Shreeve |
Shreeve Scooby Slapper
Posted: 21:26 - 28 Jan 2015 Post subject: |
I'm thinking of stripping it back but not sure how, apparently Nitromors is now rubbish and I only have a dremel as far as powered sanders go.
They really do look bent!! I can assure you they are straight, some weird camera trickery ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4 |
Shaft |
Shaft World Chat Champion
Shreeve |
Posted: 16:35 - 29 Jan 2015 Post subject: |
Cheers Shaft, I'll add it to the to do list!
Tackled the shocks today, no-one came forward with any gems of wisdom so I just winged it (little bit of trial and error involved). Before - I promise you these aren't bent, my phone camera is playing tricks.
https://i58.tinypic.com/2ic33ig.jpg
Those knee pads are saving my ability to walk, this stuff takes ages, I need a workbench...
https://i59.tinypic.com/292oh1g.jpg
Comparison.
https://i62.tinypic.com/ofxd9d.jpg
240 Grit then 1000 Grit.
https://i60.tinypic.com/2h863hj.jpg
This bit was heavily pitted, sanded it down and buffed it with the Dremel, came up ok.
https://i62.tinypic.com/euq8ic.jpg
Applied some Peek Polish and back on the bike, massive difference!! I really like the satisfying jobs like this.
The detectives among you will notice the difference on the top bolts. Some bright sod has cut the right one short so it only just gets a good hold with the nut, might have to do something about that eventually...
https://i57.tinypic.com/111nz9l.jpg
https://i57.tinypic.com/19xzpv.jpg
Last thing for today, sand off the old resin ready to stick the new emblem on. Ordered some JB Weld to do it with as heard good things.
https://i58.tinypic.com/23jmuqa.jpg
I bought a range of sand papers from 240 to 1500 grit to polish the engine. The sheer amount of work involved in that is making me do EVERYTHING ELSE first. Anyone want to come spend a week polishing my engine? Offering £2 an hour, a cuppa and i'll let you watch freeview on my small tele?!
Bargain that like. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Ed Case |
Ed Case World Chat Champion
Shreeve |
Posted: 22:47 - 29 Jan 2015 Post subject: |
Thanks for the advice, cleaning advice is very welcome as I'm literally clueless. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Shreeve |
Posted: 12:38 - 31 Jan 2015 Post subject: |
Been a productive two days.
Hung the caliper for spraying.
https://i58.tinypic.com/smukcp.jpg
As i'm now a professional bike mechanic (please just let me have that one...) I can only work on a full stomach.
https://i60.tinypic.com/23jsknm.jpg
Spray time, first time i've ever done this so I was a bit apprehensive. This was the last thing done last night before going to see Kingsman: The Secret Service - highly recommended!
https://i60.tinypic.com/v4a1wl.jpg
https://i58.tinypic.com/2ecm176.jpg
https://i58.tinypic.com/205tlvs.jpg
https://i57.tinypic.com/9qixeh.jpg
Woke up this morning as if it was Christmas, how is this stuff so exciting? Maybe the novelty hasn't worn off yet... anyway, with my new indicators here and the bar stewards having bigger bolts than the bracket allowed, this happened...
https://i57.tinypic.com/2m7w6eg.jpg
After drilling the headlight brackets I bolted on the indicators.
https://i62.tinypic.com/5d9ylj.jpg
https://i62.tinypic.com/4sog1s.jpg
The old connections had larger bullet fixings than the new ones so I had to crimp them together.
https://i62.tinypic.com/2a4x76.jpg
Somehow it worked!
https://i59.tinypic.com/jsegl4.jpg
Thought I'd give the headlamp a polish while I had it off.
https://i62.tinypic.com/21mzy1u.jpg
The work area.
https://i62.tinypic.com/20ix7kg.jpg
Now that the caliper is dry it's time to reassemble!
