. Might also try to strap the big filter somewhere close by and run longer fuel lines to the tank from the top of the filter and to the carb from the bottom of the filter.
Also ordered a new spark plug, just in case.
Ho hum. I'm making progress but it's slow, and the summer is passing by. This is why I advise people to buy new. ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
slowlydoesit |
Posted: 18:19 - 21 Jun 2014 Post subject: Re: Baby steps |
Well, I think I found the cause of the flooding carb. I went over to the workshop this afternoon and attached a new, smaller filter inline between the tank and the carb with some new 6mm fuel hose, like so:
https://i.imgur.com/swMaI23.jpg
Then I started it. When I turned on the fuel and started kicking I smelt petrol. Looking down I could see that the carb had overflowed once again and fuel was trickling on to the floor. I rapped the side of the carb and it stopped. I went back to kicking and it started, initially with some smoke. Then it settled down and I revved it a little while watching the rev counter. There was no sign of the revs running away as they had been doing. Rev the bike and the tacho needle swings round, release and it swings back. Good. I took it for a few laps of the yard and it was tractable and running well. I stopped and watched the exhaust while I revved it. No smoke. Then I got off the bike and checked the fuel filter, to find this:
https://i.imgur.com/0WuMQot.jpg
I don't know what that sludgy stuff is, but this was the result of the engine running for five minutes. Initially it was white-ish but then turned brown. Once I saw this I called it quits for the day because the fuel filter would have filled with that crud had I kept going. I was hoping for a ride today, so that's a pity.
So, stuff is coming out of the tank. My hypothesis was that flakes of rust or metal were getting into the carb and jamming the float open and that's why I wanted a fuel filter with a see-through body. I seem to have been half right: it's not metal, as far as I can see, but it's something. The filter seems to be cleaning the fuel and in doing so stopping the racing engine problem, while the smoke from the exhaust has largely disappeared. (Previously it kept smoking while running - perhaps it was burning that crap that was creating the smoke?) All in all, a promising step forward.
I'm considering my next move. If I want to do a proper job I could empty the tank, wash it out, treat it with something to clean it all, then do a POR15. On the other hand, if I can get a good secondhand tank it would certainly be easier, more reliable and may be not much more expensive to just replace the tank.
Oh, here's the new brake caliper on the bike. Looking fine.
https://i.imgur.com/EETuelo.jpg
And the tank after repainting the bare patch with rattle cans last weekend:
https://i.imgur.com/Z2ac0nR.jpg ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
The last post was made 9 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
