Today I did: Fork straightening at home
gavcarter
PostPosted: 18:53 - 30 Jun 2014    Post subject: Today I did: Fork straightening at home Reply with quote
Just a quick one, a mini project if you will.
First thing I did was knock up a big lever press, just using junk I have stashed away for just such days Laughing
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140629_202917_zps7bcc7631.jpg
You can see it is opened right over itself in this pic, the lever travels through 180 degrees ( and then some more) to allow the pushing block right out of the way of the fork leg, with out the need to hold it off the leg.
Its worth noting rawl bolts are your friend and this will need fastening down.
There is a V block at either end of the steel bed, I made these out of thick wood, but steel would be better - i didnt have and suitable steel so went with wood.
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140629_202929_zps3545dfda.jpg
A magnetic based dial indicator is set up on the leg and the leg turned 360 degrees to find the high spot, I took about 5 measurements down each leg length to find the "middle" of the bend. The middle of the bend is positioned directly under the pushing block with the high spot facing up.
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140629_202951_zps03b97764.jpg
The block lowered onto fork, only move the dial indicator as little as possible and zero it, it wants to be as close to the bend as possible and still able to read the fork leg.
https://i1072.photobucket.com/albums/w375/gavcarter12/IMG_20140629_203005_zpsfef994a9.jpg
Now you push like mad and hope you've made your lever long enough!
I counted the dial round as I pushed by leaning over it, but it would be a lot easier if an assistant could read them out to you!
When measuring the run-out, you turn the fork leg until the indicator is at its highest reading, take a note then turn to its lowest reading and take a note. The run out is half the difference between the two:
Example
Indicator reads 0.10mm and 0.78mm you have a difference of 0.68mm - the total run out would be 0.34mm
This is why its easier to zero your indicator each time.
I started by bending an equal amount in the opposite direction. I had approx 0.8mm of runout so I pushed the leg 0.8mm the other way.
This made NO DIFFERENCE
SO i went to 1.6mm NO difference...
I just kept increasing by 1 mm until i could measure the bend as being reduced. This didnt happen until I had applied 7.5mm of travel in the opposite direction of the bend! And i still had some to go!
In the end I think I applied around 8.4mm travel against the bend, but I am unsure how much of this is due to the wooden V blocks ( they will compress under strain ) and how much is the natural "spring" of the tube - so go careful and ALWAYS measure twice.
When the bend is almost out, you will have to move the pushing block right out of the way and measure right at the arc of the bend to check run out.
When you think your finished, transfer the V-blocks, leg and dial indicator to a known flat surface ( kitchen worktop etc) and re-measure the leg, I took a good 5 or 6 around the bent area, a measurement each end and a couple in between.
Your run-out is always the highest one, if you have 0.5mm run out in the middle and 0.01mm near the end the run-out is 0.5mm
Both of my stanchions were bent, I got one to 0.05 -0.06 ish mm and the other is about 0.03mm
** DISCLAIMER This post is for information purposes only, professional services are around £80 for a pair ( pre-stripped ).
If you follow ANY information in this post it YOUR responsibility to check its safe and do-able.
ride_to_die
PostPosted: 10:56 - 01 Jul 2014    Post subject: Reply with quote
You got skillz Thumbs Up
I'm not here for a long time, I'm here for a good time.
The last post was made 9 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 36.65 Kb