I reckon I did an ok job on the paint!
https://i62.tinypic.com/122p3et.jpg
https://i60.tinypic.com/2e52lo1.jpg
First, oil seal.
https://i58.tinypic.com/5uiam1.jpg
Next, dust seal. Also sanded the bolts a little as they were coated in rust.
https://i58.tinypic.com/3478vp2.jpg
Turns out this is an absolute arse to fit. I had to put it around the piston and use a seal pick to push it in to the groove after pushing the piston passed the oil seal, nightmare
https://i60.tinypic.com/t7mzon.jpg
https://i61.tinypic.com/2h37dvt.jpg
With the caliper rebuilt I bolted it back on the bracket and set about putting some brake fluid back in. For some reason the brake fluid wasn't leaving the M/C so i started to investigate. Weird straight through adapter.
https://i62.tinypic.com/314qek6.jpg
Looked a bit gunky under the reservoir.
https://i60.tinypic.com/1ebfhk.jpg
Ok, maybe a lot gunky... think I found the source of the blockage!
https://i58.tinypic.com/eaifzb.jpg
After cleaning this I had an absolute pig of a job getting the brake fluid in to the hose. I just couldn't seem to catch it and pumping the lever just moved air. I can confirm that blowing through brake hoses to see if they actually work is a bad idea btw...
Eventually (and after putting my early teenage pumping muscles to good use, giggity), I managed to get it through and bled the air out. The end product - a fully functioning clean front brake Though the hose is too long and looks horrendous, can't win em all!
https://i60.tinypic.com/2iibkm8.jpg
https://i59.tinypic.com/339klyq.jpg
I learned loads doing this, 100% confident with brakes now which actually makes me feel better about owning bikes generally. The question now is, what do I do next? ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 14:31 - 31 Jan 2015 Post subject: |
Shreeve wrote: | Woke up this morning as if it was Christmas, how is this stuff so exciting? Maybe the novelty hasn't worn off yet... |
If you are very unlucky, it maybe never will!
For months I have bee having to push the heads back on the cheap & nasty back indicators every time I get on... pondering cause and solution, my soft panniers and whether it was my frequent pillion.. and NOT really 'sorting' it.... until I pushed them back on t'other day, started the bike up to warm, and watched them vibrate off again..... Oh-Kay... new shiny bit's needed.
After perusing e-bay for ages, and finally settling on a pair... the glorious anticipation of arrival was some-what short-lived, the postman knocking on the door a mere 18 hours after hitting the 'Buy it Now' button to hand me my pressies
So rushed out and swapped them onto the bike..... OH! the underwhelmingness of it. I was actually HAPPY that the wire on the new indies was slightly 'short' and had to take them back off to bring into the kitchen, chop the wires off the old indies, and splice to the new to stretch them.... added a whole ten minutes to the 'fun.. about half as long as I spent going 'Oooh! Works' testing it lit up.... then 'Lets try the other one... oooh! That works too.. lets see if the other one still works.... oooh" and well, you get the idea!
Tip for you while you are playing 'lectrics; get a 10A 'Electronic' flasher unit of e-bay. ; Chrystal timed, it has fixed flash-rate regardless of bulb-loading, so you dont have to worry about balencing bulb wattages; like having 21W tungstens in 'OE' lamps or 12w tungstens mini-cators, or mA LED's anywhere. No moving parts, either, they don't click or buzz or fill with water. £7.omething, they are cheaper than pattern electro-mech ones and a lot cheaper than OE. (have used that one on about five bikes so far)
Yeah.. so after twenty minutes of 'wonder' playing with a light switch, marvelling at lights lighting up... I had to turn my attention to something a little more challenging...... Grab Rail Bolts.... I had some long hex-heads with rack-spacers poking out of the recesses, from where I didn't have the OE bolts. Snowie I recall procured some new M8 Allen bolts to do her Guzzi Gearbox last springs, so I went 'hunting' for the 'spares'... after being shouted at by precious pillion for having loads of staka-boxes and ice-cream tubs littering the kitchen when she came in from school and wanted to make a sandwich.... I gave up ad ordered two to length of e-bay... OH the joy, of them NOT arrivg for two days, giving me that Kid-Before-Chrstmas glee, and anther chance to run out into the snow in my dressing gown, three days later, armed with an allen key, when they did.....
