Kickstart |
Kickstart The Oracle
slowlydoesit |
slowlydoesit Could Be A Chat Bot
Kickstart |
slowlydoesit |
Kickstart |
slowlydoesit |
Kickstart |
gavcarter |
gavcarter Could Be A Chat Bot
slowlydoesit |
gavcarter |
slowlydoesit |
slowlydoesit |
dangerousdave |
dangerousdave Traffic Copper
stevo as b4 |
slowlydoesit |
Nexus Icon |
Nexus Icon World Chat Champion
slowlydoesit |
Posted: 19:00 - 06 Jul 2014 Post subject: Tank fixed but now stutters at higher throttle openings |
More glorious weather in West Wales. I cruised over to the workshop and did some work on the KMX. The new tank is on and seems to work fine. The graphics clearly don't match the bike, but it'll do for now.
https://i.imgur.com/H0YWi5L.jpg
The blu-tack has been removed and the rattly thing, which turned out to be one of the inlet pipes for the fuel tap, was hooked out with some welding wire. I took the bike for a spin and found that the engine no longer has the problem of racing at higher revs, which has been a concern. As per the pictures above, there seemed to be a white paste (perhaps from the treatment that was given to the previous tank?) contaminating the carbs and that at least seems to have stopped. It no longer smokes like it used to and it starts easily. So far so good.
On the other hand, when I wind open the throttle from mid-range on - about 5,000rpm, but varies - the bike stutters and won't rev to the top of the range. The actual rpm at which this happens depends on the gear, so sometimes it happens at around 4k and sometimes at 6k. I'm thinking that although I have a new(ish) tank and fresh petrol, the sludgy petrol from the previous tank may have contaminated the carb and be causing a sticky main jet. I have already stripped the carb twice, but that was before I realised that the residue from the old tank was the problem.
Continuing (but different) fuelling problems aside, it was a good day. I rode the bike for a few miles along country roads and it felt pretty good to be cruising around in such great weather. Bike is well balanced and easy to ride, though I'm having a few problems getting used to the lack of engine braking. I think the clutch could do with some adjustment as it feels to me as if you have to pull it back a long way to change gear, but that's something for the future. ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
dangerousdave |
Posted: 17:26 - 10 Jul 2014 Post subject: |
Stuttery running does sound like muck in the carb.
Be interesting to know if it responds the same immediately after the carb had been cleaned and the jets blown out with compressed air.
If performance is the same after this, same stuttery running then check your jetting. Somebody may have altered the jetting from the original spec when the Big One exhaust was fitted. Look at the needle clip position, believe it should be on #2 for standard setup. Then check the main jet size, this should be #112.5.
Check the air filter is clean and lightly oiled also. The spark plug may need a clean/replacement, they are cheap anyway.
Hope that solves it. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
slowlydoesit |
dangerousdave |
Posted: 05:27 - 17 Jul 2014 Post subject: |
These two-strokes can be a little finicky, unless the set-up is perfect, they won't run right. Its good you now know the jetting is correct, for the standard set up.
Good shout on the coil, didn't think of that myself.
Old filters can cause rough running if they are limiting air flow. Spark plugs can cause problems as well if the gap isn't right or if there is a carbon build up. I clean the plug regularly.
Any air leaks between the carb and the air box will throw the jetting out. Be worth checking if anything obvious, tears in the rubber, cracks, or fastenings which aren't tight or no longer sealing.
Any leaks around the near side KIPS resonator cover? The threads can go causing a proper seal on the cylinder to be impossible. If this is leaking it may have trouble below 6,000, as it will loose compression.
Finally, any leaks on the exhaust? ____________________ 1988 Kawasaki KMX 200
slowlydoesit |
Posted: 03:35 - 06 Aug 2014 Post subject: HT coil conundrum - any advice? |
Now I have a problem with the HT coil I bought to see if it would cure the stuttering issue at higher revs. Partly my fault: I should have looked at the existing part and taken a photo before ordering the new part. Basically, the existing HT coil was fixed to the bike with a bolt that passed at 90 degrees to the frame rail through a lug. The new HT coil has a hole that runs parallel or in line with the frame rail.
There's no way it will fit, though I could bodge it by securing it with a cable tie. Would that work or does the coil need to be earthed on the frame? The old coil has no metal in the mounting hole, so I guess it can't be earthing.
And why the hell would the mounting holes be different? A search on Ebay for "KMX HT coil" bring up both types. Why would that be? Something as basic as a frame lug surely wouldn't change over time would it?
https://i.imgur.com/IhiSTuw.jpg
We also seem to have inadvertently destroyed the spark plug cap when we pulled out the HT coil cable, which was secured to the plug cap with a screw and two washers (see below). The plug cap seemed to contain a resistive element of some kind, which is the red part in the picture. Is that normal?
https://i.imgur.com/Vq4WGWR.jpg ____________________ Kawasaki KMX200 with broken fixed powervalves and a stutter |
Bunny Lingus |
Bunny Lingus Traffic Copper
gavcarter |
dangerousdave |
blurredman |
Posted: 19:08 - 06 Aug 2014 Post subject: |
If the spark plug is resistored (which most are now) you can discard the resistor in the cap. You only need 5k ohms to adhere to law etc, 10k ohms is just reducing your spark unnecessarily.
It is thought as good practice now, to integrate the resistence into the spark plug therefore changing both at the same time, and less issues with degredation, contact clenliness and availability of resistors in the caps. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k |
The last post was made 9 years, 265 days ago. Instead of replying here, would creating a new thread be more useful? |
