_Iain_ |
_Iain_ Banned
bikertomm |
bikertomm World Chat Champion
_Iain_ |
_Iain_ Banned
Posted: 16:23 - 27 Nov 2014 Post subject: |
stevo as b4 |
Posted: 21:30 - 27 Nov 2014 Post subject: |
Id be more than happy with a real 48mph on the flat from a Chinq 50cc!
You might find a fraction more speed or acceleration with the aftermarket variator especially if it has a greater range of gearing than the std one has.
Getting clutch's to bite at high enough rev's seems to be a common problem. I found changing springs on the Speedfight made probably no more than 200-250rpm difference to engagement, where really I wanted another 1500rpm or so before moving away.
Those adjustable race clutches seem to be the way to go for this, and they don't rely on changing springs to set them up for different engagement speeds AFAIK. |
evoboy |
evoboy World Chat Champion
Posted: 22:17 - 27 Nov 2014 Post subject: |
If its any good, I think I still have a race clutch left over from the NRG build. Itll fit the Chinky motor and weighs about half of the standard one. It is set to engage at fairly high RPM mind! ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
P. |
P. Red Rocket
_Iain_ |
_Iain_ Banned
evoboy |
Tamsin |
Tamsin World Chat Champion
wr6133 |
wr6133 World Chat Champion
P. |
P. Red Rocket
Posted: 09:29 - 28 Nov 2014 Post subject: |
Nah just the R, the RR is water cooled |
_Iain_ |
_Iain_ Banned
Posted: 10:16 - 28 Nov 2014 Post subject: |
Tamsin wrote: | I kinda question how long it will last but I'm learning a fair bit here! |
Well it would seem the breaking point of the chinese transmission is around where we're at now. However Evoboy has a clutch, and I've picked up a fancy variator so with both of those fitted we ought to be onto a winner! With scooter tuning you seem to replace every component bar the crankcases anyway, so I figure it ought to be nearly as quick & just as reliable as every other tuned scoot out there after the motors finished. At the moment it holds about 7500-8000rpm once you're moving, and flat out spins to about 10500rpm which on the top speed attempt pictured meant holding it at that sort of speed for well over a minuite. With no gearup kits availible and the variator unlikely to make a massive difference in final drive ratio it's going to have to be able to hold masses of revs for a sustained period. If it fails, that'll be when - I'm sure of it.
Will post lolpics when it does throw the conrod
evoboy wrote: | If it is, it will be a far better base for tuning. |
Apparently ditching the fan on an air cooled motor is good for 1-2hp on a tuned engine, however it'll kersplode if run for any length of time. But it does prove how much more efficient water cooling is!
Edit: Also, worth noting at this stage I feel is the fuel consumption. It guzzles it like it's going out of fashion. My KTM uses less fuel when ridden hard. It's used nearly an entire tank of fuel (£5.20) in around thirty miles, (although this is with an 18st rider, headwinds & huge uphills) I'll be installing a 2nd tank in the helmet storage that doesn't actually fit a helmet. When fitted with a huge carb it's just going to make the MPG worse, currently I suspect the main is somewhere in the 54-60 range. When fitted with a 70cc kit, 21mm carb and sports pipe most of the local lads seem to be running 100-115 mains
Edit 2.0: Just another sudden thought - With the big variator conversion, do I want it to be running 3.5 with the new variator/torque spring (Doppler supply one) or do I need to be heavier, lighter or what? Rollers were bang on before at 3.5gr 15x12, Doppler variator converts it to 19x15.5 ____________________ Please be aware that the above post may be full of complete nonsense.
Riding: '07 KTM Duke II, Baotian BT49QT-20 Driving: '88 Volvo 340 |
Nobby the Bastard |
_Iain_ |
_Iain_ Banned
_Iain_ |
_Iain_ Banned
Posted: 21:21 - 29 Nov 2014 Post subject: |
Its dead.
One of the mains shat itself in a big way at about 35mph on road test. It still ran enough to get it home...was nearly there anyways as it felt rough as anything from the moment I hit full throttle.
https://youtu.be/4Swn2U2mEfk
Oh well, race crank & 70cc top end time. Will pull the engine tomorrow & relocate it in the kitchen ____________________ Please be aware that the above post may be full of complete nonsense.
Fladdem |
Fladdem World Chat Champion
Posted: 21:43 - 29 Nov 2014 Post subject: |
Ha. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
UnspeedySam |
UnspeedySam World Chat Champion
Tamsin |
_Iain_ |
_Iain_ Banned
Tamsin |
evoboy |
Posted: 22:10 - 01 Dec 2014 Post subject: |
The Athena HP Kit is very good for the money. The HPR is probably too much for that bike. I raced the NRG against pitbikes and it was pretty pointless as it just pulled big power wheelies everytime you got on the throttle. ( If you let go of the throttle, the gearbox 'gears down' so as soon as you get back on it, your in a lower gear and the front is back up in the air )
But I thought the HP kit was also single ring piston, just with less aggressive porting? Also make sure you read the instructions on setting the 'squish clearance' exactly as it is vital its done correctly. Also it would definatly be worth matching the ports on the crankcases to the ports on the cylinder.
I ran one of these cranks in the NRG.
https://www.adrenalin-pedstop.co.uk/p-SLine_Evolution_crankshaft_for_Yamaha_Aerox_50_Jog_R_Neos_2t-6281.aspx
For the money I was very impressed with the quality.
I do also still have an Italkit Seletretta Inner rotor ignition kit which made the engine rev up like a motocross bike. But the backplate is for a Piaggio LC engine. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
Just_James |
Just_James Could Be A Chat Bot
Posted: 01:13 - 02 Dec 2014 Post subject: |
Is that a quilted divider behind the coffee table?
What happens behind there? |
_Iain_ |
_Iain_ Banned
Just_James |
Posted: 11:21 - 02 Dec 2014 Post subject: |
Fladdem |
Posted: 23:52 - 04 Dec 2014 Post subject: |
Shit Son! Why's Iain banned? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
The last post was made 9 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
