grant965 Brolly Dolly
Posted: 22:06 - 12 Feb 2015 Post subject: Few job lots, spares, projects, business start up. Full List |
Hi all,
Mentioned I no longer had time to sell bike parts and so was selling everything I had in job lots:
Box 1
YZF R 125
-loom x 4.
- right hand switch gear and handle bar x 2.
- Tail tidy with indicators and number plate light
- different style tail tidy with number plate light
- left hand switch gear and handle bar x 2.
- ECU
CBR 125
- ecu
- reg/rec
- fuel pump
- rear caliper and bracket, 2012 i think.
Box 2
YZF R 125
-front seat
-rear seat cowl
-rear caliper and master cylinder
-pillion footrests, left and right
-front caliper with master cylinder x 2
-throttle body x 4
Triumph daytona 600 injectors/throttle body
Box 3
YZF R 125
-bottom yoke x 4
-left hand heel plate and linkage x2
-silver radiator x2
-right hand heel plate
-rear shock x 2
-coils with no plugs x 2
Box 4
Danmoto GP extreme end can with baffle
Early GSXR brakes (bought for a suzuki rf600 project so probably from GSXR of same year)
Triumph front disks - fit daytona 600 etc
3 cylinder triumph (cant remember model)
-right handle bar
-speedo drive and cable
-coolant tank
-bag of bolts/possibly fittings
Heated grip temperature control switch.
Yamaha Thundercat yzf600r black single bubble screen
-rear light and surround
Unknown fan
CBR 125 2012 pair of indicators
-fuel pump
Hyosung gt 125 fuel sender (quite rusty)
CBR 125 carbed model
-loom
-CDI
-reg/rec
-speedo and cable
-rear fairing joiner (between seats) blue/repsol
-screen
-number plate light and reflector
YZF R 125
-ECU
-reg/rec
-loom incl headlight loom
-loom
Generic carbon look indicators with iridium lense, flush fitting. (pair)
Unknown parts
-coil, maybe cbr or yzf r 125
-coil, possibly 3 cylinder triumph
-set of brackets
-earth lead
-loom, possibly 3 cyl triumph
Box 5
CBR 125
-top end in bits, might be no good
-engine parts in boxes, might be no good
-earth lead
-clocks, mounts snapped off
-rear light
-starter relay
-radiator and fan
-right hand throttle
3 cyl triumph top yoke and ignition
Box 6
Yamaha YZF R 125
-rear mudguard
-rear seat
-battery lead
-rear light
Box 7
CBR 125 FI
-front seat x 2
-thermostat
-brake hose, think its for the front
-main loom
-tank front cowl
-throttle body
-rear caliper for spares/repair
-rear master cylinder
-indicator marked FL
-engine side chain cover
-rear left and right hangers/pillion rests
CBR 125 carbed
-thermostat
Box 8
CBR 125 carb
-front seat
-rear seat
-front caliper and hose
-clocks, mounts damaged
-chain guard
CBR 125 FI
-Left hand engine mount
-right hand handle bar
Box 9
CBR 125 carb
-CDI
-reg/rec
-headlight, no loom etc just the shell
-rear light, mount broke off but is glueable
-grab rail
-coolant bottle
-coil
-Ignition switch, under seat lock and key
-airbox
-headlight loom
-pillion hangers, left and right
-left handle bar, switch, clutch perch.
-loom and starter relay
-airbox hose
-fuel filter + hose
Box 10
CBR 125 FI
-swing arm
-shock
-right handle bar
CBR 125 carb
-right handle bar + throttle tube and bar end
-coolant tank
-left handle bar, grip, bar end (slight bend)
-thermostat
-radiator and fan
-right hand engine bracket
-side stand and switch
-Yamaha R1 rear seat, slight rip to one corner
YZF R 125
-front caliper and master cylinder
-coolant bottle x2
-left hand heel plate + linkage (snapped peg)
-handlebar left and right
-shock
-linkage
Box 11
YZF R 125
- Stator
-engine cover
-undertray
-rear mudguard
-fan
-gear linkage
-fuel tank and pump
-rear seat
-starter relay
-water pump
-rocker cover
CBR 125 airbox
Box 12
Honda CBR 125 203
-bag of bolts/fittings
-engine bracket
-engine bracket with side mounts
-wiring loom with starter relay x2
-thermostat
-bottom yoke
-coil x 2
-grab handle left and right
-ECU
-Reg/rec
CBR 125 carbed
-rear shock
-horn
Loads of other bits lying around, few are as follows:
3 cyl triumph end can
Jinlun JL 250
-forks for parts (end cap missing off one side)
-front caliper for parts
-front and rear wheels
CBR 125 engine (no head)
-a second engine I believe to be perfectly fine but it has been sat for a long time
YZF R 125 swing arm with mudguard
-read tank fairing, scrapped and bumped
-full engine that I believe needs a rebore
About 6 wheels from CBR 125 YZF R 125, some with disks etc some without.
Triumph Daytona 600
-fuel tank in silver
-engine, believe to be good but been sat under a cover outside for around 18 months
-downpipes
Also have a display I made to act as a backdrop for pictures for ebay etc.
Open to offer on everything, ideal for spares, or a project, or starting your own business.
Regards,
Grant ____________________ Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R |