It's great... thirty years ago, you had to go to a SHOP, and be told they'd have to 'order it in'.. wait a week, drop in on the way back from school/college/wherever, each evening, to be disappointed that it was NOT 'in' yet. OR, you would have to send an SAE to M&P, from one of their adds in MCN to get a catalogue..... you could wait a fortnight for that! Then having decided what you wanted, fill in the order form in black ball-point pen; go to the post-office ad get a postal order for the exact total, or tick the box and add the surcharge for 'Cash on Delivery' (Does the Post Office still do That I wonder?) 'cos credit cards and debit cards were NOT in common usage and few only Dad, if you were lucky, had a cheque-book.... and hope some-one was 'in' AND could find the envelope you left the cash in for the postie, when your bits arrived.... Ooooh the anticipation, like Christmas, could stretch out TILL, ad BEYOND Christmas
e-bay... you can get that kid-before Christmas feeling every week!
And in fact, I think my Daughter and Snowie DO! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Shreeve |
Posted: 15:07 - 31 Jan 2015 Post subject: |
Cheers for the advice on the relay and the story!
I certainly hope it doesn't fade, I think the Mrs is starting to feel neglected though! ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Bru |
Bru Trackday Trickster
KLR600 |
KLR600 World Chat Champion
Shreeve |
Ed Case |
Shreeve |
Posted: 18:38 - 31 Jan 2015 Post subject: |
After all this work I thought it deserved a good run, didn't miss a beat and the front brakes are brilliant if I do say so myself!
https://i61.tinypic.com/14waujb.jpg
https://i61.tinypic.com/s25gud.jpg ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
pepperami |
pepperami Super Spammer
Posted: 22:09 - 31 Jan 2015 Post subject: |
cool ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 23:21 - 31 Jan 2015 Post subject: |
Good Grief! Just read that Test Review by, no less than Brian Chrichton; who still writes, I believe for Classic M/C magazine, but the chap who took the underwhelming Norton Rotary to TT success in the 90's.
However.... to spot the irony...
"Block Tread Rear Tyre looks dated but works well"
"Engine Power* is sufficient for wheel spin 1/4 mile starts dropping the clutch at 8000rpm"
*24hp at 10,000rpm
Telling really, isn't it, that a supposedly 'good' tyre, in them days could be overwhelmed by a mere twenty four horse-power! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Ed Case |
Fladdem |
Fladdem World Chat Champion
Posted: 21:16 - 03 Feb 2015 Post subject: |
Looking good, let me know how the paint on the caliper holds up, I may do the same to my Kwak, I am definitely going to go and replace the pistons up front, I can't think of any other reason why the front brakes are so rubbish other than that the new seals have been damaged by the pitting and leaking slightly.
After reading Tef's post on the indicators, I just imagine him getting absolutely ecstatic every time the light flashes on, then on the verge of tears as it goes out again, before becoming over the moon that it flashes back on afterwards. In my mind, he does this for hours, sets up all of his 125's in a row and tries to sink up the flashes. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
Shreeve |
Posted: 21:34 - 21 May 2015 Post subject: |
Well I've had some cracking rides on it and it's been an absolute champ. I think this one is a lifer, would hate to sell it.
Tonight I decided to do an oil change so started ticking it over to get up to temp, a couple of minutes in I realise there's a peculiar smell... petrol. It was pissing everywhere from somewhere around the petcock/carb and I almost shart myself when i realised petrol was leaking on to a hot engine case...
I've decided this means I need to strip the whole thing down and do a slow restoration. Carbs need a clean, there's rust all over the frame and the electrics are scarier than Hellraiser when I watched it as a 9 year old.
I'll be posting here as and when I progress which won't be as rapid as the last time. See how it goes though. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Ed Case |
Posted: 21:40 - 21 May 2015 Post subject: |
A chrome sidestand eh ?........maaaan, that's cooool.......... |
Shreeve |
Posted: 08:06 - 22 May 2015 Post subject: |
Thoughts on Pod filters? Worth the hassle of re-jetting the carbs?
They look cool. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Shaft |
Ed Case |
lilredmachine |
lilredmachine World Chat Champion
Shreeve |
Posted: 08:15 - 23 May 2015 Post subject: |
Stunning! Where did you get the tank and fairings done?
Braided hoses are on the to buy list ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
stevo as b4 |
The last post was made 8 years, 341 days ago. Instead of replying here, would creating a new thread be more useful? |
